| spitfire123 |
 spitfire123 Could Be A Chat Bot
| MarJay |
 MarJay But it's British!
| colin1 |
 colin1 Captain Safety
| spitfire123 |
| spitfire123 |
| spitfire123 |
 Posted: 15:07 - 11 Apr 2009 Post subject: |
in reply to my own post above:
put new oil in gearbox.
i took the starter gear off and bump started it.....it still vibrates like hell.
i then double checked all the engine mounts....all tight....
the engine runs perfrct and dosent miss a beat.
but it is vibrating beyond belife...you can sit on it for maby 30 seconds just above idol and you can barly stand afterwards.
this thing is reeeeeeaaaaallllly pissing me off now..ive worked 5 days on it to get everything up to standerd and spent alot of oney on it....only to find anew problem.
ANY advice is REALY apriciated as im totaly stuck.
cheers all  ____________________ You won't be able to eat my dust......As it'll settle before you get there. |
| Vincent |
 Vincent Banned
| Kickstart |
 Kickstart The Oracle
| spitfire123 |
 Posted: 18:08 - 11 Apr 2009 Post subject: |
| Kickstart wrote: | Hi
Against popular belief I don't work on Mito engines all the time  .
However I have heard many times that the Mito workshop manual on timing up the balance shaft is wrong. If the balance shaft it out then it will likely make the vibration far worse rather than canceling it out.
Keith |
and how do i go about sorting this out?
as i say i dident split the crank or take the flywheel off....dident realy even touch the crank as it was real smooth.
thanks  ____________________ You won't be able to eat my dust......As it'll settle before you get there. |
| spitfire123 |
| Kickstart |
| spitfire123 |
| Kickstart |
| spitfire123 |
| spitfire123 |
| Kickstart |
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 03:37 - 12 Apr 2009 Post subject: |
you hear about loads of people putting their mitos together like this.
the manual that cagiva put out is wrong, so if you find the settings for the balancer shaft, do the opposite and it'll be fine. cagiva try and get you to set it 180 degrees out, making it vibrate like hell. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| spitfire123 |
| Kickstart |
 Posted: 16:19 - 12 Apr 2009 Post subject: |
Sounds like you have got it right, or maybe one tooth out by mistake.
The manual in English says bottom dead centre, but if you rear the other languages they say "punto morto superiore", "point mort superieur", "totpunkt positionieren" or "punto muerto superior", which all seem to be top dead centre. Basically the manual is right except it should be top rather than bottom.
| spitfire123 |
The last post was made 17 years, 121 days ago. Instead of replying here, would creating a new thread be more useful? |
