| Belgarion |
 Belgarion Renault 5 Driver
 Posted: 15:14 - 13 Apr 2009 Post subject: Cg125 Chain :| |
Well, after the advice given by you guys, I found the problem was the chain itself - I had already adjusted tension,and when I was testing alignment, I discovered a couple of links have seized. I tried some WD40 and relubing, and it seemed to help - until last night when the chain came off the rear sprocket. That wasn't fun - pushing it a mile or so was the last thing I wanted to do
I've re-tightened the chain for now - it works, but it's not exactly ideal. I would just leave it and not use it, but I have no real choice but to ride it as I need it to get to work.
I've been quoted between £40 and £65 to get a new one sorted and replaced.
I'd imagine I could probably do it myself - I checked out the various threads on it, and I think I can manage it.
Couple of questions tho:
Is a CG chain attachable without needing any specialised tools?
Are there any pitfalls I should be aware of that might end up making things worse?
Ta guys  ____________________ Bike: CG125 - Theory: Passed 20th June...64/75 Hazard, 49/50 Theory... Test: Module 1 - 15/10/09.... Failed  |
| nightshaddow |
 nightshaddow Nearly there...
 Posted: 15:39 - 13 Apr 2009 Post subject: |
i find all you need to fit a new chain on a cg size machine is a small flat head screw driver and a pair of long nose plyers, the small link size of the 428 pitch makes it a very easy job, i got my last chain from hien gerike for £16 they dont last long but i get 6 months out of one,
for £40 or so you can get an o ring chain which will last alot longer but i never had a problem with either,
if you get a cheap chain though get some good lube and do it regulaly or it will go alot quicker,
the split links are usualy suplyed with the chain so you shouldent have any problems ____________________ "WHAT DO YOU MEAN 100 MPH THATS IMPOSSIBLE Its chinese OFFICER."
Current rides CB 125 TDE(the next project) NS125RK ( now on the road ) CB125TDC (soon to be project 17) melody ( the nephews ) |
| virus |
 virus World Chat Champion
| Gaz-t1esto |
 Gaz-t1esto Borekit Bruiser
| Feasty |
 Feasty World Chat Champion
| Gaz-t1esto |
| Belgarion |
 Posted: 12:20 - 14 Apr 2009 Post subject: |
| Gaz-t1esto wrote: | Unclip the old chain at the clippy bit that looks like a U (forgotten what its called) with long nose pliers. Attach new chain to the old one and pull the old chain through thus will pull new chain into place (this till save you time trying to get the chain round the front sprocket as its a pain if you dont attach it), once pulled chain through, connect new chain up with the new clippy bit. A quicker way to remove old chain if its too corroded to remove the U clip thing is an angle grinder and then pulling new chain through but i shall let you decide how you would like to carry out your work. Gaz |
You know when you just read something, and think to yourself 'why the hell didn't I think of that?' Well, there's one example right there
The chain I believe just couldn't handle the atrocious weather this past winter, and as I don't have luxury of a garage or shed, it had to stand in the elements.
The rear sprocket seems to be ok. I totally understand that they should probably be replaced just as a matter of course, but to be totally honest, I simply don't have the time, tools or know-how to do it in a hurry. I will change them when I have a little more time however, as I can't imagine them being in pristine condition.
Is there any worth in spending £40+ on a better chain, or will the £15 one do the job without any huge issues? ____________________ Bike: CG125 - Theory: Passed 20th June...64/75 Hazard, 49/50 Theory... Test: Module 1 - 15/10/09.... Failed  |
| Faraz |
 Faraz Nearly there...
| nightshaddow |
 Posted: 13:41 - 14 Apr 2009 Post subject: |
for sure the 40 pound one will be better quality and last longer but you wont have any major issues with the 15 pound ones i have bought them many times when funds are low and as faraz said look after it good lube and correct adjustment ____________________ "WHAT DO YOU MEAN 100 MPH THATS IMPOSSIBLE Its chinese OFFICER."
The last post was made 17 years, 123 days ago. Instead of replying here, would creating a new thread be more useful? |
