Cg125 Chain :|
Belgarion
PostPosted: 15:14 - 13 Apr 2009    Post subject: Cg125 Chain :| Reply with quote
Well, after the advice given by you guys, I found the problem was the chain itself - I had already adjusted tension,and when I was testing alignment, I discovered a couple of links have seized. I tried some WD40 and relubing, and it seemed to help - until last night when the chain came off the rear sprocket. That wasn't fun - pushing it a mile or so was the last thing I wanted to do Razz
I've re-tightened the chain for now - it works, but it's not exactly ideal. I would just leave it and not use it, but I have no real choice but to ride it as I need it to get to work.
I've been quoted between £40 and £65 to get a new one sorted and replaced.
I'd imagine I could probably do it myself - I checked out the various threads on it, and I think I can manage it.
Couple of questions tho:
Is a CG chain attachable without needing any specialised tools?
Are there any pitfalls I should be aware of that might end up making things worse?
Ta guys Smile
Bike: CG125 - Theory: Passed 20th June...64/75 Hazard, 49/50 Theory... Test: Module 1 - 15/10/09.... Failed Sad
nightshaddow
PostPosted: 15:39 - 13 Apr 2009    Post subject: Reply with quote
i find all you need to fit a new chain on a cg size machine is a small flat head screw driver and a pair of long nose plyers, the small link size of the 428 pitch makes it a very easy job, i got my last chain from hien gerike for £16 they dont last long but i get 6 months out of one,
for £40 or so you can get an o ring chain which will last alot longer but i never had a problem with either,
if you get a cheap chain though get some good lube and do it regulaly or it will go alot quicker,
the split links are usualy suplyed with the chain so you shouldent have any problems
virus
PostPosted: 20:04 - 13 Apr 2009    Post subject: Reply with quote
wemoto sell a chain for 15 quid for a cg, its 20 minutes work to do and thats if your taking your time about it.
John
own: 81 xs1100g...
Gaz-t1esto
PostPosted: 09:33 - 14 Apr 2009    Post subject: Reply with quote
It is a doddle buddy. honestly. you wont even need a radio to listen to whilst you do it as its a quick and easy job.
Firstly, you want to undo wheel bolts slightly so that you can then slide wheel forward so that the new chain will fit using the chain tensioners.
Unclip the old chain at the clippy bit that looks like a U (forgotten what its called) with long nose pliers. Attach new chain to the old one and pull the old chain through thus will pull new chain into place (this till save you time trying to get the chain round the front sprocket as its a pain if you dont attach it), once pulled chain through, connect new chain up with the new clippy bit. A quicker way to remove old chain if its too corroded to remove the U clip thing is an angle grinder and then pulling new chain through but i shall let you decide how you would like to carry out your work.
Make sure you get the clip bit in the right direction (there will be a small diagram on the packaging showing which direction the clip should face when at the top of rear sprocket). it is essential that you do it as stated on the diagram. not following instructions leads to accidents and thats something no-one wants.
now you need to tighten the chain tensioners to the new correct position then tighten the wheel bolts back up.
Lube the new chain, wipe of excess lube and your good to go.
I done my chain not so long ago. i own a cbr 125 and imagine your chain will be similar to mines, shouldnt cost more that £30 for a fairly decent one.
Good luck
Gaz
Feasty
PostPosted: 09:37 - 14 Apr 2009    Post subject: Reply with quote
I've heard you should always change your sprockets when fitting a new chain otherwise the chain and sprockets won't match as evenly and so wear out a lot quicker...
Previous: Aprilia Habana Retro 50cc (beauty), Yamaha SR125 (fell apart), Honda XR125 (nippy little commuter), Honda SLR650 (Geewhizz), Yamaha Diversion 900S (Smoooooth) written off courtesy of a stupid escaped horse.
(7 year gap), BMW F650 (Relaxing ride). Aprilia Caponord ETV1000 (Big and bold). Yamaha FZS600 (got me in trouble too quick!).
Current: Yamaha TDM 900 (Comfy, light but big, power when needed).
Gaz-t1esto
PostPosted: 09:42 - 14 Apr 2009    Post subject: Reply with quote
This is something i forgot to mention and is certainly worth doing.
Inparticular the front sprocket as this takes on hell of a beating. changing the sprockets is failry easy if you got the two or 3 tools needed. the front sprocket can be a pain I am lead to believe if the spacers arent in the right position....i may be talking nonsense as i havent ever changed them myself. always left that for the workshop to do when needed.
*TIP* if you change the chain but not the sprockets, the chains life can be reduced considerably.
Belgarion
PostPosted: 12:20 - 14 Apr 2009    Post subject: Reply with quote
Gaz-t1esto wrote:
Unclip the old chain at the clippy bit that looks like a U (forgotten what its called) with long nose pliers. Attach new chain to the old one and pull the old chain through thus will pull new chain into place (this till save you time trying to get the chain round the front sprocket as its a pain if you dont attach it), once pulled chain through, connect new chain up with the new clippy bit. A quicker way to remove old chain if its too corroded to remove the U clip thing is an angle grinder and then pulling new chain through but i shall let you decide how you would like to carry out your work. Gaz
You know when you just read something, and think to yourself 'why the hell didn't I think of that?' Well, there's one example right there Razz
The chain I believe just couldn't handle the atrocious weather this past winter, and as I don't have luxury of a garage or shed, it had to stand in the elements.
The rear sprocket seems to be ok. I totally understand that they should probably be replaced just as a matter of course, but to be totally honest, I simply don't have the time, tools or know-how to do it in a hurry. I will change them when I have a little more time however, as I can't imagine them being in pristine condition.
Is there any worth in spending £40+ on a better chain, or will the £15 one do the job without any huge issues?
Faraz
PostPosted: 12:55 - 14 Apr 2009    Post subject: Reply with quote
Just get the £15 and take care of it.
'56 Yamaha MT-01
'05 Nissan 350z Roadster GT
3 words dude.. Fvck. Yes.
nightshaddow
PostPosted: 13:41 - 14 Apr 2009    Post subject: Reply with quote
for sure the 40 pound one will be better quality and last longer but you wont have any major issues with the 15 pound ones i have bought them many times when funds are low and as faraz said look after it good lube and correct adjustment
The last post was made 17 years, 124 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.36 - MySQL Queries: 13 - Page Size: 66.44 Kb
