my new bike
sandlerandle
PostPosted: 18:39 - 17 Apr 2009    Post subject: my new bike Reply with quote
hello
i have been out of biking for a year or 2. then by chance seen a cheap bike to which i liked the look of its a aprilia tuareg 125 not beening runing for over a year. the lad i got it off just knowed it as a tuareg but from looking on the net have found they is a es model wind and others.
its a d reg 87
does any one have any info on these bikes or can point me in the right direction. and is it worth doing up, as it stands it in need of a make over
IMG]https://i264.photobucket.com/albums/ii164/sandlerandle/DSC00321.jpg[/IMG]
check out my other interests www.yorkshire-suzuki.co.uk
OssY
PostPosted: 18:49 - 17 Apr 2009    Post subject: Reply with quote
If you wanna spend the time doing it up it is worth it fully just to see an older bike back on the road. My cousin had one for a few years he loved it. Nifty little 2stroke with 25bhp as standard new.
I would rip that engine apart and make sure it is all ok before you start commiting to spending your hard earned cash on putting it back on the road.
sandlerandle
PostPosted: 08:22 - 18 Apr 2009    Post subject: Reply with quote
i paid a small amont for it so dont mind putting a few quid into it. been looking on the net again and i think it has a 123 rotax engine in it. ap1 engine. i am going to get it out side in the light and pull it to bittoday. more photo to follow
BenR
PostPosted: 12:21 - 18 Apr 2009    Post subject: Reply with quote
Cool! Haven't seen one of those for donkeys years, should be more than 25bhp if it's the 123 engine. I would say as it cost you so little to start with it may be worth doing it up & getting it running, engine parts for those are still in abundance. Thumbs Up
The Artist
PostPosted: 12:53 - 18 Apr 2009    Post subject: Reply with quote
Make sure you take loads of pictures for us of each stage and put them all on here. We love this sort of thing.
sandlerandle
PostPosted: 17:10 - 18 Apr 2009    Post subject: Reply with quote
hi again thanks for the replys still cannt find any maneuls or anything which can help me sort this bike biike. i have never tryed to rebuilt a bike back up. i really want to get out on it every one who has seen it says how cool it is and i have had a few people offer to buy it of me but willnt sell it.
today i have put a new battery on it and spark plug turned it on and pressed the start and nothing no lights no starter sound nothing so have taken all the panels of to start looking for the problem.
sandlerandle
PostPosted: 18:33 - 18 Apr 2009    Post subject: Reply with quote
few pics of the wiring which i think is behind the iginistion not coming on.
and a few of the panels tank.if any one can identify the engine from these photos it would help me
i have also go the log book it was imported in 2001
BenR
PostPosted: 18:56 - 18 Apr 2009    Post subject: Reply with quote
Christ! That looks worse for wear. Shocked I'd strip it mate get oit all cleaned up & repaint everything. You'll be able to check all the connectors & such much better with everything off. Thumbs Up
carlnicholson...
PostPosted: 19:30 - 18 Apr 2009    Post subject: Reply with quote
The problem may be something as simple as a blown fuse. That would be very likely if there is no power to anything after fitting a new battery. If not then continuity test each length of wiring with a multimeter. Tedious but will almost certainly find the problem plus any other issues that may be lurking.
My advice would be to give it a thorough clean. Seeing as you intend to strip it apart and rebuild it, the easiest approach would be to give it a good steam clean and then clean each compenent with a rag soaked in thinners as it comes off. Another good tip is to put all the fasteners and washers of that component in a poly bag and tie it to the part, that way nothing goes missing and you know which screw secures which part.
I haven't tried any of the above on a motorcycle but they all helped when repairing various fast jet aircraft so the theory is well proven!!
Good luck and keep us all informed!
"THOSE WHO RISK NOTHING, DO NOTHING, ACHIEVE NOTHING, BECOME NOTHING."
kawashima
PostPosted: 14:05 - 19 Apr 2009    Post subject: Reply with quote
I'm not good at repairing bikes but it looks tough work for me. There are many rusty parts. I hope you sort it out.
own:2020 Serow 250
sandlerandle
PostPosted: 15:34 - 19 Apr 2009    Post subject: Reply with quote
well i till not ure weather to build it or break it. i till have not identified the engine. i have took some better pics and maybe some one will know which one it is. they is a few parts missing and i cannt find these untill i know which engine it is.
kawashima
PostPosted: 16:02 - 19 Apr 2009    Post subject: Reply with quote
I'm afraid buying a cheap better condition bike might cost less than repairing this bike watching these photos. Am I wrong?
own:2020 Serow 250
dougon2wheels
PostPosted: 16:23 - 19 Apr 2009    Post subject: Reply with quote
you got a bargain there.......
the engine is the very early 123 with a pneumatic power valve
from a distance you've got a 34mm carb and matching inlet rubber,these 2 are worth more than you paid for the bike alone......
it might not run because you have the polarity swapped on the battery.......looks to me like the neg connection is feeding the fuses Mr. Green
https://www.bikechatforums.com/files/dsc00332_116.jpg
nick606
PostPosted: 16:36 - 19 Apr 2009    Post subject: Reply with quote
tbh the hole electrics look rough as fuck Laughing
carlnicholson...
PostPosted: 17:30 - 19 Apr 2009    Post subject: Reply with quote
Second that. I'd say it looks like someones also done a bodge extension on the negative lead to make it reach the positive terminal on the battery. Try whpping it round, check the fuses and it may well come to life...
sandlerandle
PostPosted: 18:49 - 19 Apr 2009    Post subject: Reply with quote
thanks guys it worked !!!!!!!
it is still a bit mixed up horn sounds like a whisle and the lights are mixed up too. but the starter spins. i just need to find a cover to hold the starter gear on to see if it will start.
as long as its not costing me loads of money i am going to keep going with it untill i find a major problem. if i can here it running then i will stripp it down get it painted up and free off breaks and re build the supsenion.
the next thing i am un sure off is power valve? in the photo nothing is holding this on and they is a big spring under it which fell out.? any ideas welcome
SlimRick
PostPosted: 12:01 - 20 Apr 2009    Post subject: Reply with quote
I'll give you £100 for it Very Happy
sandlerandle
PostPosted: 17:13 - 20 Apr 2009    Post subject: Reply with quote
temping but i think i will keep hold of it Laughing Laughing Laughing
carlnicholson...
PostPosted: 17:59 - 20 Apr 2009    Post subject: Reply with quote
Don't you dare sell it without offering me first refusal!!!
I'd say your in a pretty priveliged position. You have little self confidence with engineering but have a decent and cheap bike that you don't depend on and is in need of a bit of work. That's a perfect situation! You'll quickly find how simple most of the jobs will be and with a bit of thought a decent manual (if you can find one) and some simple toolage, you'll get it sorted without too much difficulty or expense if you dig around for parts.
After all that you'll have a good little bike you'll feel a part of and be much more confident and capable with sorting your own bikes in future instead of paying garages for doing work. In time the bike will have paid for itself!
Stick with it mate!! Thumbs Up Wink
sandlerandle
PostPosted: 18:14 - 20 Apr 2009    Post subject: Reply with quote
dont worry its stayin with me. Very Happy
on sunday i could here all the bikes close to my house and was think i should be out there again. not been on a bike for few years. and cant want to get it sorted. even my dad wants a ride on it he hasnt been on a bike for 20 odd years.
i am just waiting for the lad i got it off to call me so i can go get the rest of the bits. sent him about 100 messages today asking when i could get them. he still has the starter gear cover so cannt try starting it untill i have that times a ticking. Rolling Eyes
PostPosted: 09:38 - 22 Apr 2009    Post subject: Reply with quote
It is a Tuareg Wind (although not sure it is badged Wind). The engine is a Rotax 127, not a 123 (main difference is that the 123 has a counter balancer but the 127 doesn't, the 127 basically being a competition engine that was also sold in road form while the 123 is a road engine). Quite a few internal bits are the same between the 123 and 127 engines, but not many external bits. Claimed power was 26hp, but I suspect the reality is 20~21.
The engine will run without most of the electrics in place (it is self generating). Basically the stator has 3 wires to connect to the coil and one wire that goes to the loom, and as long as those are OK then it should run.
The starter motor is a bit of a bodge on these. Bit of bent metal holding it on one side, while on the other it bolts to the plastic cover over the rotor.
Engine spares you should be able to get from Peter Knight (0176 141 4106 ).
carlnicholson...
PostPosted: 20:46 - 22 Apr 2009    Post subject: Reply with quote
My word Keith, how do you do it?!!! Shocked
PostPosted: 21:09 - 22 Apr 2009    Post subject: Reply with quote
Too many bikes with that engine it them!
PostPosted: 21:51 - 22 Apr 2009    Post subject: Reply with quote
CHR15 wrote:
3. undo the 3 bolts ontop of the engine ( the ones around the spark plug ) use a well fitting ring spanner or socket. DO NOT use an adjustable spanner, or something that half fits.
4. when youve got the head off, take some pictures of the bit you pulled off and the stuff underneath it, ie. piston / barrel.
On the 127 engine the head is a 1 piece unit. The 4 domed nuts you can see on the top go onto studs that come up from the crankcases, and hold both the barrel and head of. Once you have undone them you may as well take the barrel off (the head gasket is a rubber O ring, the outer gasket being a large square section rubber seal).
Piston is easy to get a replacement for, and gaskets not really a problem. Think the 127 fitted to the Tuareg has a plated barrel (the version of the engine in the early AF1 used a cast iron liner which could be rebored).
I might have a parts list for the bike or the engine. Not sure.
sandlerandle
PostPosted: 17:33 - 26 Apr 2009    Post subject: Reply with quote
bad news bike has to go Crying or Very sad
its going on ebay for quick sale
i just dont have the time to sort it out
thanks for all the help people have gave me
The last post was made 17 years, 168 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.96 - MySQL Queries: 13 - Page Size: 129.03 Kb
