gs550 starting
herald
PostPosted: 21:37 - 18 Apr 2009    Post subject: gs550 starting Reply with quote
Any ideas, recently got a 1979 gs550. Started great and ran well untill I ran the battrey flat. Charged battery but now cant start it. starter solind is clicking loudly, but thats about it. Cant try kick start as thats missing. Any ideas?
B10Hazard
PostPosted: 22:02 - 18 Apr 2009    Post subject: Reply with quote
Are you sure you have charged the battery fully/correctly ??
How much power is the battery giving ?.
Have a check with a multimetre. ( Im just asuming you can do this )
More than 12v is ideal. . .
Any less and that is proberly your problem.
Dan . . .
No longer any socks
herald
PostPosted: 22:07 - 18 Apr 2009    Post subject: Reply with quote
I havnt put multi meter on battery, but lights , horn etc all working fine.
pikey1
PostPosted: 17:51 - 19 Apr 2009    Post subject: Reply with quote
if the battery is fine but still wont start try jump leads. if this works it will be the kill switch on handlebar. happened twice to me with gs 650 and 850.
if not check the regulator/rectifier as the gs range always had probs with these.
Rolling Eyes
Pikey1
B10Hazard
PostPosted: 19:21 - 19 Apr 2009    Post subject: Reply with quote
These things may still work as they dont need anywhere near as much power as your starter motor.
Also check your starter solinoid, could be eroded with salt or something and need a clean. .
No longer any socks
herald
PostPosted: 17:09 - 20 Apr 2009    Post subject: Reply with quote
cheers for info suppose best try jump leads first of all. battery only 6 weeks old so would thought that should be ok?
Am i right in thinking that as solinoid is clicking then this and battery ok?
B10Hazard
PostPosted: 06:28 - 21 Apr 2009    Post subject: Reply with quote
Yes you would have thought the battery would be okay, but you have ran it flat and sounds like it has died in the doing or you have not charged it right.
And the starter solinoid will click, even with very low power.
So no, you are not right in thinking they are okay. Well the starter is okay, just has no power, from either a not properly charged or dead batery.
Have you done whta chri5 said yet ?
No longer any socks
ringer
PostPosted: 08:09 - 21 Apr 2009    Post subject: Reply with quote
The clue to the underlying problem is in your original statement
(sic) - please do learn how to spell properly
Ask yourself why it went flat - did you leave the ignition/lights on? Did the battery just gradually run out of juice? Did you use the starter a lot of times in succession?
It is my guess that there is a problem with the rectifier/charging circuit, and that has damaged your battery. You really do need to do those tests suggested by Chris5 and BioHazard.
Suzuki GT250 (stolen 1980), Kawasaki H1 500 (blew up 1982), Piaggio Liberty 125 (since 2008), Moto Morini 500 Strada (since 2008), CB125T (in bits)
herald
PostPosted: 16:17 - 21 Apr 2009    Post subject: Reply with quote
Cant get hold of multi meter till weekend, for sake of £20 i might as well just put new battery on.
The last post was made 16 years, 303 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 59.51 Kb
