| clancy |
 clancy World Chat Champion
| Itchy |
 Itchy Super Spammer
 Posted: 20:28 - 23 Apr 2009 Post subject: |
#2 Looks light a set of head race bearings PITA to do as you need the entire front end of the bike off and usually 2-3 special tools.
#3 check the wiring then the switch and that the brake lever actually activates the switch a replaced front end brake lever I got once did not touch the switch.
#4 Buy a rear reflector £2 from any bike/car factors infact go to a car factors they are usually cheaper.
#5 Erm tighten your chain?. from pictures your bike looks like it has the regular end of swing arm adjusters. Just undo the big bolts on the wheel spindle, then wind out the adjusters. Measure both sides of the adjusters to keep your wheel in line and turn the adjusters an equal amount to keep the wheel alignment.
Then do up the big bolts on the spindle , and sit on the bike with somebody else pushing the chain up and or down up so that it can just about slap the swing arm (see the manual for the correct amount of slack) it has to have some slack else it will wear your output shaft badly and cause chain snappage.
If however your adjusters are already the maximum distance out then its time for a new chain the other method of cutting a link out and rejoining it requires a few tools and is NOT recommended. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| Dilusi |
 Dilusi Borekit Bruiser
| clancy |
| Dilusi |
| clancy |
| MarJay |
 MarJay But it's British!
| Finglonga |
 Finglonga World Chat Champion
| Itchy |
 Itchy Super Spammer
| MarJay |
| Feasty |
 Feasty World Chat Champion
| clancy |
| clancy |
| Feasty |
| Mr Hammers |
 Mr Hammers World Chat Champion
The last post was made 17 years, 83 days ago. Instead of replying here, would creating a new thread be more useful? |
