(HELP) bike failed MOT because of....
clancy
PostPosted: 20:02 - 23 Apr 2009    Post subject: (HELP) bike failed MOT because of.... Reply with quote
1.-- nearside front shock absorber seal failed and leaking oil.
( know how to fix this)
2-- steering movement excessively "notchy" with the wheel raised.
3-- front stop light does not illuminate when brake is applied
4-- rear reflector missing.
5-- drive chain excessively loose.
i know how to replace the fork seal so i dont need help with that, but any help or advice with the other parts would be appreciated.
the mechanic that did the mot was abit useless and didnt explain anything to me.
ive written the 5 points just as he wrote them on my form.
the bike is a rieju rs2 matrix 2005 model.
any help would be apreciated cuz i need the bike back on the road as soon as possible.
thanks, leigh.
Itchy
PostPosted: 20:28 - 23 Apr 2009    Post subject: Reply with quote
#2 Looks light a set of head race bearings PITA to do as you need the entire front end of the bike off and usually 2-3 special tools.
#3 check the wiring then the switch and that the brake lever actually activates the switch a replaced front end brake lever I got once did not touch the switch.
#4 Buy a rear reflector £2 from any bike/car factors infact go to a car factors they are usually cheaper.
#5 Erm tighten your chain?. from pictures your bike looks like it has the regular end of swing arm adjusters. Just undo the big bolts on the wheel spindle, then wind out the adjusters. Measure both sides of the adjusters to keep your wheel in line and turn the adjusters an equal amount to keep the wheel alignment.
Then do up the big bolts on the spindle , and sit on the bike with somebody else pushing the chain up and or down up so that it can just about slap the swing arm (see the manual for the correct amount of slack) it has to have some slack else it will wear your output shaft badly and cause chain snappage.
If however your adjusters are already the maximum distance out then its time for a new chain the other method of cutting a link out and rejoining it requires a few tools and is NOT recommended.
Dilusi
PostPosted: 20:31 - 23 Apr 2009    Post subject: Reply with quote
May just need steering bearings taking apart, cleaning and re-greasing. If that doesn't work you'll need to fit new ones, shouldn't be to difficult if you know how to replace the fork seals.
Front brake light switch could be knackered or a bad connection. You should be able to prove this by shorting out the two connectors that fit onto the switch with each other.
Fit one.
Adjust the chain tension, unless they mean the chain is knackered.
clancy
PostPosted: 20:36 - 23 Apr 2009    Post subject: Reply with quote
what special tools might i require for the headrace bearings?
ill be allright with everything except the front break light.
any chance you could talk me through exactly what to do ? im not good with electrics, so this talk of shorting out connectors and whatever went right over my head?
thanks for your help, leigh.
KLX 300r
Dilusi
PostPosted: 20:49 - 23 Apr 2009    Post subject: Reply with quote
There should be two connectors going to a switch which will probably be under your front brake lever somewhere. Normally when you pull the brake lever it will release the switch and close the circut making your brake light come on. If you pull the two connectors off the switch and connect them together the brake light should come on. If it does theres a problem with the switch, if it doesn't you may have a wiring fault somewhere.
As for the steering bearings no special tools should be required other than maybe a C-spanner but I managed to do mine without.
clancy
PostPosted: 20:58 - 23 Apr 2009    Post subject: Reply with quote
ah right i get you.
ok , well ill check what you just said and get back to you.
KLX 300r
PostPosted: 22:43 - 23 Apr 2009    Post subject: Reply with quote
Don't do that, it won't fix it. Replace the bearings. Once there is a notch in it you can't fix it. If you're going to take the front end apart you might as well replace the bearings for the sake of £15.
Normally MOT places will put a stick on reflector on the corner of the number plate.
Tighten it so it moves 3cm in the middle of the lower chain run. Turn the chain through an entire rotation and make sure there are no tight spots. If there are, make sure it has some slack at the tightest spot.
Blimey, if you can do fork seals and can't tighten a chain... I'd worry! Wink
Finglonga
PostPosted: 23:10 - 23 Apr 2009    Post subject: Reply with quote
Not checking the basics it may fail on before taking a bike for an MOT is the worrying thing. Wink
Andy Sez....
F.Y.Y.F.F.
Itchy
PostPosted: 08:52 - 24 Apr 2009    Post subject: Reply with quote
Its called kitchen towel under the dust seals Wink
PostPosted: 08:57 - 24 Apr 2009    Post subject: Reply with quote
You mean like not checking water is not pi$$ing from the cylinder head before you set off to ride to the MOT place? Doh!
Feasty
PostPosted: 09:33 - 24 Apr 2009    Post subject: Re: (HELP) bike failed MOT because of.... Reply with quote
clancy wrote:
3-- front stop light does not illuminate when brake is applied.
Doh! Did you not tell the nice MOT tester/mechanic man that bikes generally don't have front stop lights, just rear ones - much like cars in fact! Rolling Eyes
Previous: Aprilia Habana Retro 50cc (beauty), Yamaha SR125 (fell apart), Honda XR125 (nippy little commuter), Honda SLR650 (Geewhizz), Yamaha Diversion 900S (Smoooooth) written off courtesy of a stupid escaped horse.
(7 year gap), BMW F650 (Relaxing ride). Aprilia Caponord ETV1000 (Big and bold). Yamaha FZS600 (got me in trouble too quick!).
Current: Yamaha TDM 900 (Comfy, light but big, power when needed).
clancy
PostPosted: 11:18 - 24 Apr 2009    Post subject: Re: (HELP) bike failed MOT because of.... Reply with quote
it doesnt mean a light on the front.
it means when you pull the front break the rear light doesnt illuminate.
he just worded it funny,
leigh.
KLX 300r
clancy
PostPosted: 11:21 - 24 Apr 2009    Post subject: Reply with quote
i know how to change the fork seals because i helped a friend do it.
and i knew the bike was going to fail the mot becasue of that, i just thought id put it in to see what needs doing as id only had the bike like 3 days and it wasnt in great nick.
leigh
KLX 300r
Feasty
PostPosted: 11:35 - 24 Apr 2009    Post subject: Re: (HELP) bike failed MOT because of.... Reply with quote
leigh.
Yes I know what it meant really... that's why there was a Laughing at the end of my post!
(I dunno why I bother wasting my sarcasm on this forum sometimes! Rolling Eyes )
Mr Hammers
PostPosted: 11:49 - 24 Apr 2009    Post subject: Re: (HELP) bike failed MOT because of.... Reply with quote
I read it that way too (but knew what he meant), so I for one could appreciate the sarcasm Thumbs Up Very Happy
A Guide To Powerbands
The last post was made 17 years, 80 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 1.92 - MySQL Queries: 13 - Page Size: 95.75 Kb
