40,000 miles on a CBR 400 safe?
Raf
PostPosted: 17:22 - 28 Apr 2009    Post subject: 40,000 miles on a CBR 400 safe? Reply with quote
Would 40,000 miles on the clock of a CBR 400 be a high number? I know its not recommended to buy a bike with this kind of mileage but the price is very good and the rest of the bike is in fair knick.
That_Hornet
PostPosted: 17:36 - 28 Apr 2009    Post subject: Reply with quote
CBR engins would survive an apocalypse,
along with Toyota Hilux'S, and cockroches
but 40k is alot.... good look around, test ride, through all the gears.
Charlie
PostPosted: 17:58 - 28 Apr 2009    Post subject: Reply with quote
What age is it?
It might be other parts that all start failing before the engine does.
jack_zxr400
PostPosted: 18:07 - 28 Apr 2009    Post subject: Reply with quote
wouldnt be too bad if it had enough history with it so you know its had parts replaced and serviced when it needed it
Previous Bike: ZXR 400
Current Bike: R6
Test Date: 8/8/2008-PASSED
Seb
PostPosted: 18:33 - 28 Apr 2009    Post subject: Reply with quote
As long as it's been properly maintained it should be ok, my ZZR was almost touching 40k when I sold it on and it was still as sweet as a nut, if anything it was in better shape than the 14k mile Futura I traded it in for Neutral
Try to budget for a decent service right of the bat if you don't have a full history to hand though, it'll do it good in the long run and let you get right ontop of any potential issues from the get go.
2010 Triumph 1050 Sprint ST
Seb
Oh and no crashing allowed FYI Wink
PostPosted: 18:47 - 28 Apr 2009    Post subject: Reply with quote
I believe it was someone from here that had a CBR400 with 100k on it.
craigs23
Mr Muscle
PostPosted: 19:20 - 28 Apr 2009    Post subject: Reply with quote
Should be fine. Check the charging system though.
Scotsman37
PostPosted: 19:33 - 28 Apr 2009    Post subject: Reply with quote
Ask when the engine was last fully overhauled, just in case of excessive wear&tear of circlips/gear cogs are needing to be replaced, as you don't want the gearbox to jam on you while riding!
mooserx
PostPosted: 19:54 - 28 Apr 2009    Post subject: Reply with quote
my old cbr had over 45k on it and was still running sweet, honda engines are indeed bulletproof.
TL1000r-handful.
binge
Emo Kiddy
PostPosted: 19:59 - 28 Apr 2009    Post subject: Reply with quote
You sure its 40,000 miles and not kilometers?
Unless its got the KPH to MPH converter then the mileometer will be clocking in KM not Miles.
As has been said, They are gear driven cams, And bloody solid engines to be honest.
Ben
DynaMight
PostPosted: 20:15 - 28 Apr 2009    Post subject: Reply with quote
At 40,000 miles a well looked after engine is barely half way through its life but theres other stuff that needs looking after/replacing like suspension, shock, exhaust system, brake discs, brakes and loads of other possibly expensive stuff.
Robby
Dirty Old Man
PostPosted: 20:20 - 28 Apr 2009    Post subject: Reply with quote
Maurice has an NC30 with about 100,000km on the clock. You wouldn't think it to look at it, but he has looked after it well.
40k on a CBR4 engine is no problem, they're pretty tough. They do suffer from infrequent oil and coolant changes though, corrosion from just using water as coolant will contribute to head gasket failure.
Of course, if it's had 40k miles or km of abuse and no servicing it'll be screwed. As others have said, its the rest of the bike that could be knackered, not so much from mileage but from age.
veze
PostPosted: 19:57 - 28 May 2009    Post subject: Reply with quote
well, in my experiance, get the valves check, ive had 2 cbr400 nc29 engines now, the first one had done 40.000. did a compression test on it, it was fine, two weeks later dropped a valve on cylinder 2 and mullerd the engine, so i got another engine with less milage, but it was running like crap and i couldnt get the carbs balanced, a compression test followed, this engine had no compression on cylinder 2. so ive dropped the engine out and gave it to my mechanice that i use regularly, for when thers something i dont wana do, and hey presto, the valves again. get your valves checked, compression test, take up to the redline through all the gears, see how it idles. if theres is dout in your mind for one second, walk away.
tlm50,mt5,sr50. rs125 extrema, cbr 400rr nc29 suzuki gs500e.Honda cbx250 rs . FJ1200 .fz6,fjr1300
kingsknight
PostPosted: 21:52 - 28 May 2009    Post subject: Reply with quote
My 2000 CG had 40k on the clock 10 of which i put on and the engine sounded like the day i got it!
I saw one CG with 96k on the clock and that still sounded sweet too! I guess it depends on how ragged the engine is?
My friends dad has a CB500 with 67k on the clock and he had that from new! he hasnt had any problems with that since buying it 10 years ago!
TS50 (sold) NS125F (sold) NSR125R-K (write off after 2 crashes) CG125 (nicked) XR125L-3 (Sold )-: ) DR125SM '11 (sold yay) XL125V '12 (In love with this bike) XT600E '04 (fun on the dirt)
Raf
PostPosted: 00:08 - 29 May 2009    Post subject: Reply with quote
Thanks for the advice. I ended up buying a CBR 600 FM for £700. Had the Valve clearances and Carbs balanced last week and have been told it was all spot on. Apart from the carbs which where quite off. Did the Oil and filters myself.
33,000 miles on the clock and in fair nick.
Thanks for the help, hope it takes me to 60,000+ because im happy with this one Smile
CBR1100xx - BMW K1100 - BMW K100 - Triumph Sprint ST 955i - Suzuki GSX-R 600 - Suzuki DR 350 - Yamaha XV 750 - Honda CBR 600 FM - Yamaha XT 600 - Yamaha Rs 200 - Honda NSR 125
The last post was made 17 years, 135 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 87.64 Kb
