r6 drinking water?
gray84
PostPosted: 19:48 - 26 Apr 2009    Post subject: r6 drinking water? Reply with quote
had a major service on my 02 r6 1500miles ago and since then ive had to top the water up twice. does this sound like a problem or could it just be some air in the system and now the waters made its way around? the bike runs fine and at the right temps but ive never even had to top it up before this.
thanks for any info
gray
Blue_SV650S
PostPosted: 20:04 - 26 Apr 2009    Post subject: Reply with quote
How much water did it take on each top up and after how many miles did you do each of them?
MaybeGuy
PostPosted: 22:11 - 26 Apr 2009    Post subject: Reply with quote
hold your hand over the exhaust and rev it to see if it gets covered in filthy water.
if it does, could be head gasket. check your sump too if the oils gone like tea.
if either of the above happens, ive got a nice GSXR with no running problems ill gladly swap it for Wink
The Artist
PostPosted: 23:48 - 26 Apr 2009    Post subject: Reply with quote
mattsprattuk wrote:
ive got a nice GSXR
Laughing Laughing Laughing Laughing
Noxious89123
PostPosted: 13:47 - 27 Apr 2009    Post subject: Reply with quote
Could be your radiator leaking a little? Depends really on how much you've had to top it up, and how often.
I had a small rad leak, that took ages for me to find. If you go for a decent ride, the rad gets hot enough to evaporate any water that leaks onto the fins, so you don't notice it. Similarly, it never leaked when the bike was stood. It was only after a short 10 minute ride or so, that you could see water on the rad.
Also, i was bored and couldn't help myself...
https://img518.imageshack.us/img518/5333/r6volvic.jpg
£60 a bottle, got the Yamaha logo on it don't cha know.
adamck
PostPosted: 14:19 - 27 Apr 2009    Post subject: Reply with quote
ahhh bugger you went for the "Volvic" when you shudda gone EVIAN/NAIVE route haha
https://www.bhatt.id.au/blogimg/bottled-water-for-naive-people.jpg
<insert><something><useful>Here</useful></something></insert>
gray84
PostPosted: 22:14 - 28 Apr 2009    Post subject: Reply with quote
lol cheers for the help.
when i toped it up it only had a small amount to fill the bottle not even a 100ml i did about 200miles and noticed it was low again. ill check for a leak on the rad next time i get it out. the oil is all clean.
Blue_SV650S
PostPosted: 22:18 - 28 Apr 2009    Post subject: Reply with quote
How much fluid is in the 'expansion tank'??
gray84
PostPosted: 17:55 - 29 Apr 2009    Post subject: Reply with quote
thats what im topping up. its on max now but keeps going down to min.
The Artist
PostPosted: 18:05 - 29 Apr 2009    Post subject: Reply with quote
Are you topping up the expansion tank!?!
Blue_SV650S
PostPosted: 22:02 - 29 Apr 2009    Post subject: Reply with quote
Why are you not topping up the radiator???
How much fluid will the radiator take?
Noxious89123
PostPosted: 22:04 - 29 Apr 2009    Post subject: Reply with quote
Well seeing as that's where the cooling system draws fluid from when it needs to... I'd imagine th answer to be yes.
Why are you surprised? Question
Blue_SV650S
PostPosted: 22:34 - 29 Apr 2009    Post subject: Reply with quote
To understand what is going on, it makes more logical sense to fill the rad to the brim and monitor the level in there ....
gray84
PostPosted: 22:58 - 29 Apr 2009    Post subject: Reply with quote
rigghhhhtttt Confused
the bloke at the shop by me told me to fill it from the expansion tank. ill go fill the rad ujp then lol. still havnt had time to look for leaks but best start by filling the rad up Embarassed
lukamon
PostPosted: 23:14 - 29 Apr 2009    Post subject: Reply with quote
good god man. its quite a bit past april 1st Mr. Green
killa wrote: Im an ass man myself
Blue_SV650S
PostPosted: 23:38 - 29 Apr 2009    Post subject: Reply with quote
Go on ... why is that such a silly thing to suggest?? Thinking
lukamon
PostPosted: 23:46 - 29 Apr 2009    Post subject: Reply with quote
because the coolant expansion bottle is the highest part of the cooling system, hence whenever the rad looses water, the level in the expansion bottle will go down to keep the rad full. kmx of mine did'nt have a bottle because the rad was higher up than the engine, so to top up the system, you put it in the rad.
Blue_SV650S
PostPosted: 23:51 - 29 Apr 2009    Post subject: Reply with quote
The bottle sits at about the crank level i.e. below the rad (certainly below the top of the rad) on the R6 ....
Race bikes don't have the 'expansion' tank at all ... just a 'catch' tank ...
gray84
PostPosted: 13:07 - 02 May 2009    Post subject: Reply with quote
its still using alot. im about to top it up again now. cant see any leeks from rad and help my hand over the exhaust and revved. had some cacky water but the bike had been used and standing so i let it warm up again and did it and nothing really come out just a little clean steam on my hand.
Coxyzxr
PostPosted: 14:40 - 02 May 2009    Post subject: Reply with quote
On my zxr the expansion tank is in the rear tail unit.
Not only that but the rad cap internals are sprung loaded so when rad pressure builds to a certain point only then will it push the rad cap innards open to allow water to over flow to the expansion tank.
I fI just filled the expansion tank it would just sit in the expansion tank and wouldn't feed into the rad because of the sprung cap blocking it.
**WAS FITTED "WRONG WAY ROUND" !** CANT ACCOUNT FOR THE STUPID !
Coxyzxr
PostPosted: 14:41 - 02 May 2009    Post subject: Reply with quote
hmmm. Question
gray84
PostPosted: 16:38 - 03 May 2009    Post subject: Reply with quote
well i wen up to the horse shoe pass ystaday with a few mates and i just bollocked a load of water in the expansion tank and it hasnt used a drop so it looks like it was just a thirsty moment.
cheers for your info guys
Blue_SV650S
PostPosted: 11:19 - 04 May 2009    Post subject: Reply with quote
Have you checked how much is in the rad NOW?
Its bound to have dropped a little (when it expands for the first time it will spit a bit out of the overflow), but you should still be able to see water in there. If you can't see water, you have a problem.
Noxious89123
PostPosted: 17:42 - 04 May 2009    Post subject: Reply with quote
Just to make sure we're all on the same page;
When you had this "Major service" they drained all the coolant and filled it back up, right? (as opposed to not doing anything to the cooling system at all).
After they'd drained it and refilled it, there would still be a bit of air in the system. Running the bike would eventually force all the air out of the system when it get's hot and pressurises. When it cools, it will draw fluid back into the system from the expansion tank. Once all th air is out of the system, it'll stop drawing water from the expansion tank.
Simples! Smile
The better way of getting the air out of the system would be to run the engine for a bit to dislodge any air (but don't let it get too hot), then open the rad cap, and top it up directly there. Rinse and repeat until there's no more air making it's way into the top of the rad. Tis how i did mine.
Ended up with antifreeze all down my leg, because my buddy that was pouring it in whilst I held the bike up missed a bit... Rolling Eyes
Blue_SV650S
PostPosted: 18:42 - 04 May 2009    Post subject: Reply with quote
Simples! Smile
Shocked Er that's not how it works ... but never mind Laughing
However, the run it for a bit to bring all the air to the top of the rad, let it cool and re-fill is indeed the way ahead on a coolant change ... just the same as it is the way a run and top-up is the way to go on an oil change!!! Thumbs Up
The last post was made 17 years, 58 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.22 - MySQL Queries: 13 - Page Size: 132.65 Kb
