no spark xj600
mad man
PostPosted: 09:29 - 30 Apr 2009    Post subject: no spark xj600 Reply with quote
hi could anyone help me i have a yamaha xj600 with no spark what should i look for? Thinking
chillyman0
PostPosted: 11:11 - 30 Apr 2009    Post subject: Reply with quote
starter relay... check the wiring
coils
caps Ht leads
could be anything best bet is to get a multimeter and test all the connection in the starting circuit
Finglonga
PostPosted: 12:07 - 30 Apr 2009    Post subject: Reply with quote
No spark on all 4 pots or just one?
Andy Sez....
F.Y.Y.F.F.
mad man
PostPosted: 12:22 - 30 Apr 2009    Post subject: Reply with quote
all 4
iooi
PostPosted: 12:33 - 30 Apr 2009    Post subject: Reply with quote
Kill switch on ????
Any eletrics work ?
Try pulling the clutch in, as the switch maybe faulty.
Same with side stand...
mad man
PostPosted: 13:13 - 30 Apr 2009    Post subject: Reply with quote
iooi wrote:
Kill switch on ????
Any eletrics work ?
indicators dont work, neutral light not on, headlights works and no bulb in brake light
Finglonga
PostPosted: 16:14 - 30 Apr 2009    Post subject: Reply with quote
Are you 100% sure it's in neutral? Check cut out switches on clutch lever and side stand are working.
Andy Sez....
F.Y.Y.F.F.
iooi
PostPosted: 18:28 - 30 Apr 2009    Post subject: Reply with quote
I take it then, that its turning over.
Have you charged the battery up. If its too low, while it will turn over there is nothing left for sparks.
If its not in netural, you need the clutch in. In fact mine will only start with the clutch pulled in no matter what.
Does the oil light come on when cranking ?
Have a look at the fuses, if other eletrics are not working then there is a good chance that something is wrong with the loom. These bike are well known for the loom connections deciding they have had enough. It could be either the one under the seat, or under the tank.
Scotsman37
PostPosted: 19:29 - 30 Apr 2009    Post subject: Reply with quote
Sometimes a lot of build of crap from the road gets into the loom's connection(s)or you may have used a high pressured water jet on your bike as you may have pushed some of it into the wiring looms connection points, either that you've now got a dry connection and so try disconnecting them and spray some WD40 into them to see if it helps you?
But as others have said check that there is a power going through wiring loom or if you've got a fuse blown. Either that is one said your battery may need recharging or it's incapable of holding a good enough charge - Check it with multimeter as it should be sitting at about 12volts, as the bike requires that to be able to turn the motor over!
sickpup
Old Timer
PostPosted: 00:01 - 01 May 2009    Post subject: Reply with quote
Would this by any chance be a Diversion and if so what year?
mad man
PostPosted: 13:51 - 01 May 2009    Post subject: Reply with quote
yes it is n 95
PostPosted: 14:08 - 01 May 2009    Post subject: Reply with quote
Is it cranking over? When cranking over does the rev counter move (it is driven by the ignition unit).
That the neutral light isn't on suggests that might be the issue. Think if the stand is down (or the bike thinks the stand is down) and the bike is not in neutral it kills the ignition (there is a complex relay to take care of it).
Neutral light works by earthing the neutral circuit through the switch. If the switch is faulty then this won't happen. Try earthing the wire to the neutral switch (a sky blue wire), and see if the neutral light comes on and the bike starts.
The last post was made 17 years, 177 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.52 - MySQL Queries: 13 - Page Size: 71.4 Kb
