| mad man |
 mad man L Plate Warrior
 Posted: 09:29 - 30 Apr 2009 Post subject: no spark xj600 |
hi could anyone help me i have a yamaha xj600 with no spark what should i look for?  |
| chillyman0 |
 chillyman0 Nearly there...
| Finglonga |
 Finglonga World Chat Champion
| mad man |
| iooi |
 iooi Super Spammer
 Posted: 12:33 - 30 Apr 2009 Post subject: |
Kill switch on ????
Any eletrics work ?
Try pulling the clutch in, as the switch maybe faulty.
Same with side stand... ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| mad man |
| Finglonga |
| iooi |
 iooi Super Spammer
 Posted: 18:28 - 30 Apr 2009 Post subject: |
I take it then, that its turning over.
Have you charged the battery up. If its too low, while it will turn over there is nothing left for sparks.
If its not in netural, you need the clutch in. In fact mine will only start with the clutch pulled in no matter what.
Does the oil light come on when cranking ?
Have a look at the fuses, if other eletrics are not working then there is a good chance that something is wrong with the loom. These bike are well known for the loom connections deciding they have had enough. It could be either the one under the seat, or under the tank. ____________________ Just because my bike was A DIVVY, does not mean i am......
| Scotsman37 |
 Scotsman37 World Chat Champion
| sickpup |
 sickpup Old Timer
| mad man |
 Posted: 14:08 - 01 May 2009 Post subject: |
Is it cranking over? When cranking over does the rev counter move (it is driven by the ignition unit).
That the neutral light isn't on suggests that might be the issue. Think if the stand is down (or the bike thinks the stand is down) and the bike is not in neutral it kills the ignition (there is a complex relay to take care of it).
Neutral light works by earthing the neutral circuit through the switch. If the switch is faulty then this won't happen. Try earthing the wire to the neutral switch (a sky blue wire), and see if the neutral light comes on and the bike starts.
The last post was made 17 years, 179 days ago. Instead of replying here, would creating a new thread be more useful? |
