 ---- World Chat Champion
 Posted: 12:44 - 06 May 2009 Post subject: Just had a tooth removed...I really need a ciggy :( |
The dentist said it's best not to as it increases the risk of infection.
Anyone bothered to stop smoking after having tooth removed???
It's bad enough that i cant have a hot coffee but going without a spliff aswell just isn't right  ____________________ DRZ-400sm |
| tribal_tiger |
 tribal_tiger World Chat Champion
 Posted: 12:58 - 06 May 2009 Post subject: |
I stopped for about 3 days after having a wisdom tooth out.
If you smoke you really increase the chance of getting dry socket which is basically a form of gangerene
Check out this post by suitor_stu
Edit: Fixed now, but he's already posted on here now!
Anyone else see him in their mind as Steve Martin in Little shop of horrors? ____________________ How much wood would a woodchuck chuck if a woodchuck could Chuck Norris?
All of it.
 Posted: 13:03 - 06 May 2009 Post subject: |
Linky not working...
Oh well,i suppose i should do without then  ____________________ DRZ-400sm |
| Suitor_Stu |
 Suitor_Stu Could Be A Chat Bot
 Posted: 13:08 - 06 May 2009 Post subject: |
The nicotine (and some other chemicals) in tobacco smoke reduce the number and size of blood vessels (and their ability to carry oxygen and healing cells) in your gums, which means that infection does not get washed away as well as it might do and you are increasing your risk of something called Alveolar Osteitis (or Dry Socket). Smoking is the biggest risk factor in this happening, but it's totally up to you if you want to risk it. Some say the pain is worse than the toothache it's self...
(however, if you want to read into it - and there are NO studies specifically been done on this btw before you say anything - nicotine is thought to be the major cause of this problem, and Grass doesn't contain Nicotine...?... )
Oh, and the hot thing is mainly until the anaesthetic wears off, so you don't drink something too hot and badly burn yourself (but not realise it till later). Wouldn't get too worked up about that. As said, smoking is the major cause of post op infections, however if you read the above link, you may do a bit of a risk assessment and see if you want to risk it...
Have fun,
Stu |
 Posted: 13:21 - 06 May 2009 Post subject: |
Just read that link
Firstly it seems i have less chance of any problems anyway as it was my upper wisdom tooth which was removed.
Secondly, i'm a bloke which lessens the chance.
But it also says not to drink out of a straw because of the negative pressure created,which i assume wont be a lot different to sucking on a ciggy.
Think i'll do without for now
I should be good for a cuppa now anyway as i drink it with more milk than water=not much chance of it being hot enough to burn me
Thanks for the reply fella
Did you pass your finals then? Should be due round about now i'm guessing.(just what i read in the thread tribal_tiger was trying to link to ) ____________________ DRZ-400sm |
| Suitor_Stu |
| tribal_tiger |
 Posted: 14:36 - 06 May 2009 Post subject: |
Good luck with the exams mate.
Right, we have the dentist, we have a forum vet, a forum policeman, web designers, photographers and computer techies. We've people who'll answer any mechanical question.
What other professions do we need on here to cover all help and advice?
Any lawyers? Doctors?
Politicians?  ____________________ How much wood would a woodchuck chuck if a woodchuck could Chuck Norris?
All of it. |
| Asharin |
 Asharin World Chat Champion
 Posted: 19:08 - 06 May 2009 Post subject: |
I've had several teeth removed in the past 3 years due to weak enamel and I never stopped smoking for it, before or after. Not had a single problem.
I've quit smoking now mind  ____________________ I can't sing: https://laughinginpurgatory.bandcamp.com and https://soundcloud.com/laughing-in-purgatory
I am Dyslexic of Borg, resemblance is fertile, your ass will be laminated.
2008 Honda Dullsville 700 |
| Handsome |
 Handsome World Chat Champion
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 19:39 - 06 May 2009 Post subject: |
smoke through your nose. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Flip |
 Flip Super Spammer
 Posted: 20:43 - 06 May 2009 Post subject: |
I agree with Ad. F*ck it you'll prob be fine. I was.  |
| msgander |
 msgander Brolly Dolly
 Posted: 23:16 - 06 May 2009 Post subject: |
I know its bad but gotta admit to smoking each time I have had teeth out....had a few out, not recommended by any means and we are all different but its never hurt me....  ____________________ Always believe that your guardian angel flies a bit faster than you............... |
| Louise |
 Louise World Chat Champion
 Posted: 12:18 - 07 May 2009 Post subject: |
I smoke after having teeth pulled and im still fine  |
| Neorion |
 Neorion World Chat Champion
| Marcg868 |
 Marcg868 World Chat Champion
| gavcarter |
 gavcarter Could Be A Chat Bot
 Posted: 19:07 - 20 May 2009 Post subject: |
I had one as i walked out of the surgery, i had a nice handy fag-butt sized hole in my teeth to put it in too! My mouth still wasnt working from the novacaine..... Didnt have any trouble gargled tcp for a few days till the hole healed over..
P.S dilute the TCP its worse than a mouthful of petrol  |
| 5v3d3b0 |
 5v3d3b0 World Chat Champion
 Posted: 23:17 - 29 Jun 2009 Post subject: |
About the hot drinks. It's unbelievable just how effective anesthetic can be. I once had a tooth fixed, and didn't remember to turn off my bad habit of biting the skin on the inside of my bottom lip. Basically I ended up biting off a piece the size of a fingernail Hurt a few hours later I tell ya! |
The last post was made 17 years, 113 days ago. Instead of replying here, would creating a new thread be more useful? |
