Counter steering
c_dug
PostPosted: 10:45 - 14 May 2009    Post subject: Counter steering Reply with quote
Just a quicky, should it be more of a push on the inside bar or a pull on the outside? Or is it a case of whatever feels better?
c_dug
Kwaks
I'm not a fast rider
PostPosted: 10:52 - 14 May 2009    Post subject: Reply with quote
usually a push for me, but a bit of both won't go amiss Thumbs Up
www.cliqueycuntsmcc.co.uk
Acemastr
PostPosted: 10:53 - 14 May 2009    Post subject: Reply with quote
there is no right way, try doing it with only one hand, you'll see just how much force you use to do it, then with both hands and how simple it is, it's a natural movement, as long as the bike leans you're doing it right1
2016 Toyota Tacoma Limited
PostPosted: 11:50 - 14 May 2009    Post subject: Reply with quote
I usually do both if I'm trying to turn quickly.
damz
PostPosted: 15:15 - 14 May 2009    Post subject: Reply with quote
it just happens when you need it to, i have never thought about it i just do it.
Current Bikes RVF400 - 94
Cars: RX7 FD, Eunos Roadster
JAMSXR
PostPosted: 15:29 - 14 May 2009    Post subject: Reply with quote
When cornering, if I use one hand it will always feel more secure when using my pushing hand.
s44678
Guest
PostPosted: 16:08 - 14 May 2009    Post subject: Reply with quote
While we're on it: When trying to straighten back up quickly after a corner, I feel like I really need to yank the bars straight to get the bike to stand up. Is this normal?
Always a bit scared of using the power to straighten the bike up in case the back steps out.
Smooth
PostPosted: 16:19 - 14 May 2009    Post subject: Reply with quote
Use the throttle.
nowhere.elysium
The Pork Lord
PostPosted: 16:22 - 14 May 2009    Post subject: Reply with quote
MC Bodge wrote:
Use the throttle.
^^ This. The bike automatically wants to straighten up if you use the throttle. Just don't go wild with it.
Acemastr
PostPosted: 16:28 - 14 May 2009    Post subject: Reply with quote
Counter steering INTO the corner will stand the bike up as well we learn that on 125's , not enough power to stand it back up lol.
Going round a left corner, push your right hand forward and it'll stand up.
TheFoxyDuke
PostPosted: 07:55 - 15 May 2009    Post subject: Reply with quote
I find a push to be easier to execute and a bit more natural (at least it's on the same side as the direction you want to turn) and I think the brain finds it easier to interpret.
On the other hand (pardon the pun) a pull on the outside bar seems to be more effective and produce a smoother turn.
So I guess a bit of both would do the trick Confused
BTW I still can't explain the whols dynamics behind it properly Rolling Eyes
FoxyD
The Tot
PostPosted: 08:59 - 15 May 2009    Post subject: Reply with quote
I think people should bookmark this:
Andy Ibbot shows how to "pick-up" on track... can be applied to the roads.
https://www.youtube.com/watch?v=5cbQoW3rk2o&feature=PlayList&p=49ED07A6AEF2DD6E&playnext=1&playnext_from=PL&index=4
Never argue with autism
pyx_e
PostPosted: 10:46 - 15 May 2009    Post subject: Reply with quote
A little body lean makes the arms do it naturally. Leaning inot a right-hander makes the right arm shorter (push) and left arm extend (pull).
Shiney!
Kawasaki: ER5, Versys, VN900.
c_dug
PostPosted: 10:52 - 15 May 2009    Post subject: Reply with quote
Its not really the natural counter steer im worried about, as the name suggests that kind of happens naturaly, im more on about if im running wide in a corner and need to tighten up the turn kind of thing.
I find myself using mr right hand regardless of the direction of the corner.
c_dug
TheFoxyDuke
PostPosted: 10:53 - 15 May 2009    Post subject: Reply with quote
Surely if we're countersteering into a right-hander then the right arm is extending (pushing) not becoming shorter Confused
FoxyD
robbieguy2003
PostPosted: 10:56 - 15 May 2009    Post subject: Reply with quote
Depends how you're riding really..
I've found when its slippy weather then hanging off a bit keeps the bike more upright and gives you a little more grip.
I'll tend to lean off before the corner, say its a right hand turn ill hang off right, push the left bar to counter steer the other way which keeps the bike in a straight line (me leaning pulls right/me counter steering left pulls left and it equals out).
Then when I hit where I want to turn in a counter steer the other right which tips the bike in.
The above seems to work for me and gives me more confidence in corners even though at times i prob do look like a monkey!
I've normally only pushed the inside bar rather than also pulled the outside, especially on left handers as that lets your right hand just do the throttle.
Current Bikes: Honda CBR 600RR - '07, Suzuki GSX1250 FA ST '11
Old Bikes: Suzuki Intruder 125 LC - '2001, Honda CBR 600F - '92, Honda CBR 600RR - '03
The last post was made 17 years, 145 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 90.2 Kb
