Magnesium vs Plastic
Plastic or Magnesium?
Plastic
20%
 20%  [ 1 ]
Magnesium
40%
 40%  [ 2 ]
Both the same
40%
 40%  [ 2 ]
Total Votes : 5
TUG
PostPosted: 21:03 - 19 May 2009    Post subject: Reply with quote
Try the mags and if they wear out at the same rate just stick to plastic ones?
Haz ER-5, innit!
PostPosted: 21:07 - 19 May 2009    Post subject: Re: Magnesium vs Plastic Reply with quote
You seem to have missed an option in your post: 'Correct my bad foot position'; I can add it to the poll if you'd like Smile.
Metal ones are there to advertise to others your bad positioning on the bike Razz.
salty21
PostPosted: 23:24 - 19 May 2009    Post subject: Reply with quote
try putting your feet on the pegs while riding Wink
Pernig
PostPosted: 23:59 - 19 May 2009    Post subject: Reply with quote
He normally rides with his feet dragging along the ground Laughing.
Completely irrelevant, but my phone's case is made of magnesium and it's the only phone I've had that has lasted a year without me breaking it, apart from my SLVR which also had a case made of some sort of metal.
H100 Breaking for spares
ZRX61
Victor Meldrew
PostPosted: 04:31 - 20 May 2009    Post subject: Re: Magnesium vs Plastic Reply with quote
Poll needs a "pick your fucking feet up" option Smile
DEN MONKEY
PostPosted: 06:25 - 20 May 2009    Post subject: Re: Magnesium vs Plastic Reply with quote
What about 'buy a fluckin harley' option
meh
s44678
Guest
PostPosted: 08:08 - 20 May 2009    Post subject: Reply with quote
Magnesium is relatively soft for a metal isn't it? Like softer than Zinc. Can't imagine it will last any longer than a hard plastic.
Thom
PostPosted: 11:04 - 20 May 2009    Post subject: Reply with quote
Stick the feet furthur back on the peg, so your toes are right up on them. Simple fix Mr. Green
Fawbish
PostPosted: 09:35 - 21 May 2009    Post subject: Reply with quote
No, theres no two ways about it.
Ride around corners with your toes on the peg....they wont scrape the ground. (EDIT: Unless you have quite literally size 20 feet OR you have shockingly soft, shitty suspension)
I occasionally touch my toes down on track, but only when Im getting knackered and havent quite put my foot back properly after a gear change.
You arent putting your feet back properly if youre using toe sliders.
PostPosted: 09:44 - 21 May 2009    Post subject: Reply with quote
With normal-sized pegs you have to have damn big feet to get your feet to touch down if they are on the peg properly - generally the peg will touch down first.
If bits of bike or feet are touching down and my foot positioning was half-decent, I'd be looking to hang off more, then to raise the ride height of the bike a bit.
The last post was made 17 years, 127 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.75 - MySQL Queries: 15 - Page Size: 75.37 Kb
