| gavcarter |
 gavcarter Could Be A Chat Bot
| benlooker |
 benlooker Two Stroke Sniffer
| gavcarter |
 Posted: 21:32 - 27 May 2009 Post subject: |
Cant find whats in it apart from white spirits and silicon Tried Data sheets etc they dont list the ingrediants.... |
| gavcarter |
 Posted: 21:43 - 27 May 2009 Post subject: |
Ok from reading the tin i know it contains white spirits, I've seen a few websites advising extra clean-up precautions because it contains silicon and can "fish eye" your next paint job.
Ive found a data sheet but can i f**k determine what is in it!
https://www.hammerite.com/lv/data_sheets/SDSHM101_hammerite_direct_to_rust_metal_paint_smooth_2.pdf
If anyone can decipher this and tell me what its base is id really appreciate it!
P.S Rustins brush cleaner has no mention of being able to thin cellulose, although I do have rustins cellulose thinners some where.... |
| finpos |
 finpos World Chat Champion
 Posted: 00:18 - 28 May 2009 Post subject: |
Proper Hammerite thinners is pretty much pure xylene.
I know this because I've used pure xylene thinners before and "official" Hammerite thinners smells exactly the same.
White spirit or acetone will NOT do the job properly.
You can buy it in B&Q but they keep it behind the counter. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| prawny1 |
 prawny1 World Chat Champion
| finpos |
 Posted: 00:50 - 28 May 2009 Post subject: |
I'd have to disagree with stinkwheel, there, last time I tried (and it was a few years ago, it may have changed with COSH type rules) xylene turned hammerite to snot and acetone thinned it.
Suck it and see, I guess, you can probably find somebody to give up their nail varnish remover for a test.
f. |
 Posted: 01:13 - 28 May 2009 Post subject: |
| finpos wrote: | I'd have to disagree with stinkwheel, there, last time I tried (and it was a few years ago, it may have changed with COSH type rules) xylene turned hammerite to snot and acetone thinned it.
f. |
I have a can of hammerite thinners right here, smells nothing like acetone.
I suppose the trick would be to buy hammerite thinners .
On further, not very extensive, research (like the first link off google when you search for hammerite thinners) it does actually contain acetone but it's mostly naptha and also contains butyl acetate.
That being the case. The afore-mentioned petrol isn't a bad bet. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| gavcarter |
 Posted: 10:18 - 28 May 2009 Post subject: |
As said I have thinned it with white spirits before and it thinned fine sprayed fine apart from a lot of vapour but dried matt and looked crap.....
The guy is sending me some hammerite thinners anyway ( i got to keep the rustins! )
In regards to the hammerite thinners they contain
75-100% NAPHTHA hydrotreatd heavy petroleum
2.5-10% ACETONE
1-2.5% N-Butyl Acetate
I couldnt find a data sheet for the rustins thinners to compare.... |
| benlooker |
| gavcarter |
 Posted: 22:27 - 28 May 2009 Post subject: |
The last post was made 17 years, 125 days ago. Instead of replying here, would creating a new thread be more useful? |
