Thinning Hammerite
gavcarter
PostPosted: 20:30 - 27 May 2009    Post subject: Thinning Hammerite Reply with quote
Hi all
I have thinned hammerite in the past with white spirits and used it in a spray gun but the white spirits make a LOT of vapour when spraying.
I ordered some hammerite brush cleaner / thinners from ebay but the plank sent RUSTINS BRUSH CLEANER.
Does anyone know how well this thins hammerite and whats its like to spray when thinned with this.
Cant really try it incase i need to send it back....
ta
benlooker
PostPosted: 21:26 - 27 May 2009    Post subject: Reply with quote
If its cellulose it should be ok. Youll get a lot of fumes regardless of what kind of thinners you use really, its all nasty stuff.
gavcarter
PostPosted: 21:32 - 27 May 2009    Post subject: Reply with quote
Cant find whats in it apart from white spirits and silicon Confused Tried Data sheets etc they dont list the ingrediants....
gavcarter
PostPosted: 21:43 - 27 May 2009    Post subject: Reply with quote
Ok from reading the tin i know it contains white spirits, I've seen a few websites advising extra clean-up precautions because it contains silicon and can "fish eye" your next paint job.
Ive found a data sheet but can i f**k determine what is in it!
https://www.hammerite.com/lv/data_sheets/SDSHM101_hammerite_direct_to_rust_metal_paint_smooth_2.pdf
If anyone can decipher this and tell me what its base is id really appreciate it!
P.S Rustins brush cleaner has no mention of being able to thin cellulose, although I do have rustins cellulose thinners some where....
finpos
PostPosted: 22:15 - 27 May 2009    Post subject: Reply with quote
Acetone.
f.
PostPosted: 00:18 - 28 May 2009    Post subject: Reply with quote
Proper Hammerite thinners is pretty much pure xylene.
I know this because I've used pure xylene thinners before and "official" Hammerite thinners smells exactly the same.
White spirit or acetone will NOT do the job properly.
You can buy it in B&Q but they keep it behind the counter.
prawny1
PostPosted: 00:48 - 28 May 2009    Post subject: Reply with quote
hammerite thins with petrol pretty well
finpos
PostPosted: 00:50 - 28 May 2009    Post subject: Reply with quote
I'd have to disagree with stinkwheel, there, last time I tried (and it was a few years ago, it may have changed with COSH type rules) xylene turned hammerite to snot and acetone thinned it.
Suck it and see, I guess, you can probably find somebody to give up their nail varnish remover for a test. Smile
f.
PostPosted: 01:13 - 28 May 2009    Post subject: Reply with quote
f.
I have a can of hammerite thinners right here, smells nothing like acetone.
I suppose the trick would be to buy hammerite thinners Wink.
On further, not very extensive, research (like the first link off google when you search for hammerite thinners) it does actually contain acetone but it's mostly naptha and also contains butyl acetate.
That being the case. The afore-mentioned petrol isn't a bad bet.
gavcarter
PostPosted: 10:18 - 28 May 2009    Post subject: Reply with quote
As said I have thinned it with white spirits before and it thinned fine sprayed fine apart from a lot of vapour but dried matt and looked crap.....
The guy is sending me some hammerite thinners anyway ( i got to keep the rustins! ) Thumbs Up
In regards to the hammerite thinners they contain
75-100% NAPHTHA hydrotreatd heavy petroleum
2.5-10% ACETONE
1-2.5% N-Butyl Acetate
I couldnt find a data sheet for the rustins thinners to compare....
benlooker
PostPosted: 21:04 - 28 May 2009    Post subject: Reply with quote
every make of paint/thinner is made slightly differntly, ive used standard thinner with hammerite before and had no problems, cant say ive ever sprayed it mind. Stuff i use contains methanol, xylene and toulene. Ive never heard of silicone in paint tho? Daftest thing ive heard, slicone and paint react?!
gavcarter
PostPosted: 22:27 - 28 May 2009    Post subject: Reply with quote
https://www.lawson-his.co.uk/scripts/details.php?cat=Hammerite%20Smooth%20Finish%20Paint&product=13373
Might be the daftest thing you've heard but its true.......
The last post was made 17 years, 124 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.12 - MySQL Queries: 13 - Page Size: 72.66 Kb
