 ---- World Chat Champion
 Posted: 22:15 - 31 May 2009 Post subject: Dropped pin into my engine EDIT:Sorted Now compression low? |
Pulling the head off my engine (honda cm125 custom) and i dropped the top timing chain tensioner pin into the engine.
What's my options?
I cant see it and i tryed one of the telescopic magnetic tool things with no luck.
Tryed fishing around with the same tool going through the sump plug hole again with no luck.
Even tryed taking the clutch cover off in the hope i might get to it through that way but no chance.Next plan was to pull the engine out and tip it upside down in the hope it might fall out but i cant see that happening.
Any other options other than splitting the crankcase (which i wouldn't have a clue how to do anyway)
Thanks
Dave ____________________ DRZ-400sm
| prawny1 |
 prawny1 World Chat Champion
 Posted: 22:23 - 31 May 2009 Post subject: |
| prawny1 |
 Posted: 23:00 - 31 May 2009 Post subject: |
I also tryed draining all the oil through but it wouldn't shift it.
The pin itself probably would fit through the sump plug hole,it's a bit thinner than the average pencil and about 2" long.
Splitting the crankcase isn't really an option as i wouldn't have a clue how to go on about that,so if i cant get it out it means selling the bike as parts
It only needed new piston rings aswell absolutely gutted.
I'm starting to wonder if maybe i could just leave it in there as the crank still turns freely enough,but it's probably just a matter of time before it hits something? ____________________ DRZ-400sm |
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 00:03 - 01 Jun 2009 Post subject: |
if its in the sump now it should be ok, as it would go with the current of the oil being taken through the strainer.
whats it made of? get a magnetic sump plug and take it out next oil change? ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
 Posted: 00:17 - 01 Jun 2009 Post subject: |
magnetic sump plug would probably be the way to do it.
Im going to tip the engine upside down and if it doesn't come out i'll leave it and see what happens.
Still have to find a new pin to replace it with now though.
Attached a pic@: the pin i dropped is numbered 6 in the pic. ____________________ DRZ-400sm
 Posted: 09:25 - 01 Jun 2009 Post subject: |
P.S.
Anyone know there the timing marks are on this?
Usually theres a "T" marked on the flywheel,but not in this case.I cant see any marks anywhere else either?
Thanks
Dave ____________________ DRZ-400sm |
| MaybeGuy |
 Posted: 10:08 - 01 Jun 2009 Post subject: |
T is the TDC, and the cam gear should have 2 lines on it.
failing that, you're looking for the point where all valves should be closed on the lead cylinder, and halfway between opening.
https://www.dansmc.com/valve_timing_lines.jpg ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
 Posted: 11:23 - 01 Jun 2009 Post subject: |
Cheers matt.
It's gonna be a twat then as there's no marks on the cam sprocket or on the flywheel.
Good news is that i got the pesky little pin out of the block .WooHoo
Ok so next job is to figure out why the compression was down so low.
Left pot:
75psi
105psi with a touch of oil down the bore.
Right pot:
10 psi
50 ish with oil down.
This would point to rings but they look fine,and theres only some very light scratches on the bore and piston.
Suppose there cheap and easy to replace regardless but i'd like to know if it's possible to get the measurements of what they should be so i can check 'em (the rings that is)
I may have to order a workshop manual from ebay i think  ____________________ DRZ-400sm |
| nightshaddow |
 nightshaddow Nearly there...
 Posted: 12:18 - 01 Jun 2009 Post subject: |
the source of low compression could be your valves, check your timing and your gaps if there slightly out then compression could be lost there, also check condition of head gasket as you are lookin at rings anyway you could do it all as you go along ____________________ "WHAT DO YOU MEAN 100 MPH THATS IMPOSSIBLE Its chinese OFFICER."
Current rides CB 125 TDE(the next project) NS125RK ( now on the road ) CB125TDC (soon to be project 17) melody ( the nephews ) |
| MaybeGuy |
 Posted: 13:16 - 01 Jun 2009 Post subject: |
definatly sounds like the timing is out.
not by much by the sounds of it, as its turning over without valve contact.
your close, so do it by trial and error very carefully, chances are you're 1 or 2 teeth out.
move it 1 tooth one way, and turn over very carefully and feel for piston to valve contact. if it stops, move the timing 2 teeth the other way and try again till you get it right.
just remember that the exhaust opens after the compression stroke and you'll be fine. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| rottie007 |
 rottie007 Two Stroke Sniffer
| MaybeGuy |
 Posted: 13:58 - 01 Jun 2009 Post subject: |
Went to see the bloke i bought it off who told me he replaced the piston rings and valve stem oil seals.
I noticed when i was pulling it apart he had put the right piston (the one with the lowest compression) in the wrong way round(had the IN markings facing forward!)
Also got the workshop manual off him which will help for the timing but it doesn't tell me what the compression should be
Checked the piston rings and there well in spec so now i'm thinking maybe he didn't seperate the gaps in the rings when he put them in,along with putting one of them in the wrong way round it's hard to tell what's wrong.
Will go have another play with it now. ____________________ DRZ-400sm |
| nightshaddow |
 Posted: 14:59 - 01 Jun 2009 Post subject: |
defiantly check you valve clearances, if they open the tinyest bit it will cause a loss of compression also how did the head gasket look, for low compression there only 1 or 2 things it can be ____________________ "WHAT DO YOU MEAN 100 MPH THATS IMPOSSIBLE Its chinese OFFICER."
| prawny1 |
 Posted: 21:50 - 01 Jun 2009 Post subject: |
Sorted
Right exhaust valve wasn't seating properly.Going to lap them all in just to be sure,and hopefully differences in compression after the wet test was caused by the rings not being seated in the right place.
Just have to find a valve spring compressor that fits it now
Thanks for the reply's
| prawny1 |
 Posted: 22:11 - 01 Jun 2009 Post subject: |
Yup,i used that same method years ago when doing valves on a rover 214 non of my 3 compressors would work so i used a socket underneath and got my brother to pull the collets out while i pressed the spring down with 2 screwdrivers .It worked but it was a twat since it was a 16v engine
Will give it a go tomorrow and see how it goes  ____________________ DRZ-400sm |
The last post was made 17 years, 104 days ago. Instead of replying here, would creating a new thread be more useful? |
