Superdream Advice Needed .....
smegballs
PostPosted: 11:55 - 01 Jun 2009    Post subject: Superdream Advice Needed ..... Reply with quote
I picked up a 250 SDream yesterday and so far have had no luck tracking down a manual (and no cash to get one!!).
Could you help enlighten me with the following:
Oil Filter Location
Tappet Clearances
Balancer shaft chain adjustment
Anything else to watch out for???
Cheers,
Rich
PS, Stinkwheel you've been PM'd for you fine advice on the SD camchain
Ant132
PostPosted: 18:04 - 01 Jun 2009    Post subject: Reply with quote
Oil filter is underneath the front of the crankcase on the right hand side of the bike if that makes any sense. Once you are underneath the engine it stands out like a sore thumb anyway.
Tappet clearances:
Inlet - 0.12mm (0.005in)
Exhaust - 0.16mm (0.006in)
Balancer shaft chain adjustment - Best explained with this image
https://images.superdreammax.multiply.com/image/3:superdreamhonda/photos/5/1200x1200/12/12.jpg?et=Pf5Qd0ZQNugqXuVdcvELAA&nmid=158777471
What to watch out for? Erm, to be honest im no expert (only had my 400 since november) but the only problems ive had is a fuel tank infested with crap which is easily solved by POR-15, worn sprocket circlip and cush drives and it used to burn oil and the head gasket was on its way out. All of which are now solved and were quite cheap fixes (gasket set and new rings). Ive also heard the cam-chains rattle when worn and are then best of changed if the adjuster is knackered. Not really sure of what else to say other than considering how old they are anythings possible Laughing Thumbs Up
1980 Suzuki TS50 ~ 1984 Honda CB400N ~ 1992 Triumph Trident ~ 1998 Suzuki Bandit 1200
smegballs
PostPosted: 21:39 - 01 Jun 2009    Post subject: Reply with quote
Thanks very much for the info!
Is that do you have a pdf of that manual or is that a scanned page,
after several hours searching I managed to get a manual courtesy of mattspratt only.... its in German!!!
So if you have a pdf of that manual Id be very grateful if you could PM if you can send it to me.
Anyway, I cleaned air filter today and tried to adjust camchain with the "manual assist" method of pushing the tensioner with a screwdriver. Brakes binding but bleed nipple sheared so its off to get a bleedy banjo tomorrow.
Cheers, Rich
Ant132
PostPosted: 21:44 - 01 Jun 2009    Post subject: Reply with quote
Workshop Manual
Updated Manual
Parts List
I have the parts list in PDF format if its easier. Let me know if you want it. You may have to become a member of the 'Superdream club' if you cannot follow the links. Lots of info on them though so worth joining. Its free but takes a few days to get accepted. If you need anything in paticular urgently then let me know and ill post them here. Thumbs Up
smegballs
PostPosted: 21:49 - 01 Jun 2009    Post subject: Reply with quote
Wicked!!! Thats just what I was looking for!
javascript:emoticon('Karma')
Not sure how I haven't found that on the web before but trust me I've been searching for ages!!!
Karma Given!!
Yeah on mine the cushdrive is pretty slack even though the C+S is in good shape.
I didn't know the CM bikes used a superdream engine!
Rich
Ant132
PostPosted: 21:52 - 01 Jun 2009    Post subject: Reply with quote
No problem Thumbs Up
Its a really good site for 'dreams actually. Lots of helpful stuff on there, I actually found it on BCF as it happens. Laughing (I think the owner/a member posted the link on Kals thread)
The last post was made 17 years, 104 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.93 - MySQL Queries: 15 - Page Size: 49.45 Kb
