Meet 'Rusty'
Bendy
Mrs Sensible
PostPosted: 22:42 - 04 Jun 2009    Post subject: Meet 'Rusty' Reply with quote
Some weeks ago, dapthechap posted a 'Free Bike' ad and since I fancied a project, I stuck my name in the ring and he was kind enough to let me have it. So one quick van ride to Slough and fifty quid later (I thought a token donation was in order) I had Rusty in my garage.
https://dl.dropbox.com/u/3523115/bcf/IMG_0677.JPG
Rusty is a 1997 CBR600FV. She may well have started out as a race/track bike but spent some years on the road, got binned and resprayed, developed an intermittent electrical fault, a coolant leak and spent the last 3 years sat in a garage.
So the mission is simple - get her running and get her MOT'd for the minimum outlay.
https://dl.dropbox.com/u/3523115/bcf/IMG_0562.JPG
https://dl.dropbox.com/u/3523115/bcf/IMG_0559.JPG
https://dl.dropbox.com/u/3523115/bcf/IMG_0551.JPG
https://dl.dropbox.com/u/3523115/bcf/IMG_0549.JPG
Essentially, everything that could be dried out, rusted up or seized solid, is. So far I've done:
Arrow Syphoned out the skanky old petrol, lobbed some new stuff in and with a jumpstarter and some persuasion she started. Oil change, and a new battery and now she's first time off the button, if a little lumpy idling. Oil change.
Arrow Extreme violence to get brake calipers off. Attacked them with a drill to get the old pads out, mucho cleaning and new pins to reassemble. Got a semblence of braking sorted with old shagged fluid, since it's not pissing everywhere I'll treat her to some new stuff this weekend. Aim is to get reasonably effective braking - will look to improve it later on.
Arrow Fixed the coolant leak. Simple case of removing the hose at the leaky joint, cleaning it all up and putting it back on nice and tight. Obviously this let all the coolant out, so she's had a flush and some new stuff.
Arrow Removed the hugger/chain guard with an angle grinder. There was no saving those fixings.
Arrow Wheel bearings were shagged - dried out and lumpy. Took two people, more extreme violence and a blow torch to get them changed. Wheels now spin freely and she can be pushed around the garage without back spasms.
Arrow New chain and sprockets, and cush drive rubbers for added value. Front sprocket nut was as much of a pain as the photo suggests - lots of penetrating oil, freeze 'n' release and about three batteries-worth of impact wrench action.
Arrow Liberally sprayed silver paint around to make her look a bit less scabby. If she's a keeper, I'll do a better job.
Hopefully get the remaining things (fairling and fiddly bits) done this weekend, my seat'll arrive from ebay and then I can take a punt at an MOT. If I can scrape a pass and actually take her for a run or two then I can get a better idea of where to go next (and possibly run slap bang into the 'intermittent electrical fault').
binge
Emo Kiddy
PostPosted: 23:03 - 04 Jun 2009    Post subject: Reply with quote
https://i55.photobucket.com/albums/g151/Joreyheart/salad-fingers.jpg
Certainly looks like you've got your work cut out.
Has it been stood for ages then?
Ben
PostPosted: 23:08 - 04 Jun 2009    Post subject: Reply with quote
If you have a project bike for two months and it passes an MOT, when both of my projects are dead I'm going to be very grumpy for a whole long time and I might even go and sit in the corner and sulk. That is how grumpy I'll be.
Meanie.
alun111
PostPosted: 07:12 - 05 Jun 2009    Post subject: Reply with quote
That project sir, is a steal! Looks to be a good project, I'll be watching!
PostPosted: 07:41 - 05 Jun 2009    Post subject: Reply with quote
Looking good. Thumbs Up
Luke_Retrofly
Silly Lesbian
PostPosted: 08:05 - 05 Jun 2009    Post subject: Reply with quote
cool Cool
1016
PostPosted: 08:32 - 05 Jun 2009    Post subject: Reply with quote
what fun - hope exhaust studs don't snap (hopefully you won't need to remove them)
Bendy
Mrs Sensible
PostPosted: 09:15 - 05 Jun 2009    Post subject: Reply with quote
Three years. Neutral
I'm staying firmly in denial about that. While the downpipes are rusted to shit, it seems to be largely surface and they appear to be fairly solid underneath - no holes and no blowing so far. So I'm tempted just to wire brush them, slap on a couple of coats of BBQ paint (without removing them) and ignore them for now.
I'm taking the same approach with anything I can get away with *not* undoing for now - my twisted logic suggests that anything vaguely connected to the engine will benefit from being heated and cooled a few times (ie. using the bike) before trying to undo it. So stuff like spark plugs etc I'm gonna leave and hope they free up a bit with use.
Bendy
Mrs Sensible
PostPosted: 12:52 - 05 Jun 2009    Post subject: Reply with quote
Pah, my neighbours are used to me! Though I did stick the can on for later running and for a quick run up the end of the road and back (which with no seat and about 5psi in the tyres was rubbish).
Whether it's a 'keeper' or not depends if I like it. If it's fun on the road then that's cool. But if it doesn't grab me particularly as a bike then the fun was the spannering and when the spannering's done I'll probably sell it for the cost of the parts I used to get it sorted.
No sense keeping it sat in a garage going rusty again if I prefer riding my other bikes, better to let someone get a bargain on a bike they'll enjoy.
Mr.Everready
PostPosted: 13:27 - 05 Jun 2009    Post subject: Reply with quote
I think you'll find it's Madam ! Wink
Have fun Bendy Thumbs Up
Kris
PostPosted: 18:19 - 05 Jun 2009    Post subject: Reply with quote
Nice project there. You using David Silvers for any spares etc?
The good thing about the older 'steely' CBRs is that the engines are pretty tough. Hope it doesn't cost the Earth...
www.prisonplanet.com
1016
PostPosted: 22:19 - 05 Jun 2009    Post subject: Reply with quote
re:- studs - good idea, just what I was thinking, could even soak studs/nuts with WD etc when you get to your destination and switch off - a few times.
binge
Emo Kiddy
PostPosted: 22:29 - 05 Jun 2009    Post subject: Reply with quote
LukeVFR wrote:
Started with no can? In a garage? Your neighbours must love you! Laughing
I'm dreading the day when I come to start up my TZR125 pit bike.
The engine has been stood for over a year. I've filled it with WD40 to help with any rust and corrosion.
Its going to smoke. Laughing
Back on Topic. Three Years Bendy? Niiice. Shocked
Ben
Fnatic
PostPosted: 22:36 - 05 Jun 2009    Post subject: Reply with quote
More images!
J D
PostPosted: 02:32 - 06 Jun 2009    Post subject: Reply with quote
Where was this ad Shocked
I hate you Bendy Mr. Green
Flip
PostPosted: 01:30 - 07 Jun 2009    Post subject: Reply with quote
If you bought the Apollo 11 Haynes manual to fix this, then it's goin' to rock(et). Laughing
Luke_Retrofly
Silly Lesbian
PostPosted: 09:46 - 08 Jun 2009    Post subject: Reply with quote
I was thinking are you going to go with any theme or just restore back to "as is".
Would be cool to get some custom farings on it or something with a crazy paint job Thumbs Up
Bendy
Mrs Sensible
PostPosted: 14:38 - 08 Jun 2009    Post subject: Reply with quote
As is, at first - I just wanna get it an MOT.
Then I'll probably get bored and do something stupid Thumbs Up
Did fuck all this weekend except make the front brakes work to a reasonable level. Not so inclined to work outside when it's cold and wet Neutral
Luke_Retrofly
Silly Lesbian
PostPosted: 15:09 - 08 Jun 2009    Post subject: Reply with quote
yes, its June don't you know Sad
geigh weather!
Gazdaman
I did a trackday!!!
PostPosted: 15:24 - 08 Jun 2009    Post subject: Reply with quote
You have a garage attached to your house with an internal door! You don't even need to set foot outside to get there!
Cold and wet doesn't come into it!
Use it at Cadwell Very Happy
Gaz
Bendy
Mrs Sensible
PostPosted: 15:57 - 08 Jun 2009    Post subject: Reply with quote
But the garage is so full of other bikes (including a big stupid Beemer that I can't move by myself) that you need to extend out onto the drive. Where it was tipping it down.
And it was cold. So I cleaned the bathroom instead.
Yes, I'm a wuss. But a wuss with a very clean bathroom. Mr. Green
konsoli
PostPosted: 00:02 - 25 Jun 2009    Post subject: Reply with quote
Ignore how bad this sounds but leave them rusty parts in vinegar overnight and they'll be sparkling! Very Happy Just make sure to clean the vinegar off properly after
J D
PostPosted: 14:57 - 27 Jun 2009    Post subject: Reply with quote
How is this going bendy? Let me know when you come to sell it, ill most likely have it off you.
Robby
Dirty Old Man
PostPosted: 19:42 - 25 Jul 2009    Post subject: Reply with quote
I say.
What's this in my garage?
It appears to be a silver CBR6. How did that get there?
https://www.bikechatforums.com/files/25072009215.jpg
The last post was made 17 years, 100 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.78 - MySQL Queries: 13 - Page Size: 129.8 Kb
