Rounded allen bolt. Help!!
GSXReater
PostPosted: 18:54 - 07 Jun 2009    Post subject: Rounded allen bolt. Help!! Reply with quote
Ive rounded an allen bolt that i need to get off.
Any tips of getting off without damaging my bike as its near the headstock.
Thanks.
Ichy
PostPosted: 19:03 - 07 Jun 2009    Post subject: Reply with quote
Got a picture?
GSXReater
PostPosted: 19:17 - 07 Jun 2009    Post subject: Reply with quote
Not at the mo, i'll get one later. In the meantime, any advice?
KevTM
PostPosted: 19:22 - 07 Jun 2009    Post subject: Reply with quote
impact driver + torx bit?
tshort2007
PostPosted: 19:34 - 07 Jun 2009    Post subject: Reply with quote
is it recessed or raised? dome headed or shank headed? whats it holding on? usually i remove all other bolts and take off whatever there holding on. May have to carefully drill out the head of the bolt, but you should be able to get some pliers on the remaining stud.
Or try hammering a 6pin tork head into the bolt, and use a ratchet to remove. Much less chance of wearing bolt heads this way.
TheFoxyDuke
PostPosted: 21:07 - 07 Jun 2009    Post subject: Reply with quote
Tried these?
https://www.screwfix.com/prods/96028/Van-Car-Accessories/Sockets-Hex/Irwin-5-Piece-Bolt-Grip-Nut-Remover-Set
Worked a treat when I rouned the hex out of a clurch slave cylinder bolt. Tried all the other options and couldn't get it to budge. These had it out in a jiffy. Well worth the money as was considering taking it to a mechanic to have ot drilled out and tapped again Rolling Eyes
FoxyD
Currently : Ducati Monster S4R 2005, 996cc, Blue with Corse stripe, Open Carbon Clutch Cover (TokaTokaTokaToka), Marchesini 5 Spoke Wheels, 117BHP.
Wanted : Ducati 749S 2005 onwards.
Rate my Posts, You Sons of Bitches!
stirlinggaz
PostPosted: 21:50 - 07 Jun 2009    Post subject: Reply with quote
Hi,
as previously mentioned i'd hammer in a torx bit & remove it with my screwdiver or impact driver/bit set.
if that failed i'd use the dremel cutting disc method. (i like the dremel,lol)
attach a cutting disc to the dremel & cut a nice clean slot into the head of the bolt.
then use a long, flat bladed screwdriver or the impact driver with a screwdriver bit.
if all that fails, then i'd just use a pointed grinding stone bit on the dremel & grind the head of the bolt completely off.
remove whatever the bolt is holding on.
then remove the stub of the bolt using the dremel & cutting disc method.
penetrating fluid left on overnight always helps.
cheers,
GAZ
K0rnIsAFAGGOT This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
c_dug
PostPosted: 22:09 - 07 Jun 2009    Post subject: Reply with quote
Re-tighten the other bolts holding whatever it is on, this will reduce the pressure on the bolt a little making it easier to turn, not by much but every little helps Laughing
Then as above i would go with the torx idea, worked brilliantly for me Thumbs Up
c_dug
The last post was made 17 years, 133 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.84 - MySQL Queries: 13 - Page Size: 60.21 Kb
