| That_Hornet |
 That_Hornet World Chat Champion
| Flip |
 Flip Super Spammer
 Posted: 22:09 - 12 Jun 2009 Post subject: |
I need the seals replacing on the left shock. That's all that needs doing. I'll live with it 'til I get new shocks next year.  |
| KevTM |
 KevTM World Chat Champion
 Posted: 22:12 - 12 Jun 2009 Post subject: |
speedo & rev counter bulbs need replacing - can't be assed, plus it improves your night riding by not looking at them all the time  |
| stinkwheel |
| The Artist |
 The Artist Super Spammer
 Posted: 22:15 - 12 Jun 2009 Post subject: |
rear tyre (changing)
chain (new one)
right hand side mirror (re thread the hole)
both front indicators (changing)
Engine mount bolts (fitting)
Brakes (adjusting (cable drum brakes))
Rev counter replacing (glass broke on it)
All require time and/or money  |
| reu |
 reu Trackday Trickster
 Posted: 22:26 - 12 Jun 2009 Post subject: |
Needs new clocks as rev one is fucked and want a new shinny digital one
sort my front braided line
change gear box oil
tidy up the wireing as i took all farings off the other day and wasnt happy!
Paint a few bits and bobs!
Although ive done some good stuff today for example worked out how i was going to mount new clocks before i ordered them. I got a new front tire today so yea this week im hopeing will all be done and dusted!  ____________________ 125cc Pitbike <sold> Aprilla Mx50 <current> |
| Bofh5 |
 Bofh5 World Chat Champion
| ms51ves3 |
 ms51ves3 Super Spammer
 Posted: 22:32 - 12 Jun 2009 Post subject: |
Change tyres (doing next week)
Re-tap some threads (doing next week)
Fit lower fairings (doing next week)
Put in the plate element and a proper air filter into the airbox (doing tomorrow)
Put some copper grease on the back of my rear brake pads as they are squeaking (doing next week)
Fit side stand switch that will hopefully turn up soon (doing next week)
Replace front brake pads as they are a bit vague (not sure when I'm doing them) |
| MarJay |
 MarJay But it's British!
| ttr |
 ttr Crazy Courier
| Howling TerrorOutOfOffice |
 Howling TerrorOutOfOffice Super Spammer
 Posted: 23:25 - 12 Jun 2009 Post subject: |
My bikes on its original fork springs and rear shocks..its 29yrs old
Hole in left silencer(puncture wound ! )
Rear shoes near wear limit
I love this little bike, even tho riding corners and bumps are a new experience with boingy-ness in abundance. That said, the chassis does really well(Tubular, with engine part of the frame) So it still doesn't get too lairy
Front Springs £20
Rear Shocks £44-£200
Rear shoes £8
Exhaust £?? can't find any originals (have phoned around aswell)
Pat ____________________ Diabolical homemade music Bandcamp and Soundcloud
The Harry Turner Project |
| billyboy |
 billyboy Borekit Bruiser
| Flip |
 Flip Super Spammer
| Faldo |
 Faldo World Chat Champion
 Posted: 00:04 - 13 Jun 2009 Post subject: |
ZX10R: Engine buggered, need to replace all bodywork too.
ZXR750: RH front indicator came off (means the RH rear doesn't flash either), clutch slipping occasionally when giving it the beans. ____________________ Current: ZZR1400
Previous: ZXR 400 L9, ZX-7R P5, ZZR 400, ZX-7R P6, Bandit 600, GSXR 750 Slingshot, DRZ400, DR650, ZX10R C1H, ZXR 750 L1, ZXR 750 L3, '99 ZX7R P4, KTM 300 EXC, ZX-9R E1, TDM850 |
| Flip |
 Flip Super Spammer
| c_dug |
 c_dug Super Spammer
 Posted: 01:52 - 13 Jun 2009 Post subject: |
Could right a books worth of stuff i need to do!
Carbs balance
Fix leak from oil sump gasket
New oil filter
New bulb in clocks
Have no front brake dust seals at all!
Have no front brake switch
Front tyre verging on illegaly low
Rear tyre has an un-nerving cut across the width of it
Front right indicator has no orange lense bit and is in the process of falling off
Rear right indicator in the process of falling off
Both end cans leaking very badly
Need a new cush drive
I dont think my licence plate light works.
Need to check valve clearences idealy, no idea when they were last done.
Need to put proper anti-freeze in the rad instead of just boiled water.
Need to either change or tighten up the head race bearings
Both brake levers bent, although both perfectly useable.
Neither brake is very strong, slows down well enough to be honest, but no real bite to them.
Anyway, i have no money to sort any of those problems so i will just have to live with them and hope i dont get pulled over any time soon i guess.
c_dug ____________________ I am a bellend, I am a man of constant sorrow, I am a gummy bear, I am a rock. |
| Blau Zedong |
 Blau Zedong Banned
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 14:44 - 13 Jun 2009 Post subject: |
Check the headlamp aim, I get flashed at night even when on low beam. MOT's due next month, so it's something I actually must do.
Due for an oil change. Might do that next week.
Although the braking's fine, I should get some new pads up front as they are getting low.
Probably should check the head bearings, felt an ever so slight donk during the week.
Speedo sometimes sticks until I go over 30. Thought that had gone away, but it did it again this week.
One of the bolts holding the air filter cover on had to be drilled out when I last changed the filter, so it's now being held on by cable ties and duct tape. Cosmetic, but would be nice to sort.
One bulb in the tacho has gone. Cosmetic.
Nothing an afternoon of pottering in the garage wouldnt cure. ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
Previously : CB100N > CB250RS > XJ900F > GT550 > GPZ750R/1000RX > AJS M16 > R100RT > Bullet 500 > CB500 > LS650P > Bullet Electra X & YBR125 > Bullet 350 "Superstar" & YBR125 Custom > Royal Enfield Classic 500 Despatch Limited Edition (28 of 200) & CB Two-Fifty Nighthawk > ER5 |
| Steve-D |
 Steve-D World Chat Champion
 Posted: 16:36 - 13 Jun 2009 Post subject: |
New chain and sprockets.
Backlight in the speedo doesn't work.
Trip counter resets itself every time I turn the ignition off.
Carbs balancing.
Valve clearances checking.
Ohlins rear shock needs a service.
Would like to powdercoat the wheels and fit some R1 USD's and a few carbon bits. ____________________ www.southwestbikers.com
Tristan The said 'Dunno what my pace will be like, fastish slow puncture on the rear and if I go too fast I risk my 'keys' falling out' |
| ToGGoT |
 ToGGoT Nitrous Nuisance
| tutton |
 tutton World Chat Champion
The last post was made 17 years, 141 days ago. Instead of replying here, would creating a new thread be more useful? |
