99' cb600 Hornet Derestriction - HELP
carlperkins00...
PostPosted: 14:13 - 16 Jun 2009    Post subject: 99' cb600 Hornet Derestriction - HELP Reply with quote
I got my 99' hornet 600 about 6 months ago after passing my test and am getting abit tired of the restrictor.
I can get the tank and airbox off but dont really know what to do with the carbs.
Ive heard from some people that they need re-jetting after youve taken the restrictors out??? dont know if this is true.
If this isnt true then has anyone got any knowledge of derestricting hornets?
want to do it on the quiet so parents dont find out. haha.
alun111
PostPosted: 17:57 - 17 Jun 2009    Post subject: Reply with quote
Might be best giving m0l0t0v a personal message.
I seem to remember him having his derestricted... although I'm not sure if he ever had any in Laughing
Worth a try either way.
carlperkins00...
PostPosted: 08:09 - 18 Jun 2009    Post subject: Reply with quote
ok cheers man, ill give it a try.
PostPosted: 08:11 - 18 Jun 2009    Post subject: Reply with quote
They shouldn't need rejetting if the kit's been fitted properly, and you just need to remove the washers from the inlet rubbers. At least that's the type I've come across.
It's not a massive job.
carlperkins00...
PostPosted: 08:17 - 18 Jun 2009    Post subject: Reply with quote
ahh yeah it turns out what ive been hearing is wrong Laughing
so basically i :-
1. take the tank off.
2. take the airbox off.
3. undo the carburettors and lift them up gently.
4. ease the 4 big washers out of the holes.
5. put carbs back
6. put airbox back
7. put tank on.
is that right??
it sounds right but i want to be 100% before trying it. Smile
PostPosted: 12:50 - 18 Jun 2009    Post subject: Reply with quote
Pretty much.
The washers aren't in the actual carbs themselves, they sit between the carbs and the engine in the rubbers.
The washers will be a very tight fit in the inlet rubbers. Thumbs Up
Timmeh
PostPosted: 15:24 - 18 Jun 2009    Post subject: Reply with quote
Agreed, those carb rubbers can be an absolute arse. I had loads of difficulty with my CBR, which has the same engine as yours.
You can try a little lubrication with some WD40, it seems to make things a bit easier.
carlperkins00...
PostPosted: 15:39 - 18 Jun 2009    Post subject: Reply with quote
aah right cool. Ill probably be doing it at the end of july when my mate comes down from scotland.
thanks for the advice everyone.
Carl.
carlperkins00...
PostPosted: 14:03 - 20 Jun 2009    Post subject: Reply with quote
just found out from m0l0t0v that i may have to buy a new CDI unit. does anyone know why?
appreciate the help.
PostPosted: 19:19 - 20 Jun 2009    Post subject: Reply with quote
In case you have a restricted CDI. Wink
There are different methods to restrict, some are just washers, and some are by the CDI, some are a combination of the two.
Depends on the method used on yours.
carlperkins00...
PostPosted: 21:19 - 20 Jun 2009    Post subject: Reply with quote
yeah mines just washers i reckon.
cheers.
carlperkins00...
PostPosted: 14:58 - 21 Jun 2009    Post subject: Reply with quote
done it this morning! much better, took about 2 hours in all.
m0l0t0v
PostPosted: 15:12 - 21 Jun 2009    Post subject: Reply with quote
Just saw this.
And carb rubbers are normally a bitch to take off but doovydoo's ones we're so easy to pull off it actually pissed me off! considering I had to saw my ones off and buy new ones Laughing
carlperkins00...
PostPosted: 18:35 - 21 Jun 2009    Post subject: Reply with quote
haha yeah mine were well easy, lifted the carbs, undone the clamps and then put a screwdriver in the hole and lifted.
job done.
cheers for the help people
The last post was made 17 years, 118 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.35 - MySQL Queries: 13 - Page Size: 79.36 Kb
