| carlperkins00... |
 carlperkins00... Crazy Courier
| alun111 |
 alun111 World Chat Champion
 Posted: 17:57 - 17 Jun 2009 Post subject: |
Might be best giving m0l0t0v a personal message.
I seem to remember him having his derestricted... although I'm not sure if he ever had any in
Worth a try either way. ____________________ Summer: '00 Honda CB600F Hornet
Past Bikes: Lifan LF100-5 Lifan LF125-A Honda C70 |
| carlperkins00... |
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 08:11 - 18 Jun 2009 Post subject: |
They shouldn't need rejetting if the kit's been fitted properly, and you just need to remove the washers from the inlet rubbers. At least that's the type I've come across.
It's not a massive job. ____________________ My Flickr |
| carlperkins00... |
 Posted: 08:17 - 18 Jun 2009 Post subject: |
ahh yeah it turns out what ive been hearing is wrong
so basically i :-
1. take the tank off.
2. take the airbox off.
3. undo the carburettors and lift them up gently.
4. ease the 4 big washers out of the holes.
5. put carbs back
6. put airbox back
7. put tank on.
is that right??
it sounds right but i want to be 100% before trying it.  |
| Wafer_Thin_Ham |
 Posted: 12:50 - 18 Jun 2009 Post subject: |
Pretty much.
The washers aren't in the actual carbs themselves, they sit between the carbs and the engine in the rubbers.
The washers will be a very tight fit in the inlet rubbers.  ____________________ My Flickr |
| Timmeh |
 Timmeh World Chat Champion
 Posted: 15:24 - 18 Jun 2009 Post subject: |
Agreed, those carb rubbers can be an absolute arse. I had loads of difficulty with my CBR, which has the same engine as yours.
You can try a little lubrication with some WD40, it seems to make things a bit easier.
 ____________________ GSXR400 x2 | '94 RVF400 | '93 TZR125 4DL (again)
20:48:18 Temeluchus: comp you hunk of smouldering homos3x you |
| carlperkins00... |
| carlperkins00... |
| Wafer_Thin_Ham |
 Posted: 19:19 - 20 Jun 2009 Post subject: |
In case you have a restricted CDI.
There are different methods to restrict, some are just washers, and some are by the CDI, some are a combination of the two.
Depends on the method used on yours. ____________________ My Flickr |
| carlperkins00... |
| carlperkins00... |
| m0l0t0v |
 m0l0t0v World Chat Champion
 Posted: 15:12 - 21 Jun 2009 Post subject: |
Just saw this.
And carb rubbers are normally a bitch to take off but doovydoo's ones we're so easy to pull off it actually pissed me off! considering I had to saw my ones off and buy new ones  ____________________ '99 Hornet 600 , VFR 400 NC30 '92 , Kasawamasaki GT 550 , '98 Hornet 600
**\Tarmacsurfer/** said: It's that immaculately manly coiffure of yours isn't it. One glimpse of your virile locks and the punters can't wait to buy whatever it is you suggest, as it might let them be just a little bit like the Adonis that is our very own Molly Doovydoo said: Its not my fault I can't get it up properly, I just wasn't blessed  |
| carlperkins00... |
The last post was made 17 years, 119 days ago. Instead of replying here, would creating a new thread be more useful? |
