| That-Kid-O |
 That-Kid-O Scooby Slapper
| Finglonga |
 Finglonga World Chat Champion
 Posted: 22:54 - 08 Sep 2009 Post subject: |
Yes, WD40 would be ideal to remove sticky residue from your exhaust. If you don't wash the WD40 off afterwards, it'll smoke a bit next time you start it as the WD40 burns off.
If the chain is very crudded up with gritty muck, it would be an idea to clean it off or it'll wear the chain like grinding paste. More of an issue in winter when there's grit on the roads (Your can of WD40 would come in handy here, or I use paraffin which is cheaper, I use an old nail brush after the muck is loosened).
If the chain looks dry, it'll need a lube. Generally every 3-400 miles, more frequently if the weather is bad (water tends to blast the lube off).
Check the chain tension and adjust if necessary when you lube it. Check the tension at the tight spot on the chain (find the tight spot by wiggling the chain as you rotate the wheel, it'll be tighter in one place than in the others unless it is brand new). ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| That-Kid-O |
| That-Kid-O |
| Alexio |
 Alexio World Chat Champion
 Posted: 00:44 - 09 Sep 2009 Post subject: |
You should also bear in mind that if your exhaust is very cold it would be a very bad idea, depending on which exhaust you have (and what it's made out of), to pour boiling hot water over it. A sudden change of temperature like that could (in theory) seriously damage or crack parts of it, or so I've been told.
WD40 all the way though  ____________________ will never give up his CG. I look at my fuel gauge more as a progress bar than a fuel gauge.
ms51ves3: why does it need 500 miles? Are you teaching it how to be a piston? |
| chris-red |
| That-Kid-O |
 Posted: 01:55 - 09 Sep 2009 Post subject: |
I have just removed the alarm remote from the ignition key and added it to my main set of keys. I will leave the bikes key on its own as I dont want to cover the yoke...
I was just told WD 40 will stain the titanium can.... Then someone said WD40 all the way, what do I do... use it?
And the gimbo (presumably the chain?) I think has been replaced before I got the bike.... or at least it looks very clean and has been lubed. I got some Muc-Off chain lube today to apply if needed anyway
However there is a faint white mark left on the yoke from the translucent alarm remote, can this be wiped off? (not too important as it can only be noticed with direct light on the yoke lol) |
| chris-red |
| Nufkamp |
 Nufkamp Traffic Copper
 Posted: 06:27 - 09 Sep 2009 Post subject: |
Also remember, WD40 is the best tar-spot remover there is for any vehicle. ____________________ As seen on Google Street View https://tinyurl.com/yfdvojc |
| Ichy |
 Ichy World Chat Champion
 Posted: 07:38 - 09 Sep 2009 Post subject: |
White spirits is the best tar-spot remover there is for any vehicle.  |
| Paulington |
 Paulington World Chat Champion
 Posted: 08:08 - 09 Sep 2009 Post subject: |
Sulphuric acid most definitely the best tar-spot remover there is for any vehicle. . ____________________ "Four wheels move the body, two wheels move the soul."
CBT: 27/08/08. Theory: 04/09/09. Module 1: 16/09/09. Module 2: 01/10/09. |
| Nufkamp |
 Posted: 09:28 - 09 Sep 2009 Post subject: |
80 grit emery cloth is the best......... ____________________ As seen on Google Street View https://tinyurl.com/yfdvojc |
| Alexio |
| Timmeh |
 Timmeh World Chat Champion
 Posted: 11:45 - 09 Sep 2009 Post subject: |
A plasma cutter is most definitely the best tar-spot remover there is for any vehicle. . ____________________ GSXR400 x2 | '94 RVF400 | '93 TZR125 4DL (again)
20:48:18 Temeluchus: comp you hunk of smouldering homos3x you |
| Finglonga |
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
| chris-red |
 Posted: 17:29 - 09 Sep 2009 Post subject: |
| Alexio |
The last post was made 16 years, 361 days ago. Instead of replying here, would creating a new thread be more useful? |
