WD40
That-Kid-O
PostPosted: 22:08 - 08 Sep 2009    Post subject: WD40 Reply with quote
Hello there all,
I have recently got a can of WD40 and was wondering if it would be OK to use on my exhaust pipe to get rid of sticky residue left over from where there was a sticker on it?
I was advised to use boiling water to remove the sticker before but because it is a central pipe running under the seat that was awkward.
Another of my questions is that, this being my first "bike" I went out and got some Muc-Off chain lube and was curious on how often to lube the chain and also if any preparations were necessary.
Thanks to all who has taken time to read and I have used Google to find answers but I was out of luck.
Finglonga
PostPosted: 22:53 - 08 Sep 2009    Post subject: Reply with quote
Yes ok to use WD40 as long as the end can isn't titanium otherwise it will stain it.
Lube when it needs it, as in the chain looks dry. I just used to spray my lube on, but some wash the chain first.
Andy Sez....
F.Y.Y.F.F.
PostPosted: 22:54 - 08 Sep 2009    Post subject: Reply with quote
Yes, WD40 would be ideal to remove sticky residue from your exhaust. If you don't wash the WD40 off afterwards, it'll smoke a bit next time you start it as the WD40 burns off.
If the chain is very crudded up with gritty muck, it would be an idea to clean it off or it'll wear the chain like grinding paste. More of an issue in winter when there's grit on the roads (Your can of WD40 would come in handy here, or I use paraffin which is cheaper, I use an old nail brush after the muck is loosened).
If the chain looks dry, it'll need a lube. Generally every 3-400 miles, more frequently if the weather is bad (water tends to blast the lube off).
Check the chain tension and adjust if necessary when you lube it. Check the tension at the tight spot on the chain (find the tight spot by wiggling the chain as you rotate the wheel, it'll be tighter in one place than in the others unless it is brand new).
That-Kid-O
PostPosted: 23:02 - 08 Sep 2009    Post subject: Reply with quote
Finglonga, it is a Akrapovic end can and I didnt buy it so don't know if it is titanium, how can I find out?
And Stinkwheel thanks for the info.
That-Kid-O
PostPosted: 00:40 - 09 Sep 2009    Post subject: Reply with quote
And also, is there any way to recover the top yoke if for example a alarm remote left a faint area looking whitened compared to the rest of the yoke (black)?
Alexio
PostPosted: 00:44 - 09 Sep 2009    Post subject: Reply with quote
You should also bear in mind that if your exhaust is very cold it would be a very bad idea, depending on which exhaust you have (and what it's made out of), to pour boiling hot water over it. A sudden change of temperature like that could (in theory) seriously damage or crack parts of it, or so I've been told.
WD40 all the way though Thumbs Up
PostPosted: 01:28 - 09 Sep 2009    Post subject: Reply with quote
If it's a Akrapovic and it's silver in colour it's Titainiun if it's black it's Carbon.
To sort your top yoke out easiest is to get a cover
https://cgi.ebay.co.uk/CARBON-LOOK-TOP-YOKE-COVER-FIT-HONDA-CBR-VFR-VTR-HORNET_W0QQitemZ120462252533QQcmdZViewItemQQptZUK_Motorcycle_Parts?hash=item1c0c1c19f5&_trksid=p3286.c0.m14
Something Like that, You bike is a CBR right
Alexio, if you think pooring 100 degree water onto metal that makes up a bike exhaust will damage it you are clueless. A Titianium exhaust can will not be damaged by hot water Laughing
WD40 will be fine.
Oh And Kid-o Grease that Gimbo Thumbs Up
That-Kid-O
PostPosted: 01:55 - 09 Sep 2009    Post subject: Reply with quote
I have just removed the alarm remote from the ignition key and added it to my main set of keys. I will leave the bikes key on its own as I dont want to cover the yoke...
I was just told WD 40 will stain the titanium can.... Then someone said WD40 all the way, what do I do... use it?
And the gimbo (presumably the chain?) I think has been replaced before I got the bike.... or at least it looks very clean and has been lubed. I got some Muc-Off chain lube today to apply if needed anyway Wink
However there is a faint white mark left on the yoke from the translucent alarm remote, can this be wiped off? (not too important as it can only be noticed with direct light on the yoke lol)
PostPosted: 04:50 - 09 Sep 2009    Post subject: Reply with quote
WD40 hasn't stained my can, if you are worried used petrol or white spirit.
Chances are the faint mark is where the alarm fob rubbed off the paint slightly. I have a few marks on my yoke too.
Nufkamp
PostPosted: 06:27 - 09 Sep 2009    Post subject: Reply with quote
Also remember, WD40 is the best tar-spot remover there is for any vehicle.
As seen on Google Street View https://tinyurl.com/yfdvojc
Ichy
PostPosted: 07:38 - 09 Sep 2009    Post subject: Reply with quote
White spirits is the best tar-spot remover there is for any vehicle. Wink
Paulington
PostPosted: 08:08 - 09 Sep 2009    Post subject: Reply with quote
Sulphuric acid most definitely the best tar-spot remover there is for any vehicle. Wink.
Nufkamp
PostPosted: 09:28 - 09 Sep 2009    Post subject: Reply with quote
80 grit emery cloth is the best.........
Alexio
PostPosted: 11:35 - 09 Sep 2009    Post subject: Reply with quote
I said nothing of the sort Razz I said depending on what it's made out of, I wouldn't have thought it would damage Titanium now that I know that's what it is. Something like thin aluminium however is much more likely to fit my scenario. Maybe I just needed to read the OP more carefully.
Timmeh
PostPosted: 11:45 - 09 Sep 2009    Post subject: Reply with quote
A plasma cutter is most definitely the best tar-spot remover there is for any vehicle. Wink.
Finglonga
PostPosted: 12:33 - 09 Sep 2009    Post subject: Reply with quote
Stained my Ti can with a bit of overspray from WD40, luckily on the inside so didn't matter as much, but the guy who bought it off me noticed.
Andy Sez....
F.Y.Y.F.F.
PostPosted: 15:54 - 09 Sep 2009    Post subject: Reply with quote
I've used WD40 on Ti cans before without it staining. Confused
Strange.
PostPosted: 17:29 - 09 Sep 2009    Post subject: Reply with quote
Never head of an ally exhaust... never heard of ally disolving in hot water either. Laughing
Alexio
PostPosted: 17:50 - 09 Sep 2009    Post subject: Reply with quote
chris-red wrote:
Never head of an ally exhaust... never heard of ally dissolving in hot water either. Laughing
I think you'll find I said cracking Wink and true.... I could be thinking about an engine with it's fins for air cooling.... Basically I was told if my engine was hot (and I think there's aluminium on my engine) never to pour water on it to get it cool down and vice versa. Sudden temperature changes very bad for certain types of metal.
The last post was made 16 years, 362 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.77 - MySQL Queries: 13 - Page Size: 108.54 Kb
