| lau |
 lau Two Stroke Sniffer
| Barry_M2 |
 Barry_M2 World Chat Champion
 Posted: 14:30 - 17 Sep 2009 Post subject: |
If you are doing it for the first time and your a novice, then I'd say half an hour.
Just take your time and have the manual handy if possible, and follow step by step, its the best way to learn.
Maybe someone round your area could lend a hand?
 ____________________ ZXR750R (M2) - For the road.
CBR1000 RR4 - For the track.
https://www.bikechatforums.com/profile.php?mode=viewprofile&u=4332 |
 Posted: 15:00 - 17 Sep 2009 Post subject: |
Piece of piss. Drain the oil. Undo the clutch cable. Take the cover bolts out. Remove the cover (may need a tap with a mallet to loosen it). Remove the five bolts with springs under holding the clutch together. Take the old plates out, put the new ones in, bolt it all up again (roughly 7.5ft/lb on the clutch bolts). Refill with oil.
The longest part is scraping the old gasket off the cover before you re-fit it with the new one.
EDIT: Soak the plates in oil overnight before fitting. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| lau |
| Barry_M2 |
 Posted: 15:33 - 17 Sep 2009 Post subject: |
| temeluchus |
| ZRX61 |
 ZRX61 Victor Meldrew
| binge |
 binge Emo Kiddy
The last post was made 16 years, 358 days ago. Instead of replying here, would creating a new thread be more useful? |
