Replacing clutch plates
lau
PostPosted: 14:21 - 17 Sep 2009    Post subject: Replacing clutch plates Reply with quote
Hey just wondered if I can pick some brains about how easy it would be to change the clutch plates in an er5? (i have very little experience with fixing anything bike related but plan to do what i can!)
I've youtube'd a million and one video's that have them whipped out and replaced in minutes but just wondered how long it realistically takes and if theres any tools I'll need t get?
I've got a spare gasket in case it needs changing and the plates and some oil.
One of the local garages her can do it for around £70 plus parts, is it worth getting them to do it?
Cheers any advice you have.
Laura
Barry_M2
PostPosted: 14:30 - 17 Sep 2009    Post subject: Reply with quote
If you are doing it for the first time and your a novice, then I'd say half an hour.
Just take your time and have the manual handy if possible, and follow step by step, its the best way to learn.
Maybe someone round your area could lend a hand?
ZXR750R (M2) - For the road.
CBR1000 RR4 - For the track.
PostPosted: 15:00 - 17 Sep 2009    Post subject: Reply with quote
Piece of piss. Drain the oil. Undo the clutch cable. Take the cover bolts out. Remove the cover (may need a tap with a mallet to loosen it). Remove the five bolts with springs under holding the clutch together. Take the old plates out, put the new ones in, bolt it all up again (roughly 7.5ft/lb on the clutch bolts). Refill with oil.
The longest part is scraping the old gasket off the cover before you re-fit it with the new one.
EDIT: Soak the plates in oil overnight before fitting.
lau
PostPosted: 15:12 - 17 Sep 2009    Post subject: Reply with quote
Brilliant thanks for the advice, hoping it would be fairly straight forward!
Barry_M2
PostPosted: 15:33 - 17 Sep 2009    Post subject: Reply with quote
No, just need to dip them as you fit them . Soaking then does nothing more then dipping them prior to fitting as the plates dont 'soak' anything up into them. If they did they would fall apart. Thumbs Up
But, if 'soaking' makes you feel better, each to their own. Wink Thumbs Up
temeluchus
PostPosted: 15:53 - 17 Sep 2009    Post subject: Reply with quote
It can be done on some bikes, with the bike on the sidestand, without draining the oil.
PostPosted: 16:09 - 17 Sep 2009    Post subject: Reply with quote
Usually says to soak them on the packet. Many clutch friction plates are cork based and a bit porus.
ZRX61
Victor Meldrew
PostPosted: 23:12 - 18 Sep 2009    Post subject: Reply with quote
No need to drain the oil on most Kaw's if the bike is on the sidestand Wink
Single side razorblades to remove old gasket, apparently Kaw use some hellish adhesive in their gaskets...
binge
Emo Kiddy
PostPosted: 23:36 - 18 Sep 2009    Post subject: Reply with quote
I never used to drain the oil out of my CBR400 when I had the clutch cover off.
Just roll the bike onto a long plank of wood. And put it on the side stand. The stand being on the ground, And the bike being up on a 1" thick piece of wood. Gave the bike that extra little bit of lean.
Leave it for half hour or so, All the oil will then run down into the sump, And you can take the cover off without any spillage.
Ben
The last post was made 16 years, 358 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 62.53 Kb
