Taking of Generator Cover NSR 125
RichP
PostPosted: 21:48 - 19 Sep 2009    Post subject: Taking of Generator Cover NSR 125 Reply with quote
Hey guys,
Engine now off and taking it all apart to scavenge some bits for my bottom end.
I've taken all the bolts holding the generator cover out (at least the ones visible looking AT the cover.
Its obviously decided to be stubborn, are there any less obvious fasteners that i might have missed?
If not i guess its time for a bit of the old Ultra Violent!
Cheers!
RichP
PostPosted: 00:00 - 20 Sep 2009    Post subject: Reply with quote
Sorted!
(I feel like a right ignorant twat with all my workshop posts!)
Went for bit of controlled brutality.
baldy
PostPosted: 00:41 - 20 Sep 2009    Post subject: Reply with quote
Sometimes the gasket can stick solid making it feel like there's bolts holding it on. A few wacks with a rubber hammer normally does it.
How's the rebuild going so far?
One day i will rule the world, just not today.
RichP
PostPosted: 01:07 - 20 Sep 2009    Post subject: Reply with quote
Ok apart from a seized solid bolt whilst dropping the engine, in the end i had to drop the kickstand assembly out as well, even out the bike i couldn't remove the bolt so i got another bracket from the breakers.
Currently swapping bits across, also gonna clean up bike before the engine goes in.
I'm doing a thread here:
https://www.bikechatforums.com/viewtopic.php?t=182791
baldy
PostPosted: 01:32 - 20 Sep 2009    Post subject: Reply with quote
I had the same problem removing the engine. I used a massive spanner and broke the mount off the frame. I still have one in the garage. You could have had it if you wanted.
Did you tighten everything up? Those silly nuts that need a special socket are a ball ache. Also, did you check the balancer shaft for alignment? I think i timed it properly but i can't be sure.
RichP
PostPosted: 02:15 - 20 Sep 2009    Post subject: Reply with quote
All ive done so far is swap over the starter motor, haven't checked the balancer for alignment, didn't know you had to! Or how!
Back to the workshop manual! Very Happy
Can't do the clutch etc till i've swapped my oilpump.
The last post was made 16 years, 359 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 46.41 Kb
