Trouble changing a chain - Any ideas
PostPosted: 19:14 - 26 Sep 2009    Post subject: Trouble changing a chain - Any ideas Reply with quote
Went to change the chain on Charlottes Triumph Thunderbird today. The nut on the front sprocket won't come off.
Not unusual but this one really won't come off!
I have an electric impact wrench and it hasn't had any effect. The socket has dented the nut but not undone it at all.
Unfortunatly it has spoked wheels and so I can't really chock the wheel against the swinging arm. With the engine in gear and Charlotte standing on the rear brake lever the wheel can still be turned (although it too enough force to be visably bending the breaker bar).
Any ideas? Only think I can think to try is to put in a spare cast wheel from another bike instead and then chock that against the swinging arm.
PostPosted: 19:22 - 26 Sep 2009    Post subject: Re: Trouble changing a chain - Any ideas Reply with quote
Are the brake discs drilled or otherwise have holes in them?
binge
Emo Kiddy
PostPosted: 19:27 - 26 Sep 2009    Post subject: Reply with quote
Ride to a local garage and get a proper Impact Gun on the front nut.
Ben
Barry_M2
PostPosted: 19:30 - 26 Sep 2009    Post subject: Reply with quote
With the chain on, wedge a (large) piece of wood between the chain the rear sprocket. Then try the breaker bar again, but if your bending it then its probably not gonna budge!
Next thing I'd do is reach for the dremel and chop the nut off. Thumbs Up
ZXR750R (M2) - For the road.
CBR1000 RR4 - For the track.
PostPosted: 19:38 - 26 Sep 2009    Post subject: Reply with quote
Unfortunatly it is pretty much a proper one. As I said it is denting the nut.
Disk does have holes but fairly sure any bolt would (at best) just shear off with the force required.
Robby
Dirty Old Man
PostPosted: 19:43 - 26 Sep 2009    Post subject: Reply with quote
Are you absolutely sure there isn't some kind of lock tab washer or similar hiding in there, or could the thread be in the other direction?
The Artist
PostPosted: 19:46 - 26 Sep 2009    Post subject: Reply with quote
Put breaker bar on it resting on the ground.
Start engine, put in 1st and release clutch. I have done this before with no ill effect apart from me being nervous the bike would flip over cue me getting knocked out by a flailing stick of steel Laughing
just remembered this was on a bike with sprocket on the other side Embarassed
Could try it holding the breaker bar and someone else controlling the bike.
BenR
PostPosted: 19:53 - 26 Sep 2009    Post subject: Reply with quote
Are you sure you're going the right way? Sounds stupid I know but are you sure it isn't a reverse thread?
PostPosted: 20:03 - 26 Sep 2009    Post subject: Reply with quote
I am sure on the thread direction. You can just see the end of the thread. There is a tab washer and I have peeled it back. And double checked several times that there isn't another tab!
Clutch slave cylinder is on the sprocket cover and no way I want my leg near the breaker bar there without any way to disconnect drive. Added to which it would tighten the nut.
binge
Emo Kiddy
PostPosted: 20:15 - 26 Sep 2009    Post subject: Reply with quote
As a last resort, Heating the nut up would almost guarantee it undoing.
You'd need a replacement up though really.
Ben
PostPosted: 20:18 - 26 Sep 2009    Post subject: Reply with quote
Already tried that. And don't dare use more heat otherwise I willl destroy the seal on the output shaft.
Bendy
Mrs Sensible
PostPosted: 20:38 - 26 Sep 2009    Post subject: Reply with quote
I used a lot of freeze n release on the seized CBR nut, that and 4 battery charges of the impact wrench finally got it off.
PostPosted: 20:46 - 26 Sep 2009    Post subject: Reply with quote
Bendy wrote:
I used a lot of freeze n release.
Thats worth a try. Have to see if I can find some tomorrow.
PostPosted: 21:13 - 26 Sep 2009    Post subject: Reply with quote
My air wrench is significantly 'better' than the electric one (electric 210NM or so and air 485NM or so)... as can be seen by Bendy needing four charges worth, it seems Smile.
Despite the denting the nut thing, I suspect a decent air one would help.
PostPosted: 21:16 - 26 Sep 2009    Post subject: Reply with quote
They sell it in Halfords.
Give it to the count of five or you'll give it a damned good thrashing.
Also, big pneumatic air wrench, let the shaft spin but keep holding it on. The big pnumatic ones are.. well.. bigger. Heavier flywheel, higher hit rate.
Maybe try hitting each of the flats of the nut with a hammer and punch if you can get an angle on it to try and break it loose.
Mate of mine had a big, 3/4" windy gun on the crank bolt of his renault 5 for five minutes solid before it finally undid. Couldn't feel his fingers for the rest of the day.
Worst case, split the nut.
Or, you might be able to lock the shaft stationary using the old chain by variation of a technique used by cyclists to tighten/undo the rear sprockets on fixed gear track bikes called "rotofix".
LINK
jay12329
Dr. Evil
PostPosted: 21:18 - 26 Sep 2009    Post subject: Reply with quote
As bend says several treatments with freeze and release and a long time on the impact driver. The SV took a bit of work to get off. But we got there with a couple of batteries work of bashing!
Are you using an impact socket or a normal one? I dinted the nut on the sv using a normal socket but a (black halfrauds) impact one was better.
HTH
J
jay12329
Dr. Evil
PostPosted: 21:21 - 26 Sep 2009    Post subject: Reply with quote
Oh and Kickstart asking for help in the workshop?!!?? I'm in a parallel dimension or something!
J
PostPosted: 21:23 - 26 Sep 2009    Post subject: Reply with quote
I'd go for the 'fit a cast wheel and put a lump of wood through the spokes' option, and use a long bar & impact socket. Last resort is cut the side off the nut right alongside the shaft.
My air impact wrench will manage 450lb/ft for undoing things. The electric one will undo things that the air one won't, despite in theory being a fair bit weaker.
Splitting the nut is a last resort.
I am using a proper impact socket.
PostPosted: 21:34 - 26 Sep 2009    Post subject: Reply with quote
CHR15 wrote:
if its starting to damage the nut, id buy a wall drive socket.
The damage is visible ~3mm from the corners of the nut.
CHR15 wrote:
450 lb/ft isnt much, at work weve got a 1" 2000 lb/ft gun now that DOES undo anything.
Suspect that might need a rather better compressor than I have. Mine will only manage 120psi or so.
PostPosted: 21:44 - 26 Sep 2009    Post subject: Reply with quote
I'd be interested to hear if the rotafix technique works on motorbikes too.
They get a good hold, I've heard of people stripping the threads on their hubs before by overenthusiastic rotafixing (and it's a 1.37" x 24tpi thread, not insubstantial).
Don't see many tools that need more than that.
As an idea... https://www.alibaba.com/product-gs/204987548/impact_wrench.html
Tend to have a lot higher air-consumption, however.
Decent wall-drive sockets should distribute the force across a wider area, rather than dig in.
Incidentally, if anyone's got suggestions for reasonably priced wall-drive sockets, love to hear them.
Oh and CHR15, I envy your big tool!.... Confused
teabag
PostPosted: 21:49 - 26 Sep 2009    Post subject: Reply with quote
One little point, if trying to lock the back wheel by putting it in gear, use top gear not 1st.
NS125R = 2 years > GSX600F = 7 years > XR125L = 3.5 years > SV650S........and a Citroen Synergie HDI for the kids.
trisers
PostPosted: 22:21 - 26 Sep 2009    Post subject: Reply with quote
Just wondering why? Is it an unusual/expensive nut? i've used a splitter on occasion and wondered why i even bothered trying to undo those particular nuts in the first place....
Clive
PostPosted: 22:34 - 26 Sep 2009    Post subject: Reply with quote
Only way I can do it would be with a Dremel and it would be too easy to damage the output shaft. While I don't have a large enough nut splitter, even if I did I don't think there is enough clearance around the nut to use one.
The last post was made 16 years, 235 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 2.94 - MySQL Queries: 13 - Page Size: 134.57 Kb
