 Posted: 19:14 - 26 Sep 2009 Post subject: Trouble changing a chain - Any ideas |
Went to change the chain on Charlottes Triumph Thunderbird today. The nut on the front sprocket won't come off.
Not unusual but this one really won't come off!
I have an electric impact wrench and it hasn't had any effect. The socket has dented the nut but not undone it at all.
Unfortunatly it has spoked wheels and so I can't really chock the wheel against the swinging arm. With the engine in gear and Charlotte standing on the rear brake lever the wheel can still be turned (although it too enough force to be visably bending the breaker bar).
Any ideas? Only think I can think to try is to put in a spare cast wheel from another bike instead and then chock that against the swinging arm.
| MarJay |
 MarJay But it's British!
| binge |
 binge Emo Kiddy
| Barry_M2 |
 Barry_M2 World Chat Champion
 Posted: 19:30 - 26 Sep 2009 Post subject: |
With the chain on, wedge a (large) piece of wood between the chain the rear sprocket. Then try the breaker bar again, but if your bending it then its probably not gonna budge!
Next thing I'd do is reach for the dremel and chop the nut off.  ____________________ ZXR750R (M2) - For the road.
CBR1000 RR4 - For the track.
https://www.bikechatforums.com/profile.php?mode=viewprofile&u=4332 |
| Robby |
 Robby Dirty Old Man
| The Artist |
 The Artist Super Spammer
 Posted: 19:46 - 26 Sep 2009 Post subject: |
Put breaker bar on it resting on the ground.
Start engine, put in 1st and release clutch. I have done this before with no ill effect apart from me being nervous the bike would flip over cue me getting knocked out by a flailing stick of steel
just remembered this was on a bike with sprocket on the other side
Could try it holding the breaker bar and someone else controlling the bike. |
| BenR |
 BenR World Chat Champion
 Posted: 20:03 - 26 Sep 2009 Post subject: |
I am sure on the thread direction. You can just see the end of the thread. There is a tab washer and I have peeled it back. And double checked several times that there isn't another tab!
Clutch slave cylinder is on the sprocket cover and no way I want my leg near the breaker bar there without any way to disconnect drive. Added to which it would tighten the nut.
| binge |
 binge Emo Kiddy
| Bendy |
 Bendy Mrs Sensible
| G |
 G The Voice of Reason
 Posted: 21:13 - 26 Sep 2009 Post subject: |
My air wrench is significantly 'better' than the electric one (electric 210NM or so and air 485NM or so)... as can be seen by Bendy needing four charges worth, it seems .
Despite the denting the nut thing, I suspect a decent air one would help. |
| jay12329 |
 jay12329 Dr. Evil
| jay12329 |
 jay12329 Dr. Evil
 Posted: 21:23 - 26 Sep 2009 Post subject: |
I'd go for the 'fit a cast wheel and put a lump of wood through the spokes' option, and use a long bar & impact socket. Last resort is cut the side off the nut right alongside the shaft. ____________________ a.k.a 'Geri'
 Posted: 21:44 - 26 Sep 2009 Post subject: |
I'd be interested to hear if the rotafix technique works on motorbikes too.
They get a good hold, I've heard of people stripping the threads on their hubs before by overenthusiastic rotafixing (and it's a 1.37" x 24tpi thread, not insubstantial). ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| G |
| teabag |
 teabag Renault 5 Driver
| trisers |
 trisers Scooby Slapper
The last post was made 16 years, 236 days ago. Instead of replying here, would creating a new thread be more useful? |
