Stoopid spark plug question + locking nets....
funmonkee
PostPosted: 09:22 - 02 Oct 2009    Post subject: Stoopid spark plug question + locking nets.... Reply with quote
Is there anyway to tell if a spark plug is failing/getting old,dirty etc other than taking it out and checking Question What I'm looking for is a doo-daa that can attach to the plugs whilst they are still in the engine... and indicate if they are working or not (*)
</lazyBarstard>
Also, does anyone know what those security net things are called. They enclose say you lid and can be locked... Question
Karma
(*) I want to know when any of the 4 spark plugs on the Vmax are past there best...
**** Don't ride faster than your angel can fly Get this Free Space
The democratically elected Mod of the Scottish Section - The Peoples Choice[b]
Mr.Everready
PostPosted: 09:36 - 02 Oct 2009    Post subject: Reply with quote
My friend has a set of spark plug checkers, I think he got them from Aldi/Lidl. Check on the bay, there are some there too.
https://i.ebayimg.com/04/!BZuVv3!CGk~$(KGrHgoOKiQEjlLmVz3(BKoCm4L,cg~~_35.JPG
funmonkee
PostPosted: 10:51 - 02 Oct 2009    Post subject: Reply with quote
^^ that's almost what I'm looking for. If it could be permanently attached to the bike...that would be perfect Laughing
mr rip
PostPosted: 14:52 - 02 Oct 2009    Post subject: Reply with quote
try in a camping store for your locking net as backpackers use them to keep their stuff secure
never criticise a man until you've walked a mile in his shoes, then when the muck hits the fan you'll be a mile away & you'll have his shoes
PostPosted: 14:56 - 02 Oct 2009    Post subject: Reply with quote
Pacsafe?
https://www.millets.co.uk/product/104527.html
That is a small one but we have some that are a lot larger (will take a rucksack).
EDIT - Better link:-
https://www.pac-safe.com/www/index.php
virus
PostPosted: 14:59 - 02 Oct 2009    Post subject: Reply with quote
They dont test the spark plug, only the coil/ht leads.
John
own: 81 xs1100g...
PostPosted: 15:01 - 02 Oct 2009    Post subject: Reply with quote
As to plugs, I did a google for illuminated plug caps (used to see them, ones that flashed with the plug) but just found a load of neon plug leads.
However did see this:-
https://www.patentstorm.us/patents/5363046.html
ZRX61
Victor Meldrew
PostPosted: 16:01 - 02 Oct 2009    Post subject: Reply with quote
FFS, it takes mere seconds to pull a plug & check it... Rolling Eyes
funmonkee
PostPosted: 16:15 - 02 Oct 2009    Post subject: Reply with quote
@Kickstart,
Spot on; That's exactly what I was looking for pacsafe Thumbs Up And good find on the sparkplug tester.... Why not have a gadet that can check them as they working Thumbs Up
Yes, but you missed the point.. I am lazy...
Gawain
PostPosted: 07:16 - 03 Oct 2009    Post subject: Reply with quote
So you check all the plugs and find one bad, would you only replace that one? If your worried about plug condition change them all, far simpler, faster and lazyer than finding the information, buying the tool, testing, then replacing them all because they're old.
steven_191
PostPosted: 12:52 - 04 Oct 2009    Post subject: Reply with quote
wrap a piece or wire around the ht lead about ten times or so, then run into a small bulb or neon may work, then out of the bulb to the neutral.
when your coil pack fires 40,000 volts down the lead you get a magnetic field that induces a current through the wire wrapped around it. that will light up the bulb.
if the bulb doesnt light up, either theres no spark, no voltage, or the contraption you just made dont work Thumbs Up
robocog
PostPosted: 20:38 - 04 Oct 2009    Post subject: Reply with quote
https://cgi.ebay.co.uk/-4-Blue-Neon-Flashing--Spark-Plug-Caps_W0QQitemZ250397828824QQcmdZViewItem
Not sure if it could cause issues if you have an ECU controlled bike though as I doubt they will be supressed?
Regards
Rob
The last post was made 16 years, 316 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.22 - MySQL Queries: 13 - Page Size: 75.41 Kb
