Costs for Valve and Carb checks?
nasty
PostPosted: 20:58 - 09 Oct 2009    Post subject: Costs for Valve and Carb checks? Reply with quote
I'd like to get my valve clearances checked and carbs synch'd or should I say, need to!
I havn't got the kit to do this myself and don't think I'd be too confident doing this anyway Embarassed
What sort of money should I be expecting to pay to get this done by a garage on average (not dealer prices, Kawasaki Newcastle charge a fortune Sick )?
ZX6R F3
Thanks in advance Thumbs Up
ZX6R F3
The Tot
PostPosted: 21:13 - 09 Oct 2009    Post subject: Reply with quote
It's all labour. In my case, it was £220. That was carb balancing, valve check and I think spark plugs too + oil change. Depends where you go and how well you know the mechanics. Bike was a ZX6R F3
Never argue with autism
nasty
PostPosted: 21:19 - 09 Oct 2009    Post subject: Reply with quote
Cheers Titz, I didn't think it would be too cheap like Laughing
I'm fine with changing plugs, oil + filter changes etc but when it comes to engine internals I don't like to touch it Crying or Very sad
I'm gonna give a local garage a ring in the morning and see what he quotes me, his price for the last lot of work he did was good, £116 for new fork oil and seals, re-grease SHB's, re-grease throttle grip and lube cables and an MOT and that included the labour and VAT - in contrast, Kawasaki Newcastle wanted £175 just to do the fork oil and seals
ZX6R F3
tutton
PostPosted: 14:05 - 11 Oct 2009    Post subject: Reply with quote
Just to show some contrast i had a local shop do me forkseals and put in new oil for 25 quid
hmmmnz
PostPosted: 15:26 - 11 Oct 2009    Post subject: Reply with quote
it really is a very simple job, especially on the later model kawasaki's, the only bugger is having shims to hand..
take it to a small bike shop, rather that somewhere big,
and if you can all the fairings off and it ready to go, that'll drop the price,
i personally would be pissed off if it was more than 50quid to do valve clearances, its a half hour job
the humans are dead
I kick arse for the lord
PostPosted: 16:26 - 11 Oct 2009    Post subject: Reply with quote
Sorry to hijack, but is it really only about half hour job?
Im needing the same a OP, but on a GS500...was scared that it would be mega bucks
swiftb
PostPosted: 21:41 - 11 Oct 2009    Post subject: Reply with quote
I very much doubt you could do it in half an hour. If so id like to know exactly how hes doing it
hmmmnz
PostPosted: 00:03 - 12 Oct 2009    Post subject: Reply with quote
i did it on my zxr750 and that was the h1 model which required the cams to come out to change the shims, and i could do it in under half an hour, the zx6 and later zxr750s use a rocker arm under the cam which just slides to the side to allow easy access to the shims,
if a mecanic cant do it in half an hour then hes pissing about or fucken useless!!!(im only accounting for the valve clearance and change times, not taking off all the body work and what not)
the gs isn't too bad either, although it can be a bit of a piss about as you have to push the bucket down (with a special tool... or a screwdriver) which is under tension from the valve springs. to remove the shims, or you can remove the cams. but its far easier with the special curved tool, and a wee magnet,
there is a video on google videos for the gs500
the humans are dead
swiftb
PostPosted: 00:32 - 12 Oct 2009    Post subject: Reply with quote
I was pretty sure the shims are under the buckets on a zx6r therefore the cams need to come out. Thats after checking all the clearances and working out the difference in gaps etc. Locating the right shims etc etc. Reinstalling the cams and cct, Rechecking the clearances, Refitting the camcover, Airbox tank etc. Good hours graft (or more) there for someone who knows what there doing (and is doing it properly) Thinking
hmmmnz
PostPosted: 02:00 - 12 Oct 2009    Post subject: Reply with quote
it appears your right reguarding bucket over shim, obviously the 6's didnt benefit from the later model zx7rs system,
still that just makes it like the early zxr750,
and i managed to do my valve clearances in half an hour,
(as said not including taking all the shit off to get to the cams) the valve clearance and shim changes itself doesnt take that long to do.
i guess we are going to have to agree to disagree on this one,
as i don't current;y own a il4 i can't prove i can do it in that time.
Very Happy
the humans are dead
swiftb
PostPosted: 11:38 - 12 Oct 2009    Post subject: Reply with quote
But thats like saying you can run the 100metres in 9 seconds flat........but doesnt include the first 20metres or the last 20metres.
Or on the flip side saying you had sex for half an hour but not counting the 27 minutes of titty fondling Smile
Anyways, I wouldn't let you near my bike you gash bas*tard
Wink Thumbs Up
hmmmnz
PostPosted: 12:27 - 12 Oct 2009    Post subject: Reply with quote
Wink Thumbs Up
thats nothing like that at all,
doing the valve clearances is not. taking fairings off and removing the tank, its taking the rocker cover off,
then sliding a feeler guage under the cam 16 times,
then unbolting the tensionor, then unbolting the cams replace the shims that need to be replaced, then put cams back in,
its hardly a hard or particuly technical job,
and to be fair i wouldn't do any job for a smart arse know it all cock like yourself, so really you have nothing to worry about do you Middle Finger
the humans are dead
Barry_M2
PostPosted: 13:33 - 12 Oct 2009    Post subject: Reply with quote
As mentioned above, the longest part is removing the tank, airbox, cam cover etc... to get to them. Checking the clearances is pretty easy really, doesn't take long at all.
I did have a spreadsheet that calculated what your clearances should be and what size shims to put in if they did need changing. I'll see if I can dig it out, it saves you loads of time! (might even have got if from on here?!)...
As I dont ride my bike over winter, I tend to remove the engine to do my clearances and give the motor a thorough check over and clean.
ZXR750R (M2) - For the road.
CBR1000 RR4 - For the track.
the grim reaper
PostPosted: 15:11 - 12 Oct 2009    Post subject: Reply with quote
To do a check of the valve clearances shouldn't be any more than an hour from any dealership, bearing in mind that almost all dealers charge a minimum of an hours labour. I can do a valve clearance check and carb balance in under an hour, assuming the engine is already hot.
The ZX6R exhaust and inlet shims are the same diameter too, so if you are doing your own, you can swap shims around, assuming that there are some that are the suitable thickness.
Grim
Barry_M2
PostPosted: 16:05 - 12 Oct 2009    Post subject: Reply with quote
Grim
Valve clearances should be done cold, even if it states a 'hot' clearance value too.
Or do you just mean the carb ballancing when hot? Wink
The last post was made 16 years, 312 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.87 - MySQL Queries: 13 - Page Size: 91.4 Kb
