help with fitting car door . it won't shut
dransy
PostPosted: 14:29 - 15 Oct 2009    Post subject: help with fitting car door . it won't shut Reply with quote
yesterday I fitted a new passenger door on the misses rover metro . I got the door on but the things won't shut . its catching on the back end where it locks . how can I adjust it it seriously is about 3mm out also it needs lifting up a tiny little bit .
so yeah how do I adjust it ! thanks
Bikeless
PostPosted: 16:31 - 15 Oct 2009    Post subject: Reply with quote
Pics of the hinges?
Finglonga
PostPosted: 17:28 - 15 Oct 2009    Post subject: Reply with quote
Is the door fitting ok around the edges? If so adjust the position of the slam plate.
Andy Sez....
F.Y.Y.F.F.
PostPosted: 17:30 - 15 Oct 2009    Post subject: Reply with quote
https://www.tool-net.co.uk/data/tools/grga9020kd.jpg
Angle grinders fix everything. Thumbs Up
Carl_steveo
PostPosted: 19:04 - 15 Oct 2009    Post subject: Reply with quote
Have you put the correct door on the correct side lmfao ???
Current: Honda Nsr 125
Live: Sunderland
PostPosted: 19:06 - 15 Oct 2009    Post subject: Reply with quote
I have two possible solutions.
A. Kick it shut.
B. In the unlikely event that A doesn't work. Kick it harder.
tutton
PostPosted: 20:21 - 15 Oct 2009    Post subject: Reply with quote
Slightly tap the mounts on the door up a few mm before rebolting back into the car mounting?
Ariel Badger
PostPosted: 20:27 - 15 Oct 2009    Post subject: Reply with quote
You do not need doors for the Mot but will fail if any fitted do not close.
Just take it off and bung it away.
plugger147
PostPosted: 20:39 - 15 Oct 2009    Post subject: Reply with quote
Are they bolt on doors or did you have to knock the pin out of the hinge?
Tristan the wrote: just whipped off my trousers to find a big bruise on my arse, caused by matt rear ending me...
Valentino Mossy
PostPosted: 18:20 - 16 Oct 2009    Post subject: Reply with quote
Dont know if its the same ,but on a beetle the bottom hinge mount usally becomes a pain after a few years and causes the door to drop down and in when you open it. So new hinges and door bolts wont do bugger all.... new mount point need, or lots of epoxy shite to force it out !
Hold the door just slightly open and see if it drops away.
ZRX61
Victor Meldrew
PostPosted: 23:28 - 16 Oct 2009    Post subject: Reply with quote
If the hinges are bolted one:
Adjust them, it's fairly straight forward IF you know WTF you are doing
If they are welded on:
Tough titty.
chrisjacks
PostPosted: 00:40 - 17 Oct 2009    Post subject: Reply with quote
so its legal to drive round with no doors at all?
Finglonga
PostPosted: 15:17 - 17 Oct 2009    Post subject: Reply with quote
Got none on my bike. Mr. Green
Andy Sez....
F.Y.Y.F.F.
The last post was made 16 years, 345 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 79.71 Kb
