ATI graphic card problems
TUG
PostPosted: 20:15 - 21 Oct 2009    Post subject: ATI graphic card problems Reply with quote
Right, getting pissed off now, theres something up with this card!
When i first played on CS:CZ and everything was fine and i had no problems, then all of a sudden, mouse lag!
Now recently my ATItool program is telling me i'm getting core: 506.25mhz and mem: 594mhz and it should be core 600 something, mem 999mhz.
It says on the ATI site i need a 30+amp PSU and this one is 22amp, I'm getting pretty paranoid its power thats lacking and causing all my problems, but could it be corrupt drivers?
Help me out please?
Haz ER-5, innit!
SoND
PostPosted: 23:16 - 21 Oct 2009    Post subject: Reply with quote
Download latest drivers
Uninstall current ones
Boot up in safemode and run Driver Sweeper
Reboot and install new drivers
If there's no difference then you've ruled out corrupt drivers.
Makes sense that it's the psu, as soon as the card is loaded enough the clock speeds drop to what the psu can handle.
TUG
PostPosted: 23:29 - 21 Oct 2009    Post subject: Reply with quote
Best buy a psu again then and research them propperly, i'll try the driver cleaner thing next time, bit late to be fettlin now. Cheers SoND
Haz ER-5, innit!
mistergixer
PostPosted: 08:22 - 22 Oct 2009    Post subject: Reply with quote
I've got a 700W Storm PSU sitting here, used it once for a bit of troubleshooting, still in the box, your for £15 + p/p if you want it.
Space Monkey #7
TUG
PostPosted: 20:30 - 22 Oct 2009    Post subject: Reply with quote
Can you link me to some tech info on that psu gixer? im very interested.
Haz ER-5, innit!
mistergixer
PostPosted: 22:53 - 22 Oct 2009    Post subject: Reply with quote
Review here
In brief:
    Specs:
    Triple + 12V Output Rails
    Advanced Double Forward Circuit and Double-Layer PCB
    Active Power Factor Correction
    Super High Efficiency Maximum 84%
    Patented Design: Real-Time Power Watcher
    Ultimate Balance Between Cooling and Noise Level
    Honey Comb Structure for Outstanding Ventilation
    Additional 4 pin Connector with Thermal Control Function for case fan
    2 Ball Bearing / Long life 12cm fan
    Anti Vibration Pad
    All Output Cables with Nylon Sleeving
    Gold plated Terminal
    Flexible Connector and System Design
    Patented Easy Swap Connector
    Dual PCI-Express Power Connectors Fully Supports SLI & Cross-Fire systems
    1 x 20+4 Main power (Standard ATX)
    1 x CPU Connector (4+4) pin
    2 x 6 pin PCI-E VGA
    8 x 4 pin Peripheral Power Connector
    2 x Case Fan Connector
    2 x 4 pin Floppy Drive Power Connector
    1 x Case Fan Speed Monitor
    4 x S-ATA
Space Monkey #7
bazza
PostPosted: 23:34 - 22 Oct 2009    Post subject: Re: ATI graphic card problems Reply with quote
Help me out please?
I've just gone through these hoops with an nVidia card. Voltages, amps and rails and a lot of confusion.
The spec for the card recommended 12V @ 25A, but neglected to mention I needed 2 x 12V rails to plug into the 2 x 6-pin PCI-E VGA connectors on the card. Result = 1 x £70 power supply (with 2 x 12V @ 19A rails) replaced with one of suitable spec.
So, what card do you have and does 30A+ mean per rail or combined?
This is the part of the replacement PSU you should be looking at - the spec label on the side:
https://www.ocztechnology.com/images/awards/mxsp_wattage_charts.jpg
The first has 2 x 12V @ 18A rails, the others have 2 x 12V @ 25A
I ended up with the 600W one in the middle.
TUG
PostPosted: 19:03 - 24 Oct 2009    Post subject: Reply with quote
It only has one power suply to plug to, Mister gixer, When can you send? Thumbs Up Wink
EDIT: Looks like the 30A on your PSU mister gixer is on the 5v rail i need a 30A 12V rail Crying or Very sad
EDIT2: x1950xtx bazza
Haz ER-5, innit!
SoND
PostPosted: 12:32 - 25 Oct 2009    Post subject: Reply with quote
The power doesn't have to all come from one rail. Multiple lower powered rails that total over your required amps is sufficient. Each 6 pin connector does not have a dedicated rail to it.
TUG
PostPosted: 13:13 - 25 Oct 2009    Post subject: Reply with quote
how does that work? This is extremely confusing now, ATI says i need a 12v 30A 500w PSU to power the card that is the system requirement i have a 500w psu that produces 22A max
Haz ER-5, innit!
SoND
PostPosted: 14:46 - 25 Oct 2009    Post subject: Reply with quote
Has your supply got one or multiple rails? (+12v1 +12v2 etc?)
mistergixers supply is plenty and more for your card. If it doesn't work for you I'll take it. Mr. Green
bazza
PostPosted: 14:47 - 25 Oct 2009    Post subject: Reply with quote
The way I understood it is that you take the combined 12V rail output to be (roughly) the rating, e.g.
1 x 12V @ 22A = 22A psu
2 x 12V @ 18A = 36A psu
2 x 12V @ 25A = 50A psu
In the PSU world, you do get what you pay for, so a branded 500W model is likely to be better than a 750W unbranded chinese one.
To pass the time, feed your system specs into this PSU calculator:
https://www.extreme.outervision.com/psucalculatorlite.jsp
and see what it suggests.
TUG
PostPosted: 15:48 - 25 Oct 2009    Post subject: Reply with quote
couldnt really get to grips with that bazza im really a novice at this sort of thing, SOND well my psu is 5v = 24a 3.3v = 24a 12V1=22a 12v2=22a -12v=0.8a 55vsb=2.5a.
What am i missing?
Haz ER-5, innit!
TUG
PostPosted: 15:51 - 25 Oct 2009    Post subject: Reply with quote
System Requirements
* PCI Express™ based PC is required with one x16 lane graphics slot available on the motherboard and one additional adjacent expansion slot.
* Connection to the system power supply is required:
o 450-Watt power supply or greater, 30 Amps on 12 volt rail recommended (assumes fully loaded system)
* For CrossFire™: 550 watt power supply or greater, 38 Amps on 12 volt rail
* 512MB of system memory
* Installation software requires CD-ROM drive
* DVD playback requires DVD drive and decoder software (not included)
Haz ER-5, innit!
SoND
PostPosted: 17:40 - 25 Oct 2009    Post subject: Reply with quote
What am i missing?
That's not looking good. That psu should easily power that card.
How old is all your hardware?
Are your clock speeds permanently fixed at the lower speeds now or do they boot up normally then drop after a while?
TUG
PostPosted: 18:38 - 25 Oct 2009    Post subject: Reply with quote
Its like i've bought a female card, It stays fixed once booted so no drops.
Boots up either on full or like half, once i booted the pc up and the screen wouldnt show anything.
Driver issue then? I'm running usb mouse, external soundcard, wireless connector, urm, 2 hdds, dvd rw/cd rw(1 drive) its a 3-4yr old pc running AMD 3700 939 socket 3 gig ram, xp sp3 home
cant think of anything else, must be driver issue then? i dunno
Is there anyway i could of connected the PSU up wrong like mixed rails or something?
Haz ER-5, innit!
mistergixer
PostPosted: 20:05 - 25 Oct 2009    Post subject: Reply with quote
Checked your cables? I reckon you've got a knackered/not plugged in properly video cable.
Space Monkey #7
TUG
PostPosted: 00:40 - 26 Oct 2009    Post subject: Reply with quote
its plugged into the pci-e slot as much as possible and all the other cables are clipped into the mobo and the pci-e 6 cable is plugged in perficly i'll pull it apart after work tommorow.
Haz ER-5, innit!
TUG
PostPosted: 00:49 - 26 Oct 2009    Post subject: Reply with quote
But this though, 30 Amps on 12 volt rail recommended i think it means 1 12v rail needed? surely? Sad
Haz ER-5, innit!
TUG
PostPosted: 19:31 - 24 Nov 2009    Post subject: Reply with quote
Card failed to boot up in full mode 3 times, twice in complete dead pixel mode. help?
Haz ER-5, innit!
TUG
PostPosted: 21:49 - 04 Apr 2010    Post subject: Reply with quote
Right, i've reformatted my pc like suggested by HETZ and tbh, so far, i've not had anyproblems at all, not a single dead pixel, no failures, even counter strike runs like a dream.
So, HETZ i love you man. x
Haz ER-5, innit!
Welshd1k
PostPosted: 23:55 - 04 Apr 2010    Post subject: Reply with quote
you do realise ati cards downclock themselves when not in use as do alot of Nvidia cards to save power. as for the whoel 30A neede i wouldnt worry to much. ran a 8800gtx of a 350w psu with 12A for 2 years.
i would say buy a decent branded PSU but it would be worth more than your pc and seem rather poitnless
PostPosted: 09:12 - 05 Apr 2010    Post subject: Reply with quote
im running a 9500GT on 450W, its below the current min specs for the card, but ive never had it fail and its definitely been stressed.
If you are on CS, let me know your steam id Wink
SoND
PostPosted: 13:03 - 05 Apr 2010    Post subject: Reply with quote
How well did you uninstall your old drivers originally?
TUG
PostPosted: 14:07 - 05 Apr 2010    Post subject: Reply with quote
Loads of different ways and none of them made a difference i still got frozen controls on CS and right clicking froze the pc at times.
Everything is running as it should, and i've no complaints as of yet.
Haz ER-5, innit!
The last post was made 16 years, 129 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.56 Sec - Server Load: 1.64 - MySQL Queries: 13 - Page Size: 126.83 Kb
