| TUG |
 TUG World Chat Champion
| SoND |
 SoND World Chat Champion
 Posted: 23:16 - 21 Oct 2009 Post subject: |
Download latest drivers
Uninstall current ones
Boot up in safemode and run Driver Sweeper
Reboot and install new drivers
If there's no difference then you've ruled out corrupt drivers.
Makes sense that it's the psu, as soon as the card is loaded enough the clock speeds drop to what the psu can handle. ____________________ Go back to bed - You have no rights - "Streetfighters ~ Mainstream motorcycling's crackwhore sister." |
| TUG |
 Posted: 23:29 - 21 Oct 2009 Post subject: |
| SoND wrote: | Download latest drivers
Makes sense that it's the psu, as soon as the card is loaded enough the clock speeds drop to what the psu can handle. |
Best buy a psu again then and research them propperly, i'll try the driver cleaner thing next time, bit late to be fettlin now. Cheers SoND ____________________ Haz ER-5, innit! |
| mistergixer |
 mistergixer World Chat Champion
 Posted: 08:22 - 22 Oct 2009 Post subject: |
I've got a 700W Storm PSU sitting here, used it once for a bit of troubleshooting, still in the box, your for £15 + p/p if you want it. ____________________ Space Monkey #7
Mistergixer's videos on YouTube |
| TUG |
| mistergixer |
 Posted: 22:53 - 22 Oct 2009 Post subject: |
Review here
In brief:
Specs:
Triple + 12V Output Rails
Advanced Double Forward Circuit and Double-Layer PCB
Active Power Factor Correction
Super High Efficiency Maximum 84%
Patented Design: Real-Time Power Watcher
Ultimate Balance Between Cooling and Noise Level
Honey Comb Structure for Outstanding Ventilation
Additional 4 pin Connector with Thermal Control Function for case fan
2 Ball Bearing / Long life 12cm fan
Anti Vibration Pad
All Output Cables with Nylon Sleeving
Gold plated Terminal
Flexible Connector and System Design
Patented Easy Swap Connector
Dual PCI-Express Power Connectors Fully Supports SLI & Cross-Fire systems
1 x 20+4 Main power (Standard ATX)
1 x CPU Connector (4+4) pin
2 x 6 pin PCI-E VGA
8 x 4 pin Peripheral Power Connector
2 x Case Fan Connector
2 x 4 pin Floppy Drive Power Connector
1 x Case Fan Speed Monitor
4 x S-ATA
| bazza |
 bazza World Chat Champion
| TUG |
 Posted: 19:03 - 24 Oct 2009 Post subject: |
It only has one power suply to plug to, Mister gixer, When can you send?
EDIT: Looks like the 30A on your PSU mister gixer is on the 5v rail i need a 30A 12V rail
EDIT2: x1950xtx bazza ____________________ Haz ER-5, innit! |
| SoND |
 Posted: 12:32 - 25 Oct 2009 Post subject: |
The power doesn't have to all come from one rail. Multiple lower powered rails that total over your required amps is sufficient. Each 6 pin connector does not have a dedicated rail to it. ____________________ Go back to bed - You have no rights - "Streetfighters ~ Mainstream motorcycling's crackwhore sister." |
| TUG |
| SoND |
 Posted: 14:46 - 25 Oct 2009 Post subject: |
Has your supply got one or multiple rails? (+12v1 +12v2 etc?)
mistergixers supply is plenty and more for your card. If it doesn't work for you I'll take it.  ____________________ Go back to bed - You have no rights - "Streetfighters ~ Mainstream motorcycling's crackwhore sister." |
| bazza |
 Posted: 14:47 - 25 Oct 2009 Post subject: |
The way I understood it is that you take the combined 12V rail output to be (roughly) the rating, e.g.
1 x 12V @ 22A = 22A psu
2 x 12V @ 18A = 36A psu
2 x 12V @ 25A = 50A psu
In the PSU world, you do get what you pay for, so a branded 500W model is likely to be better than a 750W unbranded chinese one.
To pass the time, feed your system specs into this PSU calculator:
https://www.extreme.outervision.com/psucalculatorlite.jsp
and see what it suggests. ____________________ "That's it. You people have stood in my way long enough. I'm going to clown college."
'98 Ducati 750SS, '08 Suzuki GSX650F ©2004-2014, Bazza's Harmless Banter |
| TUG |
| TUG |
| SoND |
| TUG |
 Posted: 18:38 - 25 Oct 2009 Post subject: |
Its like i've bought a female card, It stays fixed once booted so no drops.
Boots up either on full or like half, once i booted the pc up and the screen wouldnt show anything.
Driver issue then? I'm running usb mouse, external soundcard, wireless connector, urm, 2 hdds, dvd rw/cd rw(1 drive) its a 3-4yr old pc running AMD 3700 939 socket 3 gig ram, xp sp3 home
cant think of anything else, must be driver issue then? i dunno
Is there anyway i could of connected the PSU up wrong like mixed rails or something? ____________________ Haz ER-5, innit! |
| mistergixer |
 Posted: 20:05 - 25 Oct 2009 Post subject: |
Checked your cables? I reckon you've got a knackered/not plugged in properly video cable. ____________________ Space Monkey #7
| TUG |
| TUG |
 Posted: 00:49 - 26 Oct 2009 Post subject: |
But this though, 30 Amps on 12 volt rail recommended i think it means 1 12v rail needed? surely?  ____________________ Haz ER-5, innit! |
| TUG |
| TUG |
| Welshd1k |
 Welshd1k World Chat Champion
| P.addy |
 P.addy Red Rocket
 Posted: 09:12 - 05 Apr 2010 Post subject: |
im running a 9500GT on 450W, its below the current min specs for the card, but ive never had it fail and its definitely been stressed.
If you are on CS, let me know your steam id  |
| SoND |
| TUG |
The last post was made 16 years, 130 days ago. Instead of replying here, would creating a new thread be more useful? |
