| craigs23 |
 craigs23 Mr Muscle
| Paulington |
 Paulington World Chat Champion
 Posted: 14:16 - 01 Nov 2009 Post subject: |
Frequency of engine rebuilds - what's likely going to be needed on a regular basis - when, what and how much?
On most 2 stroke 125s you are probably looking at once every 10k miles, Aprilia suggest the first rebuild at 16000km so around that distance. As for what it's usually just a piston and cylinder, probably costing you around £200-£400 or so.
2 stroke oil - I understand that this is burnt in the combustion chamber and is fed from a separate tank - is this much like a secondary fuel tank - how much is needed over what kind of distance?
Yes it is like a secondary fuel tank, most 125s just put a small tank under the seat to put the oil in. My 125 uses around a litre of oil per 25 litres of fuel, 25:1 ratio which is about right as that's what my Kart uses also which is a Rotax 125.
Fuel consumption - likely to be a lot lower than what I'm used to from a 125 bike, but what sort of figures am I to expect?
My 125cc does about 100-120 miles to a FULL tank (including reserve) which is 13 litres, it is not good on fuel at all haha.
Any major difference between the newest RS125s and the older models? Other than looks, obviously - are they both similar in terms of maintenance schedules/reliability?
Yeah going to be similar, they are hardly different besides a bit more power and looks that I know of.
And lastly - anyone care to post some pictures of their own models, and your thoughts/stories of such little beasties?
My bike, it's the same as a Derbi GPR125R:
https://i176.photobucket.com/albums/w182/OllieePaul/GileraSC125.jpg
As much as I love the bike, as flickable and fun as it is I just find it lacks power. I enjoy being able to turn my right wrist and something to happen, whereas if you're in 2nd gear or above on the 125 you just don't get that.
HTH. . ____________________ "Four wheels move the body, two wheels move the soul."
CBT: 27/08/08. Theory: 04/09/09. Module 1: 16/09/09. Module 2: 01/10/09. |
| MarJay |
 MarJay But it's British!
 Posted: 14:19 - 01 Nov 2009 Post subject: Re: Owning a 125 2 stroke... |
| craigs23 wrote: | ...what do I need to know?
Warm it up before thrashing it, and look after it.
| craigs23 wrote: |
Frequency of engine rebuilds - what's likely going to be needed on a regular basis - when, what and how much? |
Piston and rings every 10k ish - check the bore shape and smoothness each time. Inspect the ports etc.
| craigs23 wrote: |
2 stroke oil - I understand that this is burnt in the combustion chamber and is fed from a separate tank - is this much like a secondary fuel tank - how much is needed over what kind of distance? |
Usually does about 5-10 fuel tanks to a refil of 2t, but there is a light so you don't need to worry about running out. Use good fully synthetic oil like Castrol TTS.
| craigs23 wrote: |
Fuel consumption - likely to be a lot lower than what I'm used to from a 125 bike, but what sort of figures am I to expect? | Yeah it will be bad, but I can't say that it will be any worse than something like a CBR600RR.
| craigs23 wrote: |
Any major difference between the newest RS125s and the older models? Other than looks, obviously - are they both similar in terms of maintenance schedules/reliability? |
I'd avoid anything from the last four years because anything with a catalytic converter will be awful.
Buy an older clean one and rebuild it as soon as you get it. RS125's have nikasil plated barrels which are hard wearing, but if damaged need replating after a rebore.
Owning a two stroke is not hard, but you basically need to be over 25 to be anal enough to get on with it, which is why you see so many blown up RS125's etc.
The reliability of the NSR is a testament to Honda build quality rather than the RS being particularly unreliable.
Good luck!  ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
Remember kids, bikes aren't like lego. You can't easily take a part from one bike and then fit it to another. |
| ms51ves3 |
 ms51ves3 Super Spammer
| Fahd |
 Fahd World Chat Champion
 Posted: 15:06 - 01 Nov 2009 Post subject: |
Just to add my 2-pence, I've owned an Aprilia RS50 and Aprilia RS125 (the latter for 2 years) and never had to rebuild either of them once, they'd both also always start on the button very quickly.
I think a lot of people underestimate how much damage riding these things without warming up does to them. I found warming up for 5 minutes before riding gently for at least a mile before thrashing it kept it pretty well looked after.
Having said that you might want to test-ride before buying anything, I find the Honda CBR 400RR far more entertaining and I don't have the worry of my engine blowing at the back of my mind every time I ride it with some enthusiasm. So I doubt I'd ever go back to one, it's great when you're 17, not so great when you can ride whatever you want. Here's my old little beast (the yellow and grey one) with my cousins, back when we were 17:
https://www.bikechatforums.com/files/dsc01772.jpg ____________________ I Ride: Honda CBR 400RR.
I Drive: Audi S3. |
| MarJay |
| ms51ves3 |
| Philious |
 Philious Brolly Dolly
 Posted: 17:22 - 02 Nov 2009 Post subject: |
I bought an RS 125 in June this year and parted with her a month ago for my GS500e, I think they are under rated and mainly slated for the unreliability due to the 17yr old riders not warming the engine thoroughly.
Very quick little bikes, they just want you to over take at every opportunity and great handling too, a couple of times i found my knees scarily close to the tarmac whilst riding out wearing jeans....
Mileage I found did depend on how often I pinned the throttle fully open.
As for the 2t oil as stated don't rely on the light, just pop your key under the seat and use your eyes to see how much you've got, you have to do it with the tank anyway so one more thing to check won't hurt.
https://img.photobucket.com/albums/v330/flippy2k4/DSCF2137.jpg ____________________ Previously; Honda XR125 - Yamaha DT125r - Aprilia Rs125 - Suzuki GS500e, Currently; Kawasaki ZX6R + ZX10R
Theory : Passed 28/7/09 Module 1: Passed 21/09/09 Module 2: Passed 23/09/09 |
| Andy C |
 Andy C Tree Seeking Missile
 Posted: 21:15 - 02 Nov 2009 Post subject: |
I loved and hated mine. Was always careful to let it stand to warm and use the best oil but still ended up having to pay for a top end (wasnt machanically minded enough back then to do it myself) which worked out expensive.
Great handling but after the top end went I found myself quite paranoid about it happening again and although it was great to ride wasnt practical at all (though im sure you would be using it for summer days).
Think I actually perfer my RXS as is a 2 stroke but seems to have more character (though slower, worse brakes/suspension/frame/wheels/everything).  ____________________ 99 RS125 --> 02 SV650s --> 03 Speed Four --> 92 RXS100 --> 93 CB400sf --> 01 CB600f Hornet |
| Philious |
 Posted: 21:25 - 02 Nov 2009 Post subject: |
I miss the old RD 125 Lc, a mate of mine had one a few years ago and that was a sweet bike. They just don't make them like they used to.  ____________________ Previously; Honda XR125 - Yamaha DT125r - Aprilia Rs125 - Suzuki GS500e, Currently; Kawasaki ZX6R + ZX10R
| Kickstart |
 Kickstart The Oracle
 Posted: 22:33 - 02 Nov 2009 Post subject: Re: Owning a 125 2 stroke... |
| craigs23 wrote: | Frequency of engine rebuilds - what's likely going to be needed on a regular basis - when, what and how much? |
Aprilia say to check the ring at 8000km. It is about as much effort to check them properly as it is to just change them. I tend to change them at 6000km. It is a gentle afternoons work. Rings are not a massive amount and the only gaskets you need to disturb are the base gasket and power valve gasket (should be under £5 for the pair). Head gaskets are a couple of rubber O rings and can be reused a few times if you check them.
The drive gears for the balance shaft are also meant to be replaced.
They eat brake pads. Rear shock work OK but are not the most long lived things.
| craigs23 wrote: | 2 stroke oil - I understand that this is burnt in the combustion chamber and is fed from a separate tank - is this much like a secondary fuel tank - how much is needed over what kind of distance? |
Like a secondary tank. The RS isn't bad on 2 squeak oil. Some 2 squeaks use more than others (the TZR125 we had many years ago used at least twice as much as the RS). RS owners handbook says something like 1%~2% 2 stroke oil, so that is probably a litre every 4 tanks or so.
| craigs23 wrote: | Fuel consumption - likely to be a lot lower than what I'm used to from a 125 bike, but what sort of figures am I to expect? |
About 55mpg in general use, less if thrashed. Managed 74.5mpg during the fuel strikes (it was agony)
| craigs23 wrote: | Any major difference between the newest RS125s and the older models? Other than looks, obviously - are they both similar in terms of maintenance schedules/reliability? |
Lots of differences but maintenance is much the same. Older ones need the timing setting properly and the older flywheels are more delicate.
Although the engines are similar, loads of bits cannot be interchanged. Barrels are different, gearchange is different.
| craigs23 wrote: | And lastly - anyone care to post some pictures of their own models, and your thoughts/stories of such little beasties? |
https://www.alfa-pages.co.uk/TempPicture/img_7714.jpg
Personally I like them. Reliability is acceptable, performance acceptable, handling is good and the brakes are good.
| G |
 G The Voice of Reason
| Kickstart |
| G |
| Kickstart |
| serlant |
 serlant Brolly Dolly
| G |
| Kickstart |
| prawny1 |
 prawny1 World Chat Champion
| G |
 Posted: 23:51 - 02 Nov 2009 Post subject: |
Yea, can't see the 'radial' bit being the over-riding factor, but so far all the bikes I've ridden that have bothered with radial callipers have had good brakes. Presumably if they're going to the money/effort of doing them, they're going to do them half-decently.
I'm sure it won't be too long before they're on cheap Chinese bikes with appropriate performance, however . |
| Mord |
 Mord Nearly there...
 Posted: 00:13 - 03 Nov 2009 Post subject: Re: Owning a 125 2 stroke... |
| Quote: | I've read the odd post here and there, about how easy the strokers are to work on, but what do I really need to know in regards to:
They are.. and pretty much you can do everything by yourself. Piston and rings need to be changed every 5-8k miles or so (compression tester is your friend, so is Haynes manual). Always warm it up properly before you trash it (usually after 5-10 minutes of sensible riding when temp gauge stops going up and down).
Don't buy cheap piston, go for genuine Aprilia one or Wiseco. Cost around 100 quid for Wiseco rebuild kit. Run-in for first 200 miles or so.
| Quote: | 2 stroke oil - I understand that this is burnt in the combustion chamber and is fed from a separate tank - is this much like a secondary fuel tank - how much is needed over what kind of distance? |
You need 1 litre of 2T oil per 40-50 litres of petrol you use. Just top-up every 2-3 times you fill your petrol tank and you will be ok. Don't rely on 2T oil level sensor, better visually check oil level.
| Quote: | Fuel consumption - likely to be a lot lower than what I'm used to from a 125 bike, but what sort of figures am I to expect? |
I get 45mpg from full power 2008 RS125.
| Quote: | Any major difference between the newest RS125s and the older models? Other than looks, obviously - are they both similar in terms of maintenance schedules/reliability? |
Power wise they both can be the same.. Older models are cheaper to derestrict.. newer models apart from powervalve+solenoid fitting need also exhaust changed or decated to make them produce as much power as older models i.e. exhaust in 2003+ models is with cat, in Euro3 models the cat is even more restrictive (easy to solve.. just get decated exhaust i.e. Arrow like I did).. Pre 1998 models used to have bigger 34mm carb = worse mpg, more power. 34mm carbs available for 1998-2009 bikes so no problem
| Quote: | And lastly - anyone care to post some pictures of their own models, and your thoughts/stories of such little beasties? |
Photo..
https://i244.photobucket.com/albums/gg19/Mordoklej/RS125_640V1.jpg
Videos..
https://www.youtube.com/watch?v=a0N72n5F-ys
https://www.youtube.com/watch?v=DZFOXzEmT8s |
| craigs23 |
 craigs23 Mr Muscle
 Posted: 06:50 - 03 Nov 2009 Post subject: |
Thanks for all of the responses I'm a bit closer to making my mind up about whether to truly get one or not. As mentioned, I've never had a stroker before and can definitely see the appeal - even the regular tinkering away in the garage is a bit of a plus point for me.
I'll have a nose around the local papers to see if I can get something at a reasonable price - I think if I can get an Extrema-like model with some change left over for some parts would be ideal.
Thanks again.  |
| ms51ves3 |
| 27cows |
 27cows World Chat Champion
| Kickstart |
 Posted: 12:34 - 03 Nov 2009 Post subject: |
Personally, because they are fun, and you can thrash them pretty hard without going at silly speeds. Because they are in a fairly high state of tune and you need to get it right to get the best from it. Unlike anything much larger (including 250 2 strokes) where you can be far lazier and still make good progress. Same can apply to even smaller 2 stroke (I have an unrestricted 50cc gag bike as well), just that they land up being too slow for any great distance on major roads, while a 125 can happily keep up with the general flow of traffic on the motorway.
Sure a 400 4 stroke will be far quicker, but to me nowhere near as much fun.
Fast does always mean fun. Fast normally means you cannot use the performance so are just sitting round at boring revs.
The last post was made 16 years, 312 days ago. Instead of replying here, would creating a new thread be more useful? |
