CG125, What should I do?
johnsmith222
PostPosted: 00:35 - 25 Nov 2009    Post subject: CG125, What should I do? Reply with quote
Hi.
I have a '99 CG125 with a siezed engine. It's solid.
https://i14.photobucket.com/albums/a324/david_m213/DSC00051-1.jpg
I like CGs and as this is my first bike, it has sentimental value. I suppose it could be sold as parts, but I'd like to get it on the road. It is taxed but doesn't have an MOT.
It needs new forks, stripping and bits of the frame painted etc. I wouldn't get it done professionally. I'd hammerite the bits that need done after cleaning the rust off etc.
It'll need a new engine.
I'd be wanting to spend no more than £200 getting it back on the road.
Do you think I should bother or should I just get rid of it?
I did really like the wee bike but I wouldn't buy another CG because they're expensive for what they are because they're learner legal.
I'd probably learn a lot about bikes by getting it all nice again.
What do you guys think I should do?
I would be buying all parts second hand and doing it as cheap as possible.
Pie-Roe
PostPosted: 00:47 - 25 Nov 2009    Post subject: Reply with quote
Pick up a running mot failure for sub 200 quid, then use the best bits from both bikes to make your original one work.
Pyro
TUG
PostPosted: 00:52 - 25 Nov 2009    Post subject: Reply with quote
This is a learning curve bike, strip it.
You will have plenty of help here to sort it, i bet you could get a piston and rings cheap if the barrell isnt to bad, but tbh, i've be tempted to bore it to a 145? or is it a 175?
Haz ER-5, innit!
johnsmith222
PostPosted: 00:53 - 25 Nov 2009    Post subject: Reply with quote
Pyro
That's a really good idea.
I could sell the parts that I don't use and make quite a bit of money back as well. Thumbs Up
PostPosted: 00:55 - 25 Nov 2009    Post subject: Reply with quote
How seized? Only just, or been sitting in a canal for a couple of years?
Cheap method that is worth a try. Whip the plug out and lob a load of diesel fuel through the plug hole and leave it to stand for a few days. The try the kickstart again.
Once you get it to turn over drain the diesel and do an oil change.
johnsmith222
PostPosted: 00:58 - 25 Nov 2009    Post subject: Reply with quote
It's not been sitting in a canal. It siezed in august because it was run without any oil.
It's completely solid. you can put your whole weight on the kickstart and bounce and it won't move.
Thanks for your help anyway. Cool
Karma
I was on the motorway when I lost power and rolled to a stop then died.
I have access to a couple of friends who are mechanics also(although can't ask for too much help and would like to try everything myself first). I guess I really need to just strip the engine and see what I have to work with.
I'd be happy to bore it out, but I'm guessing that would be quite expensive as it needs to be exact.
I'll post some photos when I strip the engine in a week so you guys can judge if it's worth salvaging.
wizzzard
PostPosted: 01:21 - 25 Nov 2009    Post subject: Reply with quote
If you find it is seriously screwed when you open it up and it's going to be to much to repair I have a cg engine you can have. Not sure what year it is but it's free to a good home if you can sort some way of getting it to you Thumbs Up
PostPosted: 01:23 - 25 Nov 2009    Post subject: Reply with quote
A re-bore a piston will cost you maybe £100. I can't see it costing more than that.
johnsmith222
PostPosted: 01:36 - 25 Nov 2009    Post subject: Reply with quote
Hi Wizzzard.
I really appreciate the offer! Thumbs Up
I'll check out the engine that's in the bike, but if it's gubbed then I'd definately figure out a way of picking up the engine. I'm sure I could get a courier to pick it up or something. If not then maybe it'd fit on the ZZR? Laughing
Thanks mate! Thumbs Up
27cows
PostPosted: 07:05 - 25 Nov 2009    Post subject: Reply with quote
How on earth did you manage to run the engine dry? Shocked
Ariel Badger
PostPosted: 07:57 - 25 Nov 2009    Post subject: Reply with quote
You broke it, you mend it.
You owe it to the bike and you will learn a lot by doing so.
PostPosted: 10:52 - 25 Nov 2009    Post subject: Reply with quote
For £66 I'd be tempted to make a CG150 :-
https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=280418148946
PostPosted: 11:07 - 25 Nov 2009    Post subject: Reply with quote
If you have seized if from running it out of oil then I would expect there to be a load of other damage to the crank, etc.
johnsmith222
PostPosted: 18:19 - 25 Nov 2009    Post subject: Reply with quote
and it begins...
https://i14.photobucket.com/albums/a324/david_m213/DSC00194.jpg
https://i14.photobucket.com/albums/a324/david_m213/DSC00195.jpg
TUG
PostPosted: 21:21 - 25 Nov 2009    Post subject: Reply with quote
Glad your stripping it, you'll need to fix that stand it looks too far forward, normally one of the legs snaps it's weld.
Also heres the bore out option i suggested.
Haz ER-5, innit!
johnsmith222
PostPosted: 23:23 - 25 Nov 2009    Post subject: Reply with quote
Everything went smoothly, until I got to the last engine bolt!
I could've done everything I did before in the time it took me to remove the last bolt.
Here it is:
https://i14.photobucket.com/albums/a324/david_m213/DSC00198-2.jpg
The next step will be to strip the engine and see what's up. I don't know if I'll be taking photos though, my bet is the damage will be quite embarassing. Embarassed
PostPosted: 23:31 - 25 Nov 2009    Post subject: Reply with quote
The thread will be useless without damage photos.
johnsmith222
PostPosted: 23:34 - 25 Nov 2009    Post subject: Reply with quote
haha, don't worry. There will definately be damage photos when I get around to striping it. I will probably be stripping it next week as I'm really busy this week.
I was just trying to put across how ashamed I feel for wrecking it in the first place.
dextersaurus
PostPosted: 08:08 - 26 Nov 2009    Post subject: Reply with quote
I had exactly the same bike, seized it solid.
Stuck some oil in the sump, and took the plug off and stuck some oil down there, left it overnight and i managed to kick it over.
it ran fine after that.
But as said above, the 150 does seem like a good idea Razz
Dunc
johnsmith222
PostPosted: 17:22 - 27 Nov 2009    Post subject: Reply with quote
Cylinder head seems ok:
https://i14.photobucket.com/albums/a324/david_m213/DSC00199.jpg?t=1259342011
https://i14.photobucket.com/albums/a324/david_m213/DSC00205.jpg?t=1259342301
https://s14.photobucket.com/albums/a324/david_m213/?action=view¤t=DSC00207.jpg
https://i14.photobucket.com/albums/a324/david_m213/DSC00212.jpg
https://i14.photobucket.com/albums/a324/david_m213/DSC00215.jpg
https://i14.photobucket.com/albums/a324/david_m213/DSC00217.jpg?t=1259342484
The barell isn#t as bad as I was expecting, but it's still scored. Sad
I think I will need a replacement engine.
dextersaurus
PostPosted: 17:34 - 27 Nov 2009    Post subject: Reply with quote
Rebore and new piston will work out cheaper mate.
Why not try out the 150 replacement?
worth a punt eh Laughing
Dunc
shadowbiker
PostPosted: 17:41 - 27 Nov 2009    Post subject: Reply with quote
Dunc
I thught you had said c*nt then Laughing
yeah 150cc would be a better option but once it all back together make sure you do the jetting
PostPosted: 17:42 - 27 Nov 2009    Post subject: Reply with quote
If it has done that through lack of oil then check the crank carefully. Would expect the crank to die before the piston siezed.
PostPosted: 17:45 - 27 Nov 2009    Post subject: Reply with quote
Looks like it has been running a bit lean.
TUG
PostPosted: 21:15 - 27 Nov 2009    Post subject: Reply with quote
As chives said i expect the same, soo its been getting extremely hot, well if you ride them like me anyway, Do the overbore like i did it will work out miles miles cheaper than you think, use your initive mate, your a biker, not a car driver, so think outside the box.
Haz ER-5, innit!
The last post was made 16 years, 282 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 130.62 Kb
