| Coxyzxr |
 Coxyzxr Brolly Dolly
| Coxyzxr |
 Posted: 19:05 - 29 Dec 2009 Post subject: |
Seems odd. Would expect the colder weather to result in the bike running leaner rather than richer.
Could be worth getting it a run on a dyno to check the mixture. Possible that the 4>2>1 is behaving very differently to the stock system and needs a very different shape set of needles, with you getting away with it in warmer weather. Lean at some rpm and rich at others. However I would be surprised if it made that much difference.
One reason I asked about a Dynojet kit is that the needles used in some aftermarket kits are renowned for increasing wear on the atomiser tubes, making the bike run quite a bit richer at some revs.
To count out carb icing lob some suitable fuel additive in for a tank (and try a few tanks with and without it). To be honest I doubt is will make any difference but at least it is an easy thing to count out this way.
| Coxyzxr |
| Coxyzxr |
| hmmmnz |
 hmmmnz Super Spammer
| Coxyzxr |
 Posted: 09:03 - 30 Dec 2009 Post subject: |
| 0ddball |
 0ddball World Chat Champion
 Posted: 11:24 - 30 Dec 2009 Post subject: |
| Coxyzxr |
| temeluchus |
| Barry_M2 |
 Barry_M2 World Chat Champion
 Posted: 13:06 - 30 Dec 2009 Post subject: |
So, from what I gather, it runs ok when cold and starts to play up when the motor warms up a little? Runs on 3 (or 2), stalling... etc..
Initially I'd say fueling, but I could also be one of the coils playing up. When you had the float bowls off, did you remove the jets and clean them?
If it were me, I'd get it warmed up until it starts to missfire, see what cylinder it is and swap the plugs round to see if the problem follows the plug. If not, clean out the carb jets. If thats not it, see if you can find a spare coil and give that a go.
If its only running crap at low rpm, I'd suspect pilot jets. ____________________ ZXR750R (M2) - For the road.
CBR1000 RR4 - For the track.
https://www.bikechatforums.com/profile.php?mode=viewprofile&u=4332 |
| Coxyzxr |
 Posted: 14:18 - 30 Dec 2009 Post subject: |
| Barry_MC21 wrote: | So, from what I gather, it runs ok when cold and starts to play up when the motor warms up a little? Runs on 3 (or 2), stalling... etc..
If its only running crap at low rpm, I'd suspect pilot jets. |
HI barry. thanks. I have spare coils so may replace on weekend just as a matter of course.
I intend to take apart carbs on wkend also if time permits. Looking to get a gpz500 or something for commuting when moeny permits as it's breaking my heart running the zxr in this weather everyday. Needs a major overhaul so need to get it off the road asap. ____________________ **WAS FITTED "WRONG WAY ROUND" !** CANT ACCOUNT FOR THE STUPID ! |
| base |
 base Trackday Trickster
The last post was made 16 years, 294 days ago. Instead of replying here, would creating a new thread be more useful? |
