Cagiva mito engine temp rising dramaticly.
spitfire123
PostPosted: 18:09 - 31 Dec 2009    Post subject: Cagiva mito engine temp rising dramaticly. Reply with quote
hi,
was riding the mito today and i was giving it some revvs when i noticed (pulled in to the garage for fuel) that the temp had climbed to 110 degrees...
at this point i was about 2 mile away from my house luckly and waited for it to cool down to around 80 ish degrees and started it up again and in the space of about 400 yards it had gone back up to 100 degrees.
when i eventurly got home i left the bikek there for 30 mins(off) and the temp meter was still reading 60 degrees after that 30 mins...so i started it up and even idoling the tempreture of the engine was shooting up and in the space of 2 mins it had climed to 80ish degrees!
now what isit? is it the thermostat or could it be the water mumps packed up?
cheers all. Thumbs Up
You won't be able to eat my dust......As it'll settle before you get there.
Damon
PostPosted: 01:38 - 01 Jan 2010    Post subject: Reply with quote
I would check for an airlock in your rad/ any leaks. If all is fine, I would then have a go at checking the water pump is working ok. Sorry I am not much help, its late and I've just got back from a new years party.
Im totally dishwashered Wink
Billing
PostPosted: 04:29 - 01 Jan 2010    Post subject: Reply with quote
Make absolutely sure theres plenty of coolant in the rad an expansion tank (its something that may have been overlooked in the whole 'oh cock its really heating up' moment) After checking that I'd agree with the above, if it was my bike the order in which I would check would be;
1; Airlock in the cooling system, this can be fixed really quickly by bleeding the system.
2; Make sure theres no silty buildup in the pipes, this would reduce coolant flow, thereby not providing the full cooling effect
3; Faulty thermostat, if it isn't opening then hot coolant will be stuck circulating round the engine and not doing its job. Take it out and then see if the problem persists. If this doesn't help, then it's time to look at the pump being faulty.
4; Broken waterpump. I'd take the housing cover off, and see if the impeller (i think thats what it is) can be taken out , if it can, then its either snapped the impeller shaft, or the drive gear on the back has come loose. If you can't take it out, then the gear on the back may be damaged (stripped the teeth off, chunk of the gear missing etc)
I think thats everything covered, might be worth giving your system a flush out while your working on it, keep it in tip top condition Smile
spitfire123
PostPosted: 17:25 - 01 Jan 2010    Post subject: Reply with quote
hi mate,
yea cheeps for that.
got the thermostat with me now...works fine just checke dit.
no air leaks
plenty of coolent
all i havent checked is the water pump....mantey who ad the engine before me has change dthe waterpump gasket so im guessing it had a problem before Mad
im gonna crack on with it now.
cheers
flat spot
PostPosted: 18:34 - 01 Jan 2010    Post subject: Reply with quote
Not quite everything. The timing may be slightly out, it could be running lean (developed a leak). Pull the plug to give you a clue.
spitfire123
PostPosted: 19:29 - 01 Jan 2010    Post subject: Reply with quote
nope the plastic water pump drive gear smashed in to 3 peices and was just lying at the bottom of the sump!
it had to be thing only part i done have for it Mad
anyone know where i can get 1 from A.S.A.P? i need the bike for tuesday. Shocked
cheers
st3v3
PostPosted: 17:22 - 02 Jan 2010    Post subject: Reply with quote
Get to your nearest dealer.
Other than that, You'll be paying over the odds for a part off an Ebay seller if one will ship one out special delivery but it's still asking a lot.
Might also be worth checking the cylinder head is bolted nice and tightly. Thumbs Up
spitfire123
PostPosted: 21:46 - 02 Jan 2010    Post subject: Reply with quote
yea but there miles away from me! Laughing
and Why check the cilinder head??
thanks
st3v3
PostPosted: 23:58 - 02 Jan 2010    Post subject: Reply with quote
Afraid beggars can't be choosers, gotta get stuff from where it is.
I mentioned cylinder head since a mate I used to ride with had several instances when his temp gauge shot up and the bike would steam out, often near causing a seize and no bleeding or refill ever did the trick; we found out the end cause was a small hole in cylinder head where a nut had worked loose and created the tiniest gap around the top end gasket; this made water from the coolant system leak out and the engine get worringly hot..
bladerunner
PostPosted: 00:33 - 03 Jan 2010    Post subject: Reply with quote
Try Mito Mondo ltd for spares in future they seem pretty good for partd
https://www.mitomondo.co.uk/main.html
they are specialists in mito spares new and used
HTH
spitfire123
PostPosted: 16:25 - 11 Jan 2010    Post subject: Reply with quote
HTH
yeh i no about him i usaly get quite alot of stuff off of him.
all sorted now and engine isnt overheating anymore scince ive changed the WP drive gear Smile
spitfire123
PostPosted: 16:26 - 11 Jan 2010    Post subject: Reply with quote
i see,
ill check tonight.
thanks
The last post was made 16 years, 243 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.33 - MySQL Queries: 13 - Page Size: 78.66 Kb
