| spitfire123 |
 spitfire123 Could Be A Chat Bot
 Posted: 18:09 - 31 Dec 2009 Post subject: Cagiva mito engine temp rising dramaticly. |
hi,
was riding the mito today and i was giving it some revvs when i noticed (pulled in to the garage for fuel) that the temp had climbed to 110 degrees...
at this point i was about 2 mile away from my house luckly and waited for it to cool down to around 80 ish degrees and started it up again and in the space of about 400 yards it had gone back up to 100 degrees.
when i eventurly got home i left the bikek there for 30 mins(off) and the temp meter was still reading 60 degrees after that 30 mins...so i started it up and even idoling the tempreture of the engine was shooting up and in the space of 2 mins it had climed to 80ish degrees!
now what isit? is it the thermostat or could it be the water mumps packed up?
cheers all.  ____________________ You won't be able to eat my dust......As it'll settle before you get there. |
| Damon |
 Damon World Chat Champion
 Posted: 01:38 - 01 Jan 2010 Post subject: |
I would check for an airlock in your rad/ any leaks. If all is fine, I would then have a go at checking the water pump is working ok. Sorry I am not much help, its late and I've just got back from a new years party.
Im totally dishwashered  |
| Billing |
 Billing World Chat Champion
 Posted: 04:29 - 01 Jan 2010 Post subject: |
Make absolutely sure theres plenty of coolant in the rad an expansion tank (its something that may have been overlooked in the whole 'oh cock its really heating up' moment) After checking that I'd agree with the above, if it was my bike the order in which I would check would be;
1; Airlock in the cooling system, this can be fixed really quickly by bleeding the system.
2; Make sure theres no silty buildup in the pipes, this would reduce coolant flow, thereby not providing the full cooling effect
3; Faulty thermostat, if it isn't opening then hot coolant will be stuck circulating round the engine and not doing its job. Take it out and then see if the problem persists. If this doesn't help, then it's time to look at the pump being faulty.
4; Broken waterpump. I'd take the housing cover off, and see if the impeller (i think thats what it is) can be taken out , if it can, then its either snapped the impeller shaft, or the drive gear on the back has come loose. If you can't take it out, then the gear on the back may be damaged (stripped the teeth off, chunk of the gear missing etc)
I think thats everything covered, might be worth giving your system a flush out while your working on it, keep it in tip top condition  ____________________ '84 TS50X, '91 TZR125, '89 CBR400RR, '91 VFR400R NC30, '98 R1
BCF Eastern members map here ---> g.co/maps/2tm8b PM me to be added to it! |
| spitfire123 |
 Posted: 17:25 - 01 Jan 2010 Post subject: |
| BillingTZR wrote: | Make absolutely sure theres plenty of coolant in the rad an expansion tank (its something that may have been overlooked in the whole 'oh cock its really heating up' moment) After checking that I'd agree with the above, if it was my bike the order in which I would check would be;
I think thats everything covered, might be worth giving your system a flush out while your working on it, keep it in tip top condition  |
hi mate,
yea cheeps for that.
got the thermostat with me now...works fine just checke dit.
no air leaks
plenty of coolent
all i havent checked is the water pump....mantey who ad the engine before me has change dthe waterpump gasket so im guessing it had a problem before
im gonna crack on with it now.
cheers ____________________ You won't be able to eat my dust......As it'll settle before you get there. |
| flat spot |
 flat spot World Chat Champion
| spitfire123 |
| st3v3 |
 st3v3 Super Spammer
 Posted: 17:22 - 02 Jan 2010 Post subject: |
Get to your nearest dealer.
Other than that, You'll be paying over the odds for a part off an Ebay seller if one will ship one out special delivery but it's still asking a lot.
Might also be worth checking the cylinder head is bolted nice and tightly.  ____________________ Roger wrote: Women don't get damp for clingy puppies. Get some better happy pills, hit the gym & buy a medallion the size of a dinner plate. Job done |
| spitfire123 |
| st3v3 |
 st3v3 Super Spammer
| bladerunner |
 Posted: 00:33 - 03 Jan 2010 Post subject: |
Try Mito Mondo ltd for spares in future they seem pretty good for partd
https://www.mitomondo.co.uk/main.html
they are specialists in mito spares new and used
HTH ____________________ Current bikes...cbr929, KDX200's, Rd125lc mk2, RGV250's |
| spitfire123 |
 Posted: 16:25 - 11 Jan 2010 Post subject: |
yeh i no about him i usaly get quite alot of stuff off of him.
all sorted now and engine isnt overheating anymore scince ive changed the WP drive gear  ____________________ You won't be able to eat my dust......As it'll settle before you get there. |
| spitfire123 |
The last post was made 16 years, 243 days ago. Instead of replying here, would creating a new thread be more useful? |
