test help
grandmasterbo...
PostPosted: 15:28 - 16 Jan 2010    Post subject: test help Reply with quote
hi i was wandering how to go about doing my test im 21 in march whoo and im wondering wether or not to pay the £400 ish and do a course or to pay for each module in separates and pass that way by doing it that way i onley spend £130 but i onley have my CBR125 wich doesnt do U'turns or would it be worth getting a mate to insure me on one of there bikes ?
any help please
also anyone know of a CBR 250 anywhere in the uK?
suzuki CS50 roadie (exploded) Gilerea Runner VX 125 (sold)
CBR125 rw6 (crapped itself and died) YBR 125 2004 (its okay)
cyberglass
PostPosted: 16:34 - 16 Jan 2010    Post subject: Reply with quote
Do the cource on the training center bike.
If you cant u turn the cbr then your gonna need a few lessons as your gonna be doing them on a big heavy 500.
Get out there and practice turning your cbr its easy when you get the hang of it.
Keep the clutch in and set the revs to around 2500 and keep them there then gently release the clutch to its biting point and when the bike starts moving pull it in a bit so you dont go to fast and release it if you go to slow.
Also look ahead to where your going and not at the front wheel or side of the road. Your bike will go wherever your looking so if its the curb thats where you will end up.
You need to force yourself not to put your feet down if you think your going down let the clutch out a bit more and speed up.
DL650 Vstrom 2004
DRZ400S 2003
Yamaha R1 2005
grandmasterbo...
PostPosted: 17:19 - 16 Jan 2010    Post subject: Reply with quote
not doubghting your methord there but iv had many people try and u turn it and noone has done it so far tho is the uturn a nessasary part of it i can do them on other bikes just not this one :/
T0MMY
PostPosted: 18:45 - 16 Jan 2010    Post subject: Reply with quote
Most important thing on the u turn or any other slow manouvere is to control the speed with the back brake the whole time. Literally ride the back brake and let the power pull the bike against it, you will be FAR more stable.
You will have to do a u turn in your test I think and I cannot believe it's impossible to U-turn a CBR125 Laughing
ZX6R + CBR600RR
Bubbs
PostPosted: 18:56 - 16 Jan 2010    Post subject: Reply with quote
Agree!
Also make sure you use the whole width of the U-turn area. You'r given a lot of room to get your bike round, don't do my mistake and turn too sharp and bang the handlebars against the tank!
Also keep the rev's up throughout so you know that the power is there if you need it if for any reason you get into trouble i.e. going too slow.
T0MMY
PostPosted: 19:21 - 16 Jan 2010    Post subject: Reply with quote
Yep, definitely. getting on and off the power will make the bike unstable so by holding the back brake you can keep the revs high and the clutch slipping without picking up speed. Don't touch the front brake though!
ZX6R + CBR600RR
ScreamWorker
PostPosted: 19:24 - 16 Jan 2010    Post subject: Reply with quote
i had a cbr 125 and it did uturns perfectly, its got hardly anything to do with the bike and all to do with your technique and confidence...
if someone told you uturns on a cbr 125 was piss easy you would keep going untill you cracked it,
CBR125 is a perfectly adequate bike for taking a cbt on and im sure with alot of practice you would be fine
That_Hornet
PostPosted: 19:25 - 16 Jan 2010    Post subject: Reply with quote
Practice makes perfect.
I was shit a U turns when i first started. Then i just practiced. Now i can do a U turn in half the road.
Just balance
Thumbs Up Karma
Good Luck
Alexio
PostPosted: 19:28 - 16 Jan 2010    Post subject: Reply with quote
Maybe it's because I keep my tick-over speed quite high, but if I'm running out of steam on a U-turn I just slip my clutch and sail the rest of the way, I never go so fast as I've had to use the back brake Confused
T0MMY
PostPosted: 19:31 - 16 Jan 2010    Post subject: Reply with quote
The point of the back brake is more about stability than controlling speed as such. It lets the power keep pulling at the back wheel throughout the manouvere which makes it far more stable and smooths out jolts from changes in throttle position or clutch...trust me on this Laughing
ZX6R + CBR600RR
DogHeadGod
PostPosted: 19:35 - 16 Jan 2010    Post subject: Reply with quote
If you can walk your bike in a u-turn you should be able to ride it in a u-turn over the same space.
My RS125 had a really wide turning circle, which meant it could only u-turn in a *really* wide bit of road. Eventually I just started doing lessons on their bikes cause it was less hassle. I take it that is what you mean by "doesn't do u-turns"
Alexio
PostPosted: 19:36 - 16 Jan 2010    Post subject: Reply with quote
Ok, ok I trust you Laughing I must be so well practised at U-turns I don't even notice how I do them any more but they always seem to be very quick and smooth. And Lord knows I've had to do a lot of U-turns last year when I kept getting lost in the country side Laughing
Slim1664
PostPosted: 00:05 - 17 Jan 2010    Post subject: Reply with quote
All very sound advice. Exactly what i did when i passed DAS last year. Brake brake was on, clutch to control speed.
I also try to keep myself upright and push the bike on its side. Sort of like counter leaning. If im doing a right "U" turn i slide half an arse off to the left and try to keep my body upright whlie the bike turns.
It got my Yammy R125 doing nice U turns with some practice, same with the Gixxer.
1ST bike-08 YZF R125 in midnight blue. (sold)
2ND bike-02 GSXR 600 K1 in blue white. (sold)
3RD bike-06/7 plate YZF R1 `Raven`. (current)
metalangel
PostPosted: 13:55 - 17 Jan 2010    Post subject: Reply with quote
You'll whinge your little CBR won't do u-turns but your instructor will no doubt do a u-turn on his enormous BMW just to show you, and then tell you to STFU and get on with it.
grandmasterbo...
PostPosted: 14:20 - 18 Jan 2010    Post subject: Reply with quote
ok i manages one just before nearlly falling on my face so ill wok in it a bit now umm tho just wondering if i were to do my test in out of a center nd do the theory mod 1 then mod 2 but no training between and do it on my 125 will i be restricted to the 125 for a bit longer
calyx
PostPosted: 22:00 - 18 Jan 2010    Post subject: Reply with quote
You/your bike will be restricted to 33bhp for 2 years.
Keep practising and you will be just fine.
This is what happens if you over practice;
https://www.youtube.com/watch?v=bWaq0zOaAVU
Boris - London
pwntifex
PostPosted: 07:08 - 19 Jan 2010    Post subject: Reply with quote
Why can't anybody spell these days?
Has the curriculum finally boiled down to dance and drama?
Alexio
PostPosted: 09:33 - 19 Jan 2010    Post subject: Reply with quote
Complaining about misspellings on the internet is like complaining about rain in England. Saying that, it is in the Official BCF rule book '09 and forum guidelines to spell properly and in a grammatically acceptable way.
Go easy on the kids grampa Razz
T0MMY
PostPosted: 09:54 - 19 Jan 2010    Post subject: Reply with quote
Trouble is they're not kids! If they are on here they're probably old enough to ride a bike; I seem to recall being literate at 16 Laughing I have to agree it is amazing how poor the standard of education seems to be these days but maybe it's just because you communicate with people on the internet that you might not normally meet.
ZX6R + CBR600RR
grandmasterbo...
PostPosted: 10:36 - 19 Jan 2010    Post subject: Reply with quote
i claim valid reason for the speling ↲ADHD torrets dislexic and autism also it wont bother me me as the cbr gets paid of in 18 months
grandmasterbo...
PostPosted: 10:39 - 19 Jan 2010    Post subject: Reply with quote
The Original Muzza
PostPosted: 11:32 - 19 Jan 2010    Post subject: Reply with quote
All diagnosed by a professional health worker no doubt? Laughing Don't forget aspergers and schizophrenia.
Alexio
PostPosted: 11:45 - 19 Jan 2010    Post subject: Reply with quote
Aspergers is a lesser (different?) form of autism silly Rolling Eyes
The Original Muzza
PostPosted: 11:50 - 19 Jan 2010    Post subject: Reply with quote
I believe there is debate as to whether or not it should be classified within the autism spectrum. In other news: Meh. It's one of the most common self-diagnosed diseases on the internet (srsly).
grandmasterbo...
PostPosted: 13:37 - 19 Jan 2010    Post subject: Reply with quote
haha i love how knoone ever beleives have that
The last post was made 16 years, 233 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 132.44 Kb
