honda cg125 - broken rev counter
dave_manz
PostPosted: 18:32 - 28 Jan 2010    Post subject: honda cg125 - broken rev counter Reply with quote
just got a 2002 honda cg125 and everything is running fine on it besides the rev counter that doesnt work at all Sad
is there anyway to six this myself or is it a garage job?
thanks!
rob_scott92
PostPosted: 19:06 - 28 Jan 2010    Post subject: Reply with quote
most likely the cable has snapped where it goes into the engine, easy enough to check and replace.
Just get a pair of pliers, a cloth around the bit where you loosen the cable from the engine (as to not damage it), take out and replace. Jobs a good'un Thumbs Up If it turns out the cable isn't snapped it could well be the mechanism inside the rev counter itself, but its most likely the cable.
Hope this helps Wink
Rob Thumbs Up
dave_manz
PostPosted: 19:29 - 28 Jan 2010    Post subject: Reply with quote
ah thats not too bad then Smile
i will go have a look now Thumbs Up
dave_manz
PostPosted: 19:50 - 28 Jan 2010    Post subject: Reply with quote
i have followed the cable down from the back of the rev counter and it has indeed snaped Sad however i cant see where the cable should feed into Confused
rob_scott92
PostPosted: 20:59 - 28 Jan 2010    Post subject: Reply with quote
Basically , inside where the cable goes in there should be something pointing out a bit, kinda like a screwdriver bit if you like (Flathead btw Rolling Eyes ). on a new un-snapped cable there will be a bit on the end that fits over that.
Will try and get a pic for you if you're still stumped. it really is a 2 min job if that! i had the same when i bought my bike, its all a good learning experience Very Happy
Let us know how it goes
Rob Thumbs Up
Moo.
PostPosted: 21:32 - 28 Jan 2010    Post subject: Reply with quote
When did CG's have rev counters?
Have a search on ebay, likely to be able to get a replacement cable and will screw in Very Happy
A2 Passed 18/6/10
Ditto
PostPosted: 22:52 - 28 Jan 2010    Post subject: Reply with quote
CG with a rev counter. Pah Razz
CG 125 > Bandit 600 > CBR 600 FY > Street Triple R
Alexio
PostPosted: 23:05 - 28 Jan 2010    Post subject: Reply with quote
I'm hoping you're talking about the speedo (which kind of acts like a rev counter if you know what gear you're in). In which case it goes from the front wheel to the back of the speedo.
The last post was made 16 years, 258 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.25 - MySQL Queries: 13 - Page Size: 55.28 Kb
