| dave_manz |
 dave_manz Derestricted Danger
 Posted: 18:32 - 28 Jan 2010 Post subject: honda cg125 - broken rev counter |
just got a 2002 honda cg125 and everything is running fine on it besides the rev counter that doesnt work at all
is there anyway to six this myself or is it a garage job?
thanks! |
| rob_scott92 |
 rob_scott92 Could Be A Chat Bot
 Posted: 19:06 - 28 Jan 2010 Post subject: |
most likely the cable has snapped where it goes into the engine, easy enough to check and replace.
Just get a pair of pliers, a cloth around the bit where you loosen the cable from the engine (as to not damage it), take out and replace. Jobs a good'un If it turns out the cable isn't snapped it could well be the mechanism inside the rev counter itself, but its most likely the cable.
Hope this helps
Rob  |
| dave_manz |
 Posted: 19:29 - 28 Jan 2010 Post subject: |
ah thats not too bad then
i will go have a look now  |
| dave_manz |
 Posted: 19:50 - 28 Jan 2010 Post subject: |
i have followed the cable down from the back of the rev counter and it has indeed snaped however i cant see where the cable should feed into  |
| rob_scott92 |
 Posted: 20:59 - 28 Jan 2010 Post subject: |
Basically , inside where the cable goes in there should be something pointing out a bit, kinda like a screwdriver bit if you like (Flathead btw ). on a new un-snapped cable there will be a bit on the end that fits over that.
Will try and get a pic for you if you're still stumped. it really is a 2 min job if that! i had the same when i bought my bike, its all a good learning experience
Let us know how it goes
Rob  |
| Moo. |
 Moo. World Chat Champion
 Posted: 21:32 - 28 Jan 2010 Post subject: |
When did CG's have rev counters?
Have a search on ebay, likely to be able to get a replacement cable and will screw in  ____________________ A2 Passed 18/6/10 |
| Ditto |
 Ditto Nearly there...
 Posted: 22:52 - 28 Jan 2010 Post subject: |
CG with a rev counter. Pah  ____________________ CG 125 > Bandit 600 > CBR 600 FY > Street Triple R |
| Alexio |
 Alexio World Chat Champion
The last post was made 16 years, 260 days ago. Instead of replying here, would creating a new thread be more useful? |
