| con |
 con Derestricted Danger
 Posted: 19:24 - 07 Feb 2010 Post subject: keeway de-restrict |
hi, ive got a keeway x-ray 50cc enduro bike, i would like to know how to de-restrict it, if this is possible thanks alot.  ____________________ con |
 ---- World Chat Champion
 Posted: 20:18 - 07 Feb 2010 Post subject: |
It's a 50cc 4 stroke so is never going to be fast.
I doubt there's any restrictors as such but you could always add free flow filter and bigger exhaust and change the jetting which might gain a extra couple of ponies.
Preferably sell it and get a 2 stroke.
 ____________________ DRZ-400sm |
| Devans |
 Devans Spanner Monkey
| con |
 Posted: 13:21 - 08 Feb 2010 Post subject: |
thanks alot lads its a 2 stroke totally standard, so it should be able to av abit more ump! lol.  ____________________ con |
 Posted: 15:42 - 08 Feb 2010 Post subject: |
I only had a quick look on the net and seen 4 stroke mentioned.
Might be worth taking the exhaust off to see if it has a restrictor where the exhaust meets the engine.It's usually just a big clump of weld that you can grind off with a dremmel.
Remove the airbox and see if there's anything slowing down the air flow.Pay attention to the snorkel which may be able to open up a bit or remove it altogether.
Then do a plug chop to make sure it's running well.
Maybe change the gearing(sprockets) a bit which will give you either more top end or better acceleration.
You could probably buy an aftermarket exhaust for it but again it's down to how much you want to spend really. ____________________ DRZ-400sm |
| con |
 Posted: 16:05 - 08 Feb 2010 Post subject: |
cheers for that great help, wer would u recommend i get the pipe from pm tuning or something?  ____________________ con |
| Kickstart |
 Kickstart The Oracle
| hmmmnz |
 hmmmnz Super Spammer
| con |
 Posted: 00:24 - 10 Feb 2010 Post subject: |
thanks alot lads, so basically what im looking for is a restricter in the exhaust, or just put a dt straight threw exhaust on, thanks for your comments, great help.  ____________________ con |
The last post was made 16 years, 187 days ago. Instead of replying here, would creating a new thread be more useful? |
