keeway de-restrict
con
PostPosted: 19:24 - 07 Feb 2010    Post subject: keeway de-restrict Reply with quote
hi, ive got a keeway x-ray 50cc enduro bike, i would like to know how to de-restrict it, if this is possible thanks alot. Smile
con
PostPosted: 20:18 - 07 Feb 2010    Post subject: Reply with quote
It's a 50cc 4 stroke so is never going to be fast.
I doubt there's any restrictors as such but you could always add free flow filter and bigger exhaust and change the jetting which might gain a extra couple of ponies.
Preferably sell it and get a 2 stroke.
Very Happy
DRZ-400sm
Devans
PostPosted: 00:17 - 08 Feb 2010    Post subject: Reply with quote
Yeah, it's most likely not restricted in anyway, other than maybe a strangled pipe. A decent full system is not worth the cost, for the improvment in BHP.
4 strokes are usually in a low state of tune. And the only way is to get it bored out. Which again isn't worth it.
con
PostPosted: 13:21 - 08 Feb 2010    Post subject: Reply with quote
thanks alot lads its a 2 stroke totally standard, so it should be able to av abit more ump! lol. Smile
con
PostPosted: 15:42 - 08 Feb 2010    Post subject: Reply with quote
I only had a quick look on the net and seen 4 stroke mentioned.
Might be worth taking the exhaust off to see if it has a restrictor where the exhaust meets the engine.It's usually just a big clump of weld that you can grind off with a dremmel.
Remove the airbox and see if there's anything slowing down the air flow.Pay attention to the snorkel which may be able to open up a bit or remove it altogether.
Then do a plug chop to make sure it's running well.
Maybe change the gearing(sprockets) a bit which will give you either more top end or better acceleration.
You could probably buy an aftermarket exhaust for it but again it's down to how much you want to spend really.
DRZ-400sm
con
PostPosted: 16:05 - 08 Feb 2010    Post subject: Reply with quote
cheers for that great help, wer would u recommend i get the pipe from pm tuning or something? Smile
con
PostPosted: 16:21 - 08 Feb 2010    Post subject: Reply with quote
Can easily make the flow rather worse by removing them. However it is also an easy place to try and restrict the airflow.
Most likely places for a restriction are in the exhaust, with some chance of one in the carb (but most likely they just fitted a small carb to start with).
hmmmnz
PostPosted: 20:14 - 08 Feb 2010    Post subject: Reply with quote
https://www.motogb.co.uk/keeway/models/x-ray50_enduro/images/key1_1.jpg
i'd say, it'll probably be an exhaust restriction,
your bike is basically uses a copy of the dt50 engine, so there are plenty of tuning parts out there that will work on your bike
the humans are dead
I kick arse for the lord
con
PostPosted: 00:24 - 10 Feb 2010    Post subject: Reply with quote
thanks alot lads, so basically what im looking for is a restricter in the exhaust, or just put a dt straight threw exhaust on, thanks for your comments, great help. Smile
con
The last post was made 16 years, 185 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.46 - MySQL Queries: 13 - Page Size: 60.78 Kb
