| gray84 |
 gray84 World Chat Champion
| G |
 G The Voice of Reason
| gray84 |
| Blue_SV650S |
 Posted: 23:42 - 26 Feb 2010 Post subject: |
Yep, check the airbox is seated correctly, check the ram-air pipes are fitted properly and check the airfilter is in there correctly ... seems they didn't put it back together properly!!  ____________________ The purpose of life is to fight maturity. |
| gray84 |
| Blue_SV650S |
| gray84 |
| gray84 |
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 18:31 - 07 Mar 2010 Post subject: |
Plugs?
Coils?
Leads? ____________________ My Flickr |
| gray84 |
| benjami |
 benjami Nearly there...
| Blue_SV650S |
| gray84 |
| Bikeless |
 Bikeless World Chat Champion
| Blue_SV650S |
| Bikeless |
 Posted: 21:36 - 07 Mar 2010 Post subject: |
Always try things that don't seem obvious,sometimes you stumble across the problem anyway,  |
| gray84 |
| Fortuna |
 Fortuna World Chat Champion
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 01:58 - 08 Mar 2010 Post subject: |
i had something very similar.
First day riding my r6 after the crash, but mine was worse and i couldnt get above 5k.
Airbox was the fault.
Take it off and make sure its plumbed in right.
2 tubes, one either side of the carbs, plug into the underside of either side of the airbox.
1 tube with plastic box thing plugs in from crankcase breather to rear of airbox
other plastic box comes from the top of the airbox, into plastic box at the end, plastic filter/collector thing plugs into the bottom of plastic box, and the final tube connects the plastic box to the top hoses on the carbs.
Took fucking ages to figure this out even though we knew it was the airbox at fault. The manual is useless regarding this. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| gray84 |
| Noxious89123 |
 Posted: 21:09 - 08 Mar 2010 Post subject: |
If the bike was fine before, and only started doing this after a service, I'd take it back and tell them they fucked something up! ____________________
| gray84 |
| gray84 |
| MaybeGuy |
 Posted: 00:31 - 28 Mar 2010 Post subject: |
could be an intermittent fuel pump?
check the thing that clicks when you turn the ignition. should be behind the rear shock sort of area. usually on a rusty bracket.
i doubt its coils or plugs as you said its fine up to about 10k ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Fortuna |
The last post was made 16 years, 217 days ago. Instead of replying here, would creating a new thread be more useful? |
