R6 running problem?
gray84
PostPosted: 00:05 - 26 Feb 2010    Post subject: R6 running problem? Reply with quote
can anyone help
on my 02 carbed r6 when i give it full throttle and it gets to 10k its dies and wont go over 10k revs but with gentle throttle it will go through fine. it coughs and splutters as if its hit a limiter when you do it ion full throttle.i think its being starved from air or fuel but want to know if anyone has had a simular problem?
now i noticed the other day if i leave the choke on a tiny bit its fine but turn it all the way off and it dies at 10k again.
im thinking the carbs need setting up but its only just had a major service 500miles ago but only just really been giving it some shit since the service...
anyone....?
cheers
PostPosted: 00:23 - 26 Feb 2010    Post subject: Re: R6 running problem? Reply with quote
Definitely worth checking the air system - not sure how any ram air works on a stock R6, but on my zx9 if the centre air line that comes from the two main air ducts was unplugged it would suffer similar problems to what you'd described.
gray84
PostPosted: 23:18 - 26 Feb 2010    Post subject: Reply with quote
ok thanks ill take it all apart tomorrow and have a look...
Blue_SV650S
PostPosted: 23:42 - 26 Feb 2010    Post subject: Reply with quote
Yep, check the airbox is seated correctly, check the ram-air pipes are fitted properly and check the airfilter is in there correctly ... seems they didn't put it back together properly!! Rolling Eyes
gray84
PostPosted: 00:02 - 27 Feb 2010    Post subject: Reply with quote
ok so it sounds more of an air problem than a fuel prob..if it is something to do with the air intake will it be something noticable when im having a look do you think?
ill let you know how i get on.
Blue_SV650S
PostPosted: 00:25 - 27 Feb 2010    Post subject: Reply with quote
Yep, it should be obvious.
My guess is that the aibox isn't seated properly ... Wink
gray84
PostPosted: 00:28 - 27 Feb 2010    Post subject: Reply with quote
ok place bets now!!!!!!!!
gray84
PostPosted: 18:28 - 07 Mar 2010    Post subject: Reply with quote
right i ripped the bike apart today!!!
its all fine.the ram air pipes are clear and fitted nice ,the filter is clean and seated right and so is the airbox and all breather pipes..
still got this problem though.
just noticed though that even with the choke on it still does it and only really does it from 3rd upwards. its bugging me.its like the bike just comes to a limit at 9.5k revs and the exhaust pops and bangs and the revs wont rise orless you gently go through that point of the rev range with no hard throttle.
anymore ideas?
cheers
PostPosted: 18:31 - 07 Mar 2010    Post subject: Reply with quote
Plugs?
Coils?
Leads?
gray84
PostPosted: 18:35 - 07 Mar 2010    Post subject: Reply with quote
its had new plugs..
how can i test all these and wouldnt it happen all the time not just at sertain revs?
benjami
PostPosted: 20:57 - 07 Mar 2010    Post subject: Reply with quote
I've got the same problem on my yzf750.
Does it feel like its dropping a cylinder? I'm presuming its something to do with the plugs/leads/coils on mine. Although i'm sure the slight hole in the exhaust isn't helping.
Let me know if you sort yours soon, mines gonna have to wait until I get my next instalment of my loan.
Blue_SV650S
PostPosted: 21:04 - 07 Mar 2010    Post subject: Reply with quote
gray84 wrote:
its had new plugs..
Have you still got the old plugs???
Best thing to do is to change them back to isolate/dismiss it is a plug issue ...
If it helps, it wouldn't be the first ever report of a NEW plug being faulty!! Wink
gray84
PostPosted: 21:27 - 07 Mar 2010    Post subject: Reply with quote
nope the garage did the plugs. im trying to think of a cheap way to check rather than buying new plugs..
looks like this is the route to check then cheers
ben-ill keep you informed
Bikeless
PostPosted: 21:29 - 07 Mar 2010    Post subject: Reply with quote
I would doubt it's a plug,check your fuel filter if it has one and i personally would strip the carbs and clean them anyway just in case.
Could be a blocked fuel filter not filling the float bowls quick enough if you can part throttle through it.
Just my 2 pence worth.
Blue_SV650S
PostPosted: 21:33 - 07 Mar 2010    Post subject: Reply with quote
I doubt that is the problem, but no harm in looking!! Thumbs Up
Gary84, the filter is under the tank near the fuel tap .. its a big one, you can't miss it! Thumbs Up
Bikeless
PostPosted: 21:36 - 07 Mar 2010    Post subject: Reply with quote
Always try things that don't seem obvious,sometimes you stumble across the problem anyway, Thumbs Up
gray84
PostPosted: 00:02 - 08 Mar 2010    Post subject: Reply with quote
my last service 200miles ago was a big one. they cleaned all my carbs up/new filter and i was looking at the fuel filter today. didnt look to bad. a little cloudy on the side where the fuel sits..im lost i really dont know what to do...
Fortuna
PostPosted: 01:02 - 08 Mar 2010    Post subject: Reply with quote
First is to make sure the Carbs are ok.
The thing I'm concerened with is the fact it pops and bangs, that's unburnt fuel in the exhuast which makes me lean towards electrical.
Could be a number of things and only a process of elimination will solve it.
MaybeGuy
PostPosted: 01:58 - 08 Mar 2010    Post subject: Reply with quote
i had something very similar.
First day riding my r6 after the crash, but mine was worse and i couldnt get above 5k.
Airbox was the fault.
Take it off and make sure its plumbed in right.
2 tubes, one either side of the carbs, plug into the underside of either side of the airbox.
1 tube with plastic box thing plugs in from crankcase breather to rear of airbox
other plastic box comes from the top of the airbox, into plastic box at the end, plastic filter/collector thing plugs into the bottom of plastic box, and the final tube connects the plastic box to the top hoses on the carbs.
Took fucking ages to figure this out even though we knew it was the airbox at fault. The manual is useless regarding this.
gray84
PostPosted: 09:15 - 08 Mar 2010    Post subject: Reply with quote
which bit wasnt right on yours then? i stripped mine down yesterday and it was all seated fine and all breather pipes were fine....
im trying to figure out "how to" test plugs and coils too. any help? bearing in mind its only happening at 10k revs.
tar
Noxious89123
PostPosted: 21:09 - 08 Mar 2010    Post subject: Reply with quote
If the bike was fine before, and only started doing this after a service, I'd take it back and tell them they fucked something up!
gray84
PostPosted: 22:13 - 08 Mar 2010    Post subject: Reply with quote
i did but the bike started running fine "of course" and then a wile later its doing it again. next time i go out it might not do it. but 9 out of 10 times i use it the bike acts a bitch again. ive emailed the company last night so ill see what he says this time.
gray84
PostPosted: 23:49 - 27 Mar 2010    Post subject: Reply with quote
could this be crap in my tank? i sometime get a noise like there is grit in my tank but surely it would be blocking it all through the rev range not just at 9.5k revs.
how can i test coil and plugs?
MaybeGuy
PostPosted: 00:31 - 28 Mar 2010    Post subject: Reply with quote
could be an intermittent fuel pump?
check the thing that clicks when you turn the ignition. should be behind the rear shock sort of area. usually on a rusty bracket.
i doubt its coils or plugs as you said its fine up to about 10k
Fortuna
PostPosted: 03:19 - 28 Mar 2010    Post subject: Reply with quote
Checked the EXUP valve as well?
The last post was made 16 years, 217 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.50 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 127.63 Kb
