Dead Clutch
JAMSXR
PostPosted: 10:14 - 12 Mar 2010    Post subject: Dead Clutch Reply with quote
Hi Chaps,
Bit of advice/help needed if possible!?
My bike (03 RSV-R) has been left standing over the last 6 months or so, I have been firing her up every few weeks to keep her happy.
Anyway I got her out this weekend because she’s due an MOT and I wanted to make sure she was running well, only to fined out my clutch has turned into a spongy nothingness! I'm aware that air in the clutch is common on the RSV but mine is unrideable, it's virtually impossible to even engage 1st..
Any ideas what the problem could be?
Thanks
James
hmmmnz
PostPosted: 11:00 - 12 Mar 2010    Post subject: Reply with quote
well, common sense would tell you to bleed your clutch.....
where is he, im sure ive seen him about Mr. Green
the humans are dead
I kick arse for the lord
Tim..
PostPosted: 11:20 - 12 Mar 2010    Post subject: Reply with quote
Also check for any leaks around the master and slave cylinders. Also check for any bulges in the pipe (if its standard rubber) and replace the fluid just by bleeding some new stuff through.
Tim
www.marshallracing.co.uk
JAMSXR
PostPosted: 11:41 - 12 Mar 2010    Post subject: Reply with quote
Air shouldn't have gone into the system with no use, so I thought it could be something else?
Also I'm a mechanical retard!
BanditsHigh
Worse than a woman
PostPosted: 11:47 - 12 Mar 2010    Post subject: Reply with quote
Do as the man says and bleed your clutch ... also get yourself a manual or a mate to give you a hand ... you only learn by doing Thumbs Up
PostPosted: 12:00 - 12 Mar 2010    Post subject: Reply with quote
Another vote for bleeding the clutch, but a leaky seal as timmy mentions is also a good possibility.
dobby
PostPosted: 12:14 - 12 Mar 2010    Post subject: Reply with quote
https://www.serviceaprilia.com/public/lum/index.asp?l=RSV%20Mille%202004
rsv manual on here... will tell you how to do it...
JAMSXR
PostPosted: 13:10 - 12 Mar 2010    Post subject: Reply with quote
Thanks for the advice chaps, I thought bleeding would be the logical option but it made sense to check here first.
The last post was made 16 years, 155 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 2.17 - MySQL Queries: 13 - Page Size: 57.78 Kb
