GSX250 output shaft oil seal
truslack
PostPosted: 07:38 - 16 Apr 2010    Post subject: GSX250 output shaft oil seal Reply with quote
The oil seal on my new GSX250 (81) behind the sprocket is knackered, and pisses oil out. Is the oil seal pushed in from the outside, or do the crank cases need to be split?
Ta
Mark
Tim..
PostPosted: 09:45 - 16 Apr 2010    Post subject: Reply with quote
Pics would be useful here but I think you should be able to do it without splitting the cases. Not 100% on it though.
www.marshallracing.co.uk
27cows
PostPosted: 11:34 - 16 Apr 2010    Post subject: Reply with quote
I'm 90% sure you can prise out the GSX output seal and replace it without stripping the motor.
Alexio
PostPosted: 11:38 - 16 Apr 2010    Post subject: Reply with quote
Surely you just need to take the front sprocket off?
pepperami
PostPosted: 11:44 - 16 Apr 2010    Post subject: Reply with quote
i`m sure you dont need to split the cases to change that seal.
but before the new one goes in, make sure that the recess is absolutley absolutley oil free, cos oil is like water in that if it can find a route past a seal it will! Sad
truslack
I can get TO it by taking the front sprocket off, that's why I'm asking whether it needs to be fitted along the shaft from the outside, or if there's a lip and it needs to be done from inside the crank case.
The last post was made 15 years, 304 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.24 - MySQL Queries: 13 - Page Size: 48.01 Kb
