VTR1000 firestorm front cylinder problem
TUG
PostPosted: 19:47 - 16 Apr 2010    Post subject: VTR1000 firestorm front cylinder problem Reply with quote
more of an issue really, its running alot cooler than the rear pipe, hands on the zhorsts from the cylinders and the rear one gets miles hotter than the front? the plug lead is sparking good, so is the cap, plug is new but with all that working its still running really cool?
Help.
Haz ER-5, innit!
Tim..
PostPosted: 20:03 - 16 Apr 2010    Post subject: Reply with quote
The rear cylinder will tend to run alot hotter than the front anyway, the front one gets alot more cooling from the air flow around it and the rear is incased by a bike. The same goes for inline 4's, the two inner cylinders will always run hotter than the outside two because they get more airflow.
Is the bike running well and revving up smoothly? What is the plug conditon like on both the front and rear cylinders, they should both have a light brown, tan or grey 'tinge' to them (no excessive carbon, oil or blistering). If all looks and seems fine you are probably worrying about nothing.
As my pa always says 'if it ain't broke...' Wink
But if you have to have a fiddle, go for a minor service (plugs, filters, oil) and balance the carbs.
Tim
www.marshallracing.co.uk
TUG
PostPosted: 20:09 - 16 Apr 2010    Post subject: Reply with quote
This is with the bike stood and running on tick over sorry i should of mentioned that, the plugs are new, the plug cap is new, the air filter is clean also.
Haz ER-5, innit!
Tim..
PostPosted: 00:13 - 17 Apr 2010    Post subject: Reply with quote
Just re-read your first post. Did you mean you can put your hand on the header or just a quick touch?
At the risk of making a mountain out of a mole hill. Is it def running on the front cylinder?
TUG
PostPosted: 00:18 - 17 Apr 2010    Post subject: Reply with quote
It does get warm just not as hot as the rear one and yes hand on header. Apparantly i need to check the balance and so forth first before jumping the gun.
Haz ER-5, innit!
temeluchus
PostPosted: 02:17 - 17 Apr 2010    Post subject: Reply with quote
assuming you have a good spark, i would say you have a lack of fuel.
I believe this one will be carb'd, have you tried draining the float bowl on that carb to see if it isnt full of water?
TUG
PostPosted: 22:18 - 20 Apr 2010    Post subject: Reply with quote
If it was my riding would of gotten rid of that.
Valves are tight, so worn seats i'm told. I need to pull the carbs apart too saturday night and rule them out, I don't know what size shims are in the bikes so i cant order any up to fit, i also want to fit APE manual CCT's aswell.
Haz ER-5, innit!
temeluchus
PostPosted: 23:35 - 20 Apr 2010    Post subject: Reply with quote
Not really. Plenty of water in the float bowl wont shift no matter how hard you push it.
TUG
PostPosted: 23:36 - 20 Apr 2010    Post subject: Reply with quote
Ok, I'll drain them tomorrow, if your wrong you need to paypal me £5 for wasted fuel. Thumbs Up Karma
Haz ER-5, innit!
temeluchus
PostPosted: 01:34 - 21 Apr 2010    Post subject: Reply with quote
pfft, 30p!
What makes you think your valve clearences have closed up? Did you measure them?
David Silver Spares would be a good place to check for honda bits.
TUG
PostPosted: 23:19 - 21 Apr 2010    Post subject: Reply with quote
Yep checked the front cylinders clearances and they where tight. It needs a huge going over, i doubt there is anything serious, it is a honda afterall, but knowing its not right is bugging me.
Haz ER-5, innit!
TUG
PostPosted: 23:38 - 23 Apr 2010    Post subject: Reply with quote
I'll give you a £5 if you can guess how i fixed my bike, it took me 10 mins to do. Karma
Haz ER-5, innit!
temeluchus
PostPosted: 01:14 - 24 Apr 2010    Post subject: Reply with quote
large hammer?
Billing
PostPosted: 01:47 - 24 Apr 2010    Post subject: Reply with quote
reseated the airbox? stripped and rebuilt the carbs?
Tim..
PostPosted: 14:22 - 24 Apr 2010    Post subject: Reply with quote
balanced the carbs?
Gapped and fitted new plugs?
TUG
PostPosted: 17:10 - 24 Apr 2010    Post subject: Reply with quote
None of the above, keep trying... and no it wasn't carb icing or punch it in the tits and do it up the gary either BCF. Its so simple. Thumbs Up Wink
Haz ER-5, innit!
cloric_tzr
PostPosted: 17:55 - 24 Apr 2010    Post subject: Reply with quote
you remebered that you had to start the engine for it to warm up?
or you took it for a 10 min ride to warm her up properly?
i dumped my girlfriend the other day! she wouldnt act out one of my fantasy's. all i wanted her to do was come home from work, catch me fucking her sister and join in!!! miserable bitch!
My wifes so ugly, the only thing that goes down on her
Is the internet connection.
Robby
Dirty Old Man
PostPosted: 18:43 - 24 Apr 2010    Post subject: Reply with quote
Put some fuel in the tank.
TUG
PostPosted: 18:59 - 24 Apr 2010    Post subject: Reply with quote
Nope it wasn't something obvious but was easy to sort.
C'mon guys...
Haz ER-5, innit!
cloric_tzr
PostPosted: 19:04 - 24 Apr 2010    Post subject: Reply with quote
C'mon guys...
ht lead caps wernt on properly
PostPosted: 19:28 - 24 Apr 2010    Post subject: Reply with quote
You remembered you were wearing gloves when checking the front pipe, but bare hands on the rear pipe?
TUG
PostPosted: 19:45 - 24 Apr 2010    Post subject: Reply with quote
No, no and ham wtf? no lmfao.
Come on, it was the front cylinder, the problem was still there after i balanced the carbs.
C'mon, what makes a cylinder run cooler?
Haz ER-5, innit!
TUG
PostPosted: 19:52 - 24 Apr 2010    Post subject: Reply with quote
too rich?
thermostat stuck open?
Thermostat stuck open wouldn't effect the exhaust pipe and both cylinders would suffer, rich on the other hand... But what was rich?
Haz ER-5, innit!
TUG
PostPosted: 20:20 - 24 Apr 2010    Post subject: Reply with quote
Nope.
Haz ER-5, innit!
PostPosted: 20:33 - 24 Apr 2010    Post subject: Reply with quote
Power band had come off the front cylinder?
The last post was made 15 years, 252 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 125.43 Kb
